03-07-2023, 10:45 AM | #1 |
24
Rep 36
X5 45E Rolled Away In Park?
My wife ran into my son's school today to drop off his lunch. The portico where you park is basically flat from what I can tell. She pulled car in driving forward... says she hit park then off. Got out of the car walked behind it. Walked in the glass doors next to the car, handed secretary the lunchbox and turned around and the car was gone. It was about 300' away. It had rolled backwards and scrapped 2x other cars. She said when she got in the car the P was illuminated?
Question I have is... what scenarios is this possible. Assuming her memory is wrong... if she got out of the car and left it in D... when you open the door does the car shift to P by itself or N? She said if you leave the car in N it will chime/alarm that you have done such. Any thoughts on what might have happend? Or is there a potential glitch in the matrix and I should ask BMW to pull the data to see if car is not parking correctly. |
03-07-2023, 10:48 AM | #2 |
Rep 895
First I've heard of such a thing. She put the car in Park, it was Locked and doors closed and it just rolled away? Does the school have footage by chance that you can take to the dealership? The 45e turns itself off and puts itself in park when you open the door as is, so something is def. weird.
03-07-2023, 11:01 AM | #3 |
24
Rep 36
Car was not locked, key was in her purse still. She was stepping away for 30 seconds and getting right back in. I called service adviser at BMW and he said she must have put it in N. She says the car notifies her if in N and you open the door. My memory is that the spot is almost flat. Almost like the car isn't holding park. I'm going to experiment with it tonight. The video from school is weird, because the car rolled away at a very slow crawl.
03-07-2023, 11:13 AM | #4 |
981
Rep 1,560
No idea what would cause that and I'm not trying to be critical, but that is why I always use my parking brake.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
Blue87375.50 |
03-07-2023, 11:48 AM | #5 |
Rep 464
Actually one of the more common complaints on this forum about the 45e is that you cannot keep it running while stepping out quickly, the engine always shuts itself off when you open the door.
03-07-2023, 12:13 PM | #6 |
MGySgt
637
Rep 1,256
Drives: See Garage List! ;-)
Garage List 2010 M5 [10.00]
2016 BMW 340xi M Sport [9.00] 2019 X5 50i M Sport [5.50] 2010 535xi [0.00] 2013 M5 [0.00] 2012 X5 M [0.00] |
Here's a short story. I bought a brand new 2012 535i Sport and after having owning it for a few weeks, I was in a rush to get to my Credit Union before it closed,...I parked the car,...and immediately jumped out and forgot to 1) put it in Park,...or 2) active the E-Park,...and or 3) engage Auto-Hold, etc. Anyway, I jumped out of the car,...and just as I took a step or two,...the car started rolling backwards. I was lucky to be able to open the door quickly and jump in and smash the BRAKES. As a result of this, an immediate lesson was learned and that is to ALWAYS ensure I see "P" in the gauge cluster before exiting the vehicle,...or just KILL the engine and the car will automatically engage "P" (Park).
I suspect your wife wanted to see "P" mentally, yet the vehicle wasn't in Park. Now is it possible that this is an issue that can happen? The answer is yes! However, it should be happening to hundreds to thousands of cars across many manufacturers as many use ZF transmissions, etc.
JMD
03-08-2023, 06:16 AM | #7 |
Rep 1,250
In the school video, when she comes to a stop and puts the car in park and gets out, can you see any tiny body movement? We all brake to a stop and put the car in park afterwords and in my experience there is usually an additional fractional move the car makes btw the parking brake and the pedal brake. Maybe you can see this on video?
03-08-2023, 08:54 AM | #8 | |
Rep 538
What I learned: Don't rely on the car to tell you it's in N. This car is always so quiet I never know whether it's running or not. In a situation like your wife's it would have been easy to get distracted. |
03-08-2023, 10:43 AM | #9 | |
Rep 76
Guy Fleegman400.50 |
03-08-2023, 11:28 AM | #10 |
Rep 80
I Just don't understand why so many people are so averse to using the parking brake, it isn't just BMW owners, I see it everywhere. Even when I pick up my cars from service the parking brake isn't engaged.
03-08-2023, 07:54 PM | #11 |
Rep 40
Exactly this. I didn't know you could open the door without it automatically going into Park. Maybe if you put it in Neutral first, it doesn't switch to Park automatically when you open the door??
03-08-2023, 07:56 PM | #12 | |
24
Rep 36
03-08-2023, 08:01 PM | #13 |
24
Rep 36
She said normal behavior is push the P button. Hit stop and get out of the car. She thinks she would have noticed the Neutral chime. I actually think there is a somewhat a design failure when P is just that small bush button on the back of the stick. I wish it was a firmer shift into P position. Before this happened, I have always felt uncomfortable with the P and shutoff in this car because so many items continue to run and it being electric there is almost little noticeable difference between running and stopped.
JMKBMWX5e16.50 |
03-08-2023, 08:13 PM | #15 |
Rep 40
Ugh, that's frustrating - glad nobody got hurt, and damage hopefully minimal! Def try to re-create it... see if you can put it in Neutral, open the door... and see if it remains in Neutral vs going to Park.
03-08-2023, 08:16 PM | #17 |
Rep 221
Around 8s in the first video, it looks like "P" did engage.. you see your wife stop the car, then it rolls back a tiny bit and stops as expected.
Strange :\ Hm there is a brief time period where shes still in the car after 8s. Maybe she got distracted by something, took care of it, and then hit P again as she finally got out of the car. Forgetting that she already hit it once, thus disengaging it? |
03-08-2023, 08:31 PM | #19 |
Rep 8,694
Drives: eVeRyOnE mAD!
pressing the P button doesn't engage/disengage Park when done subsequently. once in P, always in P unless the gear level is moved. (truth be told, coming from Audi, the BMW steptronic shifting 'directions' weren't that intuitive for me at first.)
maybe muscle memory got the best of her? as she came to a stop, instead of pressing the P button to park, she shifted the gear level UP from D which is how we used to shift into Park with the old school automatic gear selector (see photo), but doing so on the Steptronic shifter puts it into Neutral. still, the vehicle would chime that it’s in Neutral upon opening the door |
03-08-2023, 08:49 PM | #20 |
Rep 80
Everything in the manual says if you put it in P the car won't roll, but if you don't it will if the parking brake isn't engaged. Since the P light was on when she got to the car, it may very well be a software error that didn't engage Park and since the Parking brake wasn't set it rolled. You may never be able to recreate it.
03-08-2023, 09:37 PM | #21 |
Rep 114
Does your wife have the brake hold enabled? The answer to that question will probably go a long way towards determining whether it was a fault or very understandable user error. I just spent some time in my garage trying to replicate this, and with the brake hold on it is IMPOSSIBLE to get the car to roll, even if you shift into neutral. The car is parked, and stays parked, until you hit the gas again.
But if the brake hold is off, this is shockingly easy to replicate. Bring the car to a stop with your foot on the brake. Push the gear shift lever with a single finger, just above the park button, with the same light pressure you'd use on the park button. The car goes into neutral. You don't need to squeeze the side button like you do for reverse or drive. At this point, the car will roll if on an incline and you take your foot off the brake. Yes, it chimes if you open the door to tell you you're in neutral, but it's just a chime. If the music is on and she's grabbing for the lunch she's bringing in, and the car is standing still, it'd be way too easy to miss that the car is telling you it's in neutral. EDIT: Also, she says it was in park when she got back in -- from the video that's after it had a rear-end collision. Does anyone know if these cars put themselves into park after an impact? I assume so, but that might be a question to ask BMW as well. If yes, then the fact it was in park when she returned to the car is neither here nor there on whether it was in neutral when it rolled. If it were me, I'd still have the dealer check the car for fault codes -- it's possible something failed. But if there aren't codes I would chalk this up to user error and TERRIBLE human factors engineering. A car that turns itself off when you open the door should also apply the parking brake when you shift into neutral, and affirmatively make you turn the parking brake off if you want it to roll, e.g. in a failure situation. I'd consider filing a report with NHTSA as a design defect issue, as it may be the car was operating as designed but still hazardous. Last edited by Chonkapotamus; 03-08-2023 at 09:54 PM.. |
03-09-2023, 08:09 AM | #22 |
Rep 213
How did you update the display to show the P more prominently??
X5 xDrive 45e 2023 / Mineral White / Tartufo / Anthracite-Brown Poplar
