View Poll Results: Do you have engine problems with your 50e? | |||
Yes | 48 | 32.00% | |
No | 40 | 26.67% | |
Not a 50e owner | 62 | 41.33% | |
Voters: 150. You may not vote on this poll |
06-19-2023, 12:56 AM | #1 |
40
Rep 33
Drives: BMW X5
2024 50e engine problems poll
It seems like there are multiple threads going on regarding the new 50e check engine light being on within weeks of delivery.
And it seems like most of them are related to some sort of A/C shut off valve. I’m starting a poll trying to see how frequent is this issue. Any additional input will be greatly appreciated. |
06-19-2023, 04:02 PM | #3 | |
40
Rep 33
Drives: BMW X5
Given the volume of the vote I did not expect to get anything statistically significant anyways. Also there is selection bias involved and the data is probably skewed. But from what we have so far it seems like this issue is relatively wide spread. Hopefully we get some official response from BMW soon. |
06-19-2023, 05:56 PM | #5 | |
182
Rep 335
06-19-2023, 06:15 PM | #6 |
Rep 531
Mine was the refrigerant valve issue for cooling the high voltage battery as discussed in the aforementioned thread.
Gone but not forgotten...2009 E90 Le Mans Blue M3 6MT De-Chromed, Rogue SSK, Brembo BBK, Eibach Pro Kit, Eisenmann Race Black, MS Filter. 1998.5 Titanium Silver E36 M3 Coupe NASA GTS2 Race Car.
Vnoxdev39.50 aaaaaaaaaz576.50 |
06-19-2023, 08:23 PM | #7 |
24
Rep 49
Mine was for error code P2EB8 -- which seemed to be something related to the 48V system, but no clear definitions online. Also seems that code appeared on other models -- e.g. the X7 -- based on some quick searches of these forums.
The dealer consulted with BMW NA, reset it, drove it 40 miles, and declared it a-okay. Not confidence-inspiring, but the light hasn't come back in two weeks. I'm curious about the error code for this more serious issue. Might anyone know? |
07-11-2023, 11:39 PM | #10 | |
Generalissimo
662
Rep 1,421
alison621.50 |
07-11-2023, 11:41 PM | #11 | |
Generalissimo
662
Rep 1,421
08-26-2023, 08:29 PM | #12 | |
Rep 13
Drives: Bmw x5 50e
08-26-2023, 08:48 PM | #13 |
Rep 13
Drives: Bmw x5 50e
Terrible!
08-27-2023, 11:49 AM | #15 |
Rep 99
Most likely there is a 48V bus in place for select ECUs and functions such as engine stop/start. The difference would be that the 48V bus is likely supplied not from a small 48V battery pack but from the HV pack by way of a DCDC. This would allow the automaker to reuse some electronics from the other vehicles.
10-22-2023, 09:14 PM | #16 |
Rep 1
I have the same issue: x5 50e
I got my 2024 X5 50e last Wednesday, 3 days after 90 miles, check engine light turned
on I sent a message to salesperson to see what I should do, at the same time, made an appointment for next Friday for service check |
03-24-2024, 02:14 PM | #17 |
Rep 8
Can you let us know the problem and resolution? This thread oddly stopped abruptly.
03-24-2024, 04:01 PM | #18 | |
13598
Rep 20,236
As far as your question goes, the root causes of the issues still have not be found from what we have seen. Some CEL's go away by themselves, some with a software update and others need parts replaced. We have seen some come back in all three instances.
