      04-16-2023, 05:59 AM   #1
coolcat0304
47
Drives: honda civic
MGU22H hardware specification and photos
MGU22H is the current head unit used in the 7 series. It is expected to be used on X5/X7 starting from August 2023 production.
External photos: https://fcc.report/FCC-ID/T8GMGU22H/5770732.pdf
Internal photos: https://fcc.report/FCC-ID/T8GMGU22H/5768501.pdf
SoC closeup is attached.
VERY big hardware upgrade compared to MGU21. I will only be describing the major changes:
MGU21 uses Intel Atom x7-A3960 and Intel HD Graphics 505
  • 4 CPU cores @ 2.4ghz
  • 18 GPU cores @ 750mhz
  • 14nm process node
  • GPU produces 187.2 GFLOPs
with 2x4GB RAM. The processor is 7 years old but runs core functions relatively well.
MGU22H uses Snapdragon SA8155P with 2x8GB Micron LPDDR4 RAM. The processor is pretty much an automobile version of Snapdragon 855.
It has 8 GPU cores and an Adreno 640 GPU, including:
  • 1x Kryo 485 Prime core @ 2.96 GHz
  • 3x Kryo 485 Gold cores @ 2.42 GHz
  • 4x Kryo 485 Silver cores @ 1.80 GHz
Adreno 640 blows the GPU used in MGU21 out of the water, producing a massive (relatively speaking) 954.7 GFLOPS. For comparison, the GPU used in Xbox One produces 1300 GFLOPS.
What does this mean for all of us?
1) 99.99% certain that cars using MGU21 will not receive the iDrive 8.5 update due to the significant change in hardware specification.
2) Snapdragon SA8155P is compatible with Android, so slim chance that we might receive an update to iDrive 9 in the future.
3) X5/X7 in April production get a head unit called MGU21A. Hardware specs are currently unknown. At this stage, order at your own risk of being unsupported later on down the track.
Appreciate 4
playswcars3633.50
HNSKP313.00
ifr1198.00
      04-24-2023, 07:53 AM   #2
Heavyd
Heavyd's Avatar
865
Drives: 2024 X5 50e
What unit will the May/June/July production get?
      04-24-2023, 08:19 AM   #3
TurtleBoy
TurtleBoy's Avatar
13269
Drives: 2019 X5 40i,2021 M340i
See 3 above: 3) X5/X7 in April production get a head unit called MGU21A. Hardware specs are currently unknown. At this stage, order at your own risk of being unsupported later on down the track.
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50
      04-24-2023, 01:38 PM   #4
avalon652
avalon652's Avatar
Drives: Soon to be 2024 X7 M60i
Check out this thread over with the X7s - some translated content on this topic coming out of German FAQs. End of page 36 and early 37 on Mobil.
      04-25-2023, 09:42 AM   #5
BimmerDad84
Drives: 2024 X5 50e Midnight Sapphire
Some ppl said that the x5 production in July will receive this but it's actually April? Is the head unit hot swappable to the updated version if you get stuck with the 21a.
      05-04-2023, 07:25 AM   #6
coolcat0304
47
Drives: honda civic
A new head unit will be used for July/August production. Will most likely be hot swappable if the Service Packs remain the same. Whether you want to fork out around $5000 USD just for the part alone is up to you.
      05-04-2023, 09:23 AM   #7
TurtleBoy
TurtleBoy's Avatar
13269
Just for clarity, an interim new head unit (MGU21A aka MGU4+) was also used starting with April production.
      05-23-2023, 08:52 AM   #8
xlover
2191
Drives: 2023 X7 40i
coolcat0304 figured i would toss this in here too because of all the different threads accross bimmerpost on ID8 ( and saw you posted in the x7 section)
Jan build 2023 x7 has MGU22H so seems like BMW has filtered the most capable headunit out sooner than some originally thought
      07-04-2023, 05:36 PM   #9
Black Beauty
Drives: F150 4x4 FX4 Hybrid
Is this only for those vehicles that have the hands free driving package?
      07-04-2023, 05:39 PM   #10
TurtleBoy
TurtleBoy's Avatar
13269
No, all LCI X5's and X6's.
      07-04-2023, 05:45 PM   #11
Black Beauty
  • 14nm process node
That Qualcomm Chip has Vulnerabilities in SA8155P
https://www.cybersecurity-help.cz/vdb/qualcomm/sa8155p/
Looks like they have patch them as the last update was May 2023. I do not know how BMW deals with cyber attacks and how they would apply patches.
      07-04-2023, 05:47 PM   #12
Black Beauty
Thank you sir, I was wondering if it was on the X5 50e's.
      07-04-2023, 05:54 PM   #13
Black Beauty
There was a firmware vulnerability in 2021 for Qualcomm Pmm8155au
https://www.cvedetails.com/version/6...m8155au--.html
https://stack.watch/product/qualcomm/pmm8155au/
      07-05-2023, 02:21 AM   #14
coolcat0304
47
Drives: honda civic
In the past, BMW dealt with security flaws through a combination of "configuration updates" over-the-air component and also offline firmware patches.
BMW now states that "quick closure of possible safety gaps in the software" is possible through Remote Software Update. I'd imagine that is how BMW will deliver most fixes to their customers (combined with backend fixes for ConnectedDrive).
      07-08-2023, 08:51 PM   #15
mojoJJ
mojoJJ's Avatar
Drives: 2024 X6 xDrive40i
So, I had nothing better to do on a Saturday morning and ended up digging thru all FCC filings, Qualcomm data sheets and reference schematics to make a sense of this. There are a lot of threads discussing this but I’ll post my investigation here. Only posting head unit technical information, not sure what’s going on with ID8.5.
I have a 4/23 built X6 40i with MGU22/MGU22H head unit, based on the regulatory information from iDrive. People saying that what iDrive says doesn’t matter are wrong, thats not how FCC filing/approvals work. BMW has to get approval based on what hardware is in the car, not based on what software is running. This cannot be changed with OTA since the hardware cannot change. They list both, MGU22 and MGU22H because they’re almost identical in HW (except, see below).
MGU22
  • Made by Garmin
  • Snapdragon SA8155 SoC
  • 3 USB ports, 100BASE-T1 + 1000BASE-T1 ethernet
MGU22H
  • Made by Harman
  • 2 USB ports, just a 100BASE-T1 ethernet
So they should be interchangeable, but I’m not too sure about the lack of 1 gig Ethernet port and 1 missing USB on the MGU22H. Maybe they thought they’ll use it for something and later didn’t so they removed it from 22H.
MGU21/MGUFA/MGUFQ
All of these use the really old Intel Atom A3960 platform and other hardware is similar between them.
MGU21A
Like others have said, there’s not a lot of information on this. The FCC filings are very recentl and they’ve requested secrecy from FCC for up to 180 days. Hopefully the photos show up soon. But going by number schems, doesn’t seem like it will have Qualcomm SoC.
ICD23/23H
Again, similar to MGU, they’re identical in hardware. ICD23 made by Garmin and 23H made by Harman.
One interesting thing is that even though ICD is still based on SA8155, they’re not using Qualcomm WiFi/BT, LTE or GNSS solutions. Instead, they’re going with NXP 88Q9098 for WiFi 6 and BT 5.3 and UBlox UBX-M8030 GNSS which supposedly has better urban canyon performance.
To summarize - all newer units which are running Qualcomm SA8155 chipset (almost reference design HW) are more than capable of running ID8, 8.5, 9 and whatever the hell you throw at it. Whether they get software upgrades or not is another story, but it sure isn’t a hardware limitation.
