12-22-2019, 08:18 AM | #705 |
456bhp for breakfast
425
Rep 913
12-22-2019, 09:06 AM | #706 | |
Rep 810
I can't understand why BMW doesn't make at least Sport+ available in all X5 models. Its there for the 40i, 50D and 50i - seems like 30d owners have been singled out to miss out ! |
12-22-2019, 09:08 AM | #707 | |
Rep 810
Pressing Sport mode twice just toggles between "Sport" and "Sport Individual", but there's no "Sport+" mode in the 30d. I've been told it can be done, just requires more advanced coding like esys. |
LexxM31698.50 |
12-22-2019, 09:56 AM | #708 | ||
2020 Mineral White 30d MSport
523
Rep 2,146
Drives: 2020 Mineral White 30d MSport
12-23-2019, 02:24 PM | #709 |
Rep 65
Hi guys. I'm about to jump in on this coding but I don't see anything about opening the exhaust flaps. Is that possible through bimmercode? Is that just a Carly thing? I want my baby to sound angrier. Amy info would help thanks. Happy holidays
12-23-2019, 04:19 PM | #710 |
Rep 2,609
There is no known coding for the flap. However, one can open it with software and then either remove the control cable or pull the fuse. You can also open it by driving and pulling the fuse during motion from the trunk. If you like Bimmercode and want to support the same developer, his BimmerLink paid app will open the flap to allow cable or fuse hack.
12-23-2019, 05:38 PM | #711 | |
162
Rep 360
12-23-2019, 08:08 PM | #712 | ||
134
Rep 326
12-23-2019, 08:29 PM | #713 |
162
Rep 360
ok thanks i miss understood. i thought just going the one caused it to work when in assistance mode and using the other three caused it to stay on all the time.
12-23-2019, 11:24 PM | #714 |
162
Rep 360
I made the change and left the first code in and it seems to show up in the driveway. Not sure if i was supposed to remove the first line. we will see how it works tomorrow.
12-24-2019, 02:25 AM | #715 | |
1198
Rep 1,587
Some can get it working with just the first setting, others require 3 or 4 of the settings. Not all settings are available for all cars dependant on i-step, region and/or factory options. My best advice is to code as many of the 4 as you are able. |
scott135i355.50 |
12-25-2019, 01:25 AM | #716 |
Rep 71
Hi,
Just wanted to check if anyone was able to code Lane Change Assist. I saw it a few pages ago but the instruction wasn’t clear, can we code it via BimmerCode? If anyone can share their experience and the steps to code. Thanks in advance Jeet |
buze132.00 |
12-25-2019, 03:29 AM | #717 | |
1198
Rep 1,587
You can vo code with esys alone, or fdl code with a launcher. |
jeet26.00 |
12-26-2019, 01:22 PM | #718 |
Rep 274
Successfully coded Video in Motion and M start up screen. No issues on 2020 40i. Used ENET cable and RJ45 to lightning adapter with iPhone 11 Pro.
12-27-2019, 01:33 AM | #719 |
Rep 71
Successfully coded the following:
ADV Auto Start Stop Video in Motion Warnings Start Animations I am having issues with Tire Pressure Monitor doesn’t shows Tire pressure and temperature. Please can someone advise if there is any other values that need to be changed. Thanks Jeet |
12-27-2019, 10:29 AM | #720 |
13
Rep 32
Drives: 2019 G20 330i M-Sport
Hello, can anyone please send amazon links for working adapter for coding through BimmerCode app?
12-27-2019, 11:29 AM | #721 | |
Rep 419
Choose the adapter for the G series and OS. I'm using OBDLink MX+ Bluetooth per recommendation from helpful users in this forum.
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs] |
12-28-2019, 09:47 AM | #722 | |
13
Rep 32
12-28-2019, 10:10 AM | #723 | ||
134
Rep 326
12-28-2019, 11:59 AM | #724 |
Rep 27
ENET cable and Ethernet to lightning adapter is about $40 and is the most versatile. Not only can you use the ENET cable with eSys coding, but certain bimmercode features are coded through ENET because of its higher data rate (like HKFM - Tailgate)
ENBIA RJ45 Ethernet LAN Network Adapter for Phone Pad, Phone Ethernet Adapter, 3.3ft/1m Ca... https://www.amazon.com/dp/B07SYH7PMW...sms_tai_1z5bEb... |
vicfalc09211.00 |
12-28-2019, 12:23 PM | #725 |
Rep 27
I recently successfully tested HKFM tailgate coding with Bimmercode TestFlight (Version 3.5 10325) + ENET cable. The developer provided to validate, so hopefully we’ll see it re incorporated in the next full release.
12-28-2019, 12:24 PM | #726 | |
135
Rep 372
