11-26-2021, 02:18 AM | #2 | |
Rep 2,630
It is easy to clip in the holder and then remove when not needed. Since the iPad pairs so well with Bluetooth headphones and the wifi in the car, it is better than any inbuilt entertainment system. IMHO. |
01-04-2022, 11:21 AM | #3 | |
181
Rep 326
01-04-2022, 12:41 PM | #4 | ||
Rep 2,630
https://www.shopbmwusa.com/PRODUCT/6...-TABLET-HOLDER |
01-04-2022, 01:13 PM | #5 | |||
Rep 463
01-04-2022, 01:54 PM | #6 | |
Rep 7,470
If you click the following link...you can scroll down the part nbrs below the diagram to find the exact 11 digit BMW part nbr you need for an 11" iPad. Once you have the correct 11 digit BMW part nbr...you can then simply type "BMW xx xx x xxx xxx" (where x = the actual part nbrs) into a google search box to find vendors that sell that product. An 11 inch iPad may require #9 & #10 if you have the base system (#1).
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 01-04-2022 at 02:08 PM.. |
njnets21245.00 |
01-04-2022, 01:59 PM | #7 | ||
Rep 463
Update: I see now they actually did update this with the newer models. Thanks. |
01-04-2022, 02:11 PM | #8 | |
Rep 7,470
Good luck.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 01-04-2022 at 02:17 PM.. |
volodp196.50 |
01-04-2022, 05:47 PM | #10 | ||||
Rep 2,630
01-04-2022, 05:49 PM | #11 | |||||
Rep 463
Update: Nevermind. Your link had two part numbers. You must have the 11" part number then. |
01-04-2022, 11:54 PM | #12 |
Rep 155
FWIW, I have the tablet holder and use it w/ an Ipad 6 mini. I use it with this case: https://amzn.to/3EVMLbb I have it hooked up with a magnetic c to c cable so it’s easy to slip in and out. It’s fairly secure; the case has the pencil slot with gives it enough height in landscape to be held by tablet holder.
IMO I don’t think you *need* to use the BMW cases, but if you have a compatible ipad, go for it. if you don’t - like me - you may have to buy a few cases to find one that works. Not all ipad mini 6 cases work; i had to try a few. |
01-05-2022, 12:34 AM | #13 | |
Rep 4,451
I have the same as you but opted to buy 2 x item 1 as that allows me to choose the mounting height of whatever optional attachment I use (primarily the hooks and the laptop table). |
