Oil change -- what oil to use?
05-11-2011, 11:18 AM | #1 |
Rep 272
just wondering.. i need an oil change this month and i am not going back to the dealer, no more warranty.
im planning to take it to a local performance shop, and yes, they have worked on bmws before. i know i will have to put FULL syn, 5w40 or 5w30. how many qrts? and what brand is preferred? btw, how much is for 1 qrt of the FACTORY bmw full syn. performance oil? if i get it from the dealer? thanks |
05-11-2011, 11:28 AM | #2 |
Rep 2,818
Drives: F33 430 and F39 M35i
you need bmw LL01 approved oil. check the back of the bottle for that.
i am still under maintenance warranty for another year, but i do my own oil changes at 6 months. i usually wait for a sale from my local autozone, advance auto parts, etc. stores. they will usually have 5 qts of oil and filter on sale for like $40. it is usually mobil 1 full synthetic. i forget who makes the oil filter for our cars. i get the mobil 1 0w40 because that is their european formula which is bmw ll01 approved. i end up buying it twice so i have the required seven qts of oil. the second set i buy, i buy an oil filter for my wife's car and get her regular oil and save the synthetic for my next oil change. |
05-11-2011, 12:29 PM | #3 |
Rep 5,627
You can order a complete oil change kit including filter for $69 including shipping from Tischer:
http://www.trademotion.com/partlocat...egoryID=138022 Tom |
05-11-2011, 12:59 PM | #4 | |
74
Rep 1,543
1. Why do you and the BMW website advocate LL01 oils which have weights that differ greatly from what was specified on the engine by the manufacturer? 2. You maintain that BMW LL01 testing is required for all BMW engines, yet have no explanation for why BMW does not use LL01 oil in its M engines. 3. If BMW does not require testing of LL01 above 0W40(a weight, BMW does not recommend for any of its engines, per the part number written on them), why then do quite a few oils from manufacturers such as motul, total, pentosin, etc have LL01 approved oils with weights above 0W40. Why did BMW test, and approve those oils, but not use them in the M engines? |
05-11-2011, 06:45 PM | #5 | |
NHTSA Nazi
28
Rep 1,983
How BMW tests oils, why they test it or what they test is immaterial. The fact that BMW requires a different oil for the M series has absolutely nothing to do with this discussion with one exception - if you don't use the BMW required oil for your M, then you can kiss your M warranty goodbye. |
05-23-2011, 09:57 AM | #6 |
Rep 182
Drives: Black 2007 BMW 328xi
quick question and this has nothing to do with the 3 series non m motors but why dont they use ll-01 oils in the m motor
05-23-2011, 08:57 PM | #8 |
NHTSA Nazi
28
Rep 1,983
05-24-2011, 12:33 AM | #9 | |
DSC OFF!
34
Rep 230
p.s I'am on bmw oem full synth. |
05-24-2011, 07:04 PM | #10 |
NHTSA Nazi
28
Rep 1,983
05-29-2011, 12:34 PM | #11 |
EXPAT
65
Rep 889
06-02-2011, 07:02 AM | #12 |
3637
Rep 10,397
06-02-2011, 07:50 AM | #13 |
EXPAT
65
Rep 889
06-02-2011, 09:19 AM | #15 |
3637
Rep 10,397
06-03-2011, 05:10 AM | #16 |
EXPAT
65
Rep 889
Yup, LL04 0W30. Here's a picture of the stuff:
http://www.e90post.com/forums/showthread.php?t=433503 |
06-03-2011, 08:40 AM | #17 | |
3637
Rep 10,397
06-06-2011, 12:47 PM | #18 |
Rep 2,783
Take a look at Castrol 5w-40 it states on the label that it is designed for bmws. It also meets all certifications for Castrol 0W-30. If you go by certification you would think that Castrol 5w-40 is the same as Castro's 0w-30. However, Castrol's website shows that their 5w-40 is NOT for bmws that require LL01 ( see link, page 2) [http://www.castrol.com/liveassets/bp...syntec_usa.pdf This LL01 cert must mean something. Why risk using royal purple or amsoil or any other oil without that LL-01 certification? Castorl 0W-30 and Mobil 1 0-40 have that certification. The complete list can be found on BMW's website http://www.bmwusa.com/Standard/Conte...ngineOils.aspx
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
MacGuberman9.00 |
06-07-2011, 06:49 AM | #19 | |
3637
Rep 10,397
06-07-2011, 11:25 AM | #20 |
43
Rep 364
I went to BMW and they gave me 5w-30 for my 335i with an oil filter with the rubbers and crush washer. Cost me around $50-60. Better than $120 for them to do it.
06-07-2011, 01:12 PM | #21 |
Rep 2,783
Castrol 0w-30 and 5w-40: Does not meet API SN, Does not meet SM, meets SL, SJ, ACEA A3, B3, and B4. 0w-30 is LL-01 approved and 5w-40 is not, why?
By the way, Castrol 10w-40: MEETS API SN, SM, SL, SJ, ACEA A3, B3, and B4 but why isn’t it LL-01 approved? This oil meets two other criteria API SN and SM more than 0w-30 and 5w-40 and it is not LL01 approved or LL-98 approved, why?
06-07-2011, 01:32 PM | #22 | |
3637
Rep 10,397
