Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Losing my freakin mind,this car is killing me. Now Crank shaft pulley?
      04-26-2016, 07:52 PM   #23
Lexx.md
Drives: e90 335D
Originally Posted by BB_cuda View Post
Cortego 80001103 follow on story. First here is a web site that is in german but I was able to put it in the cart (but with one trick).
https://www.motointegrator.de/warenkorb/
Nice! I have to order there as well, just have it in stock as it seems to be a critical part. Maybe even should have in the trunk
      04-26-2016, 07:56 PM   #24
Lexx.md
Drives: e90 335D
Originally Posted by Yozh View Post
Checked pics in this thread https://www.drive2.ru/l/6760454/
against my OEM pics that I had posted in another thread and they look very much identical. Poster in that thread also mentioned and showed pics of OEM p/n filed off. As such, the conclusion is that Corteco is most likely the OEM supplier to BMW.
Have read it again, and at the end he says that in Russia, or Belarus they have same name for money so hard to understand But the price was 240$ USD and he says that if not replaced in time could came apart and break timing cover which will be way more expensive to repair.
      04-26-2016, 08:01 PM   #25
Lexx.md
Drives: e90 335D
This German vendor's site didn't work right if you click the translate to English button. I couldn't put the part in the cart. I used an ap on my phone to translate from German to English real time using the phone's camera. I then was able to do all if the transaction mechanics with the site in german "mode". My motive was to get the final cost shipped to my doorstep.
Just had tried and received message:
PayPal payment failed
The PayPal payment could not be performed because the specified in the destination country is not served.
      04-26-2016, 11:11 PM   #26
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
Unless you take a tool kit with you everywhere (which its starting to seem like that might not be a bad idea ) you wont be able to do alot... That is unless you plan on driving it to a mechanic and telling him to put this part on...
You are right though...it is pretty critical....cant do a whole lot without it.....and given that there are no outward signs of nearing failure, we probably all should have one ready to go....
While im at it....JUST prior to failure, did anyone notice a little low end sluggishness? Im trying to diagnose a little weirdness right before it let go...
      04-27-2016, 07:04 AM   #27
GaryE30
COAL FED
74
Drives: 335d, M3, X5
Yeah I'm thinking he wants it in his trunk to minimize downtime. Even if you can't drive the car to a shop, once you get towed there, you have the replacement part in-hand and don't have to wait for delivery.
      04-27-2016, 09:02 AM   #28
Lexx.md
Drives: e90 335D
Exactly, and i am driving between from Philadelphia, Boston, Quebec and Vermont and upstate New York, so to find a part in these locations could be very very challenging
      04-27-2016, 09:14 AM   #29
kydiesel35
kydiesel35's Avatar
Drives: 2016 X5 35d
2011 BMW 335d  [0.00]
I don't think it'll be a repetitive issue if you use oem parts and change belts and bits at the same time. Average lifespan seems to be around 60k according to the report chart. I'm at 68k no problems just yet, seems to be in the near future though... Nice to see these discussions though, I'm about to go stage 3 as well... Hope everything works out for you after this fix.
      04-27-2016, 11:12 AM   #30
DSB335d
Drives: '11 335d DSB/oyster&black/navi
Does anyone know if these engines are internally or externally balanced? If they are internally balanced it would be nice to ditch the crappy harmonic balancer for a lighter one piece crank pulley. Maybe someone on here can talk BPC or another reputable shop into making some better quality crank pulley's for these cars?
      04-27-2016, 01:17 PM   #31
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
Internal balanced. I don't think you would want to give up the damping. If you go to one piece metal, that is what would happen.
      04-27-2016, 01:52 PM   #32
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
Yeah based on what I have read....the dampening is intended to protect the crank shaft...Ill take crank shaft protection over some questionably reliable rubber.
Well if you are driving around all over hell with this car after 75k....Id probably keep one around....its not a very common part for most places to have on hand it seems. Though I dont think they have ANY parts in stock for the 335d locally.
      04-27-2016, 02:00 PM   #33
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
I hope so too. Id suggest at least having one on hand for that eventuality.....its almost like buying a couple cases of oil....you know you are going to use it at some point...and when you need it, your car will be down for at least 3 days for shipping the new part.
Even though there was a huge argument about this on another thread, I cant help but think that the extra torque, in addition to the speed of which that extra torque increases (check the dyno chart for it) puts this part directly in the crosshairs of things that might fail after stage 3.
      04-27-2016, 04:14 PM   #34
Built4Sin
TL/DR
Built4Sin's Avatar
Drives: 2009 335d Sport
2009 BMW 335D  [9.00]
2014 Audi Q7 TDI  [0.00]
Seems like it could also be a heat issue, hence why Cortego added the plastic heat shield to deflect some of the heat that seems to be slowly softening the rubber and deformation.
I wonder on the list BBCuda has running, state wise (temp fluctuation) everyone is.
Dixy2k 86,330 miles
DSB335D 81,000 miles
PR ~50,000 miles (PR verified now)
Chau 107,000 miles
montr 67,000 miles
Barmlot ~70,000 miles
Nushibo 80,000 miles
petey_highboost 122,000 miles
Flyingman 70,000 miles
OmahaDZL, 107,000 miles
      04-27-2016, 04:50 PM   #35
BB_cuda
BB_cuda's Avatar
765
Lexx, did you ever figure out what happened? I've used Paypal for method of payment in Denmark, UK, and Lithuania. Paying in euros to that German site should be straight forward. There is a way to talk with PayPal where you give them your phone number and they call you.
      04-27-2016, 07:57 PM   #36
Chief Orman
Chief Orman's Avatar
Drives: 335D 2010
Originally Posted by montr
Classic harmonic balancer pulley failure. Mine failed at 67 K miles. When you replace the pulley, it is a good idea to replace the two belts at the same time.
It is not something that you did or the tune. The OEM pulley is of poor quality.
me too at almost exactly the same mileage
      04-27-2016, 08:04 PM   #37
Lexx.md
Drives: e90 335D
I believe they just don't want to ship to US. I have tried to go thru normal checkout and they had only 2 countries in the list Germany and Austria.
      04-27-2016, 09:15 PM   #38
BB_cuda
BB_cuda's Avatar
765
Chief, do you need to be tacked onto the list? I hadn't heard of your pulley going bad.
      04-27-2016, 09:40 PM   #39
JOHNNYBRAVO1
NY BRAVEST
Drives: 2010 Monaco blue, 335D
I'm at 98,000 on the OEM with BPC 3, is there an up dated cortego part # im getting worried now.
      04-27-2016, 09:40 PM   #40
Chief Orman
Drives: 335D 2010
yes and in some ways it was the most disturbing breakdown from a "what the hell is wrong with my car" perspective...fixed under CPO warranty
      04-27-2016, 09:43 PM   #41
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
I would definitely suggest getting one on hand, but hold off until this weekend when I post images of the one I ordered
      04-28-2016, 05:44 AM   #42
Persian Whisperjet
Kind of a Big Deal
Drives: 2011 335d
What does it sound like when the balancer is starting to head south? When I gutted the SCR I noticed a vibration around 1800 RPM but I assumed it had to do with the SCR and maybe I didn't fasten down something perfectly. That was 10K miles ago and the car is at 68K. Anyone think I have a bum balancer? Could a balancer be "on the way out" for 10K miles?
      04-28-2016, 07:55 AM   #43
montr
Drives: 2010 335d, 2018 430i G-Coupe
In my case, there was no sound, no warning prior failure. It is sudden.
      04-28-2016, 09:41 AM   #44
kydiesel35
kydiesel35's Avatar
Drives: 2016 X5 35d
https://m.thoroughbreddiesel.com/sto...roke-7-3L.aspx
Thought I'd share with everyone how they are making performance aftermarket dampeners for diesel trucks. They claim that torsional vibration is increased with any tuned application.
I'm contacting fluidampr now for possible fabrication for our vehicles.
