Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - halogen to xenon error removal
      11-24-2008, 08:01 PM   #23
joebaggg
E60
joebaggg's Avatar
Drives: Black Attack
2006 E90  [0.00]
does anyone know about resistors????!?!? im desperate the bulbs for this kit keep burning out and i need another solution. if anyone has any idea where i can go or who i can ask to figure out what type of resistor to put on this think id apreciate it greatly. surly someone must have some sort of knowledge on the subject.
thanks
      11-24-2008, 08:08 PM   #24
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
thanks
Hopefully parachute will chime in on this!!
      11-24-2008, 08:16 PM   #25
joebaggg
E60
joebaggg's Avatar
2006 E90  [0.00]
he seems to be MIA. his PM box is full
      01-23-2009, 09:55 AM   #26
joebaggg
E60
joebaggg's Avatar
2006 E90  [0.00]
im still trying to figure this problem out... where is parachute!
      03-03-2009, 03:36 PM   #27
DrPowers
Drives: 2006 325i
So I'm having issues with this setup. After I plug everything in the lights (low beams and fogs) do not function at all and the car throws an error.
I've tried both assemblies on the passenger side headlight ( easier to access) and I have been unable to get them to work. With just my headlight plugged in (no error removal harness) the lights function fully but I get an error.... Whats going on here?
      03-08-2009, 04:06 PM   #28
joebaggg
E60
joebaggg's Avatar
2006 E90  [0.00]
same thing parachute is a scam just did mine today 4 hours and 180$ wasted still got an error... pm'ed him a few times in the last few months with no reply
      03-08-2009, 06:29 PM   #29
a l l a n
Drives: E90 2007 328xi
2007 E90 328xi  [0.00]
Parachute's harness works. Your issue may be one of these three: (1) the harness is defective, (2) you installed it incorrectly, or (3) your xenon wiring is incorrect or not done properly.
What error are you having? Do a "Check Control" and take a picture of the error.
E90 2007 / Step / Montego Blue / Black Dakota Leather / Premium / Cold Weather
MODS
: Exterior: Blacklines, debadged, HO ceramic 35% tint, Hoen yellow fogs, matte black grille, OEM style splitters, Halogen-to-Xenon Interior: Alum pedals, CF wrapped trim, V1 and Nuvi hardwire, M-Tech tri-stitched wheel, SMG M5 shift knob Performance: AluFelgen CSL 19" 8.5 ET33/9.5 ET30 with 5mm rear spacers | GY Eagle F1 Asym 235/265, KW V3, BMW Perf exhaust+intake
      03-08-2009, 06:50 PM   #30
joebaggg
E60
joebaggg's Avatar
2006 E90  [0.00]
hum so you got your to work? i dont have access to a camera at the moment but im getting the red warning light with a car on the lift and a few yellow warning light with a pic of a headlamp as if the bulb were blown out... they keep beeping every minute or so when i drive so its hard to ignore, im positive my wiring is correct so maybe i have a faulty harness or something... seems against the odds tho. im so frustrated with this problem im willing to sell the car and get into a new one
      03-08-2009, 11:35 PM   #31
a l l a n
Yes, mine is fine since I installed his harness a year ago. The error your describing is exactly the same error i had BEFORE I installed his error-removal harness.
MODS
      03-09-2009, 03:24 PM   #32
joebaggg
E60
joebaggg's Avatar
2006 E90  [0.00]
damn i wish i could get this problem solved so what are you thinking? faulty harness? i mean the install isnt hard at all one cable is + one is - the other goes to pin 3 and the final wire goes to the disconnected wire from pin 3. Then i put the dummy bulbs on and started her up... same errors
      03-09-2009, 05:30 PM   #33
parachute
parachute
parachute's Avatar
96
Drives: BMW 335i Coupe
2011 335i  [0.00]
2006 325i  [0.00]
did you put the dummy bulbs on the harness or the original fog harness?, they shoulg go on the original fog harness, and connect your fog lights to my harness, hope that helps.
335i Coupe - LeMans Blue
325i Sedan - Mystic Blue (Retired)
      03-09-2009, 05:42 PM   #34
joebaggg
E60
joebaggg's Avatar
2006 E90  [0.00]
you gave me the dummy bulbs so that i could bypass my foglights because i didnt want them on with the lowbeams... does it not work with the dummy bulbs?
      03-10-2009, 01:37 PM   #35
DrPowers
Drives: 2006 325i
Is it necessary to install the shutter tap when doing the wiring conversion for the headlights. I didnt do this and I am getting no low beams or fogs at all with this assembly installed. Without the assembly the low beams and fogs work but I get the warning.
      03-10-2009, 07:38 PM   #36
joebaggg
E60
joebaggg's Avatar
2006 E90  [0.00]
i have my shutter connections done, ez extra step and the high beam u get from the shutters is pretty nice. when i install my kit my lights r fully functional but i get all kinds of errors... i just drive with the radio loud so i cant hhear it . sometimes it makes me want to drive into oncomming traffic. i need help asap
      03-10-2009, 10:47 PM   #37
a l l a n
Did you use OEM pin contacts for the new wires? If not then that could possibly be one of your problems.
I also live in NJ. One of these weekends if I'm home and free I can help you look at it if you are willing to drive to my place. I may also have extra pin contacts you could use.
MODS
      03-10-2009, 11:06 PM   #38
joebaggg
E60
joebaggg's Avatar
2006 E90  [0.00]
i didnot use the oem connectors. at this point im not excluding any possibility out but wouldnt the headlights not work if my wiring wasnt making good contact? as of right now i took parachutes kit out. where are you in nj? i would be so greatful if you could get this to work id even be willing to pay you for your time!
      03-11-2009, 09:45 PM   #39
a l l a n
Not using OEM connectors won't provide solid/good contacts. I won't be surprised if this is what's causing your problems even if you did the DIY and all the connections correctly.
Unfortunately your conversion won't work error free if you don't use parachute's harness.
I'm not looking and won't accept any kind of payment. I would just help if I can. I'm not an expert though but since I did my own conversion I might have some ideas on how to identify the issue. I'm in Robbinsville NJ 08691. I might have some time next weekend.
MODS
      03-12-2009, 09:55 PM   #40
joebaggg
E60
joebaggg's Avatar
2006 E90  [0.00]
That is very nice of you I'd definatly appreciate the help and would be extreemly grateful. Do you remember how long it took you to do the install? Any sunday would be perfect for me is that a good day for you? Pm me
      04-12-2009, 10:57 PM   #41
joebaggg
E60
joebaggg's Avatar
2006 E90  [0.00]
can someone pleaseee help me correct this problem im going nuts! allan is MIA
      04-29-2009, 01:25 PM   #42
joebaggg
E60
joebaggg's Avatar
2006 E90  [0.00]
anyone??
      06-09-2009, 11:13 PM   #43
joebaggg
E60
joebaggg's Avatar
2006 E90  [0.00]
isnt there anyone that can help me get rid of my OBC error? im willing to pay$$$
