      05-11-2020, 02:48 PM   #199
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
Originally Posted by Trojanlaw View Post
Change Ambient Lighting -Dome BDC_BODY 3070 GROUP_0_FARBE_ENSEMBLE_1 orange orange, white
- Dashboard BDC_BODY4 3070 AMBIENTE_FARBE_ENSEMBLE_1_LAYER_1 orange hellrot (there are 12 colors to choose from/ blue, green, violet ect.)
- Door's BDC_BODY4 3070 AMBIENTE_FARBE_ENSEMBLE_1_LAYER_2 orange hellrot (there are 12 colors to choose from/ blue, green, violet ect.)
- Floor's BDC_BODY4 3070 AMBIENTE_FARBE_ENSEMBLE_1_LAYER_3 orange hellrot (there are 12 colors to choose from/ blue, green, violet ect.)
Ok, well, these are definitely NOT present in G-series BDC, at least not in S18A (G05, G06, G07, etc.). However, similar parameters (and many more) do exist in the RAM ECU's (000004224) 3004 and 3005 groups. If the CTGY investigation fails (or as augmentation to it), it would be worthwhile to investigate these in the RAM ECU.
      05-11-2020, 03:40 PM   #200
Xmel`
Drives: BMW X5 G05
Can anyone please confirm that back camera warning (leagal Disclaimer or something) disabling is working on G05?
I have tried to get it to kein_id.
But instead of missing it stays on all the time ((
Am on 03/2020.24. But on early sw it didn't work as well.
Is there any specific coding?
On F30 it worked fine.
Thanks
      05-12-2020, 10:06 AM   #201
yans
Drives: G05 X5 30d MSport Phytonic Blu
Originally Posted by OzJedi View Post
Please refer to cheat sheet at the start of the thread
https://g05.bimmerpost.com/forums/sh....php?t=1637597
I was able to code Comfort Plus mode by referring to this sheet.
Thank you OzJedi
      05-12-2020, 10:21 AM   #202
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Thanks
I've had the same problem from start, I can't actually get the camera disclaimer to not come on and the direct/specified coding in Bimmercode and elsewhere makes it worse. I ended up coding it to 6 seconds I believe (need to double check) and that does work and is tolerable. My car is a Canadian build.
      05-12-2020, 03:37 PM   #203
Xmel`
Drives: BMW X5 G05
Thanks
Thanks. I did the same.
I suppose it is the best variant for now.
      05-13-2020, 12:20 AM   #204
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Anyone managed to code ambience light colors?
Ok, based on much of the work done by member jaimeen77, we now know that it is, in fact, possible to code different ambient light colours! Below is one way, there may be other ways, and there is more to research and test in here beyond the basics presented.
It is FDL coding, so you need ESys with a launcher (ESysX or Launcher Pro) -- sorry, no Bimmercode at this time, not even Expert Mode. It is a little more complicated than usual as one has to fill in two tables, so I won't go into the detail here yet, but perhaps will try to organize a structure tutorial at some point. PM me if you want unstructured details earlier, but you'll have to pass a skill testing question: "What does this mean #7FFFD4 and what is its base10 value?"
In the meantime, you can use this FDL Cheat Code file to get my settings. The file is here: https://pastebin.com/tLnqZc6f and the colours and colour mappings are:
6 colours:
00 Magenta
01 Blue
02 Cyan
03 Orange
04 Red
05 Purple
11 combinations
00 Bronze/Bronze --> Cyan/Cyan
01 Bronze/White --> Cyan/Blue
02 Orange/Orange --> Orange/Orange
03 Orange/White --> Red/Orange
04 White/White --> Red/Red
05 Blue/Blue --> Blue/Blue
06 Blue/White --> Magenta/Blue
07 Green/Green --> Magenta/Magenta
08 Green/White --> Magenta/Orange
09 Lilac/Lilac --> Purple/Purple
10 Lilac/White --> Magenta/Purple
Appreciate 5
Xmel`6.50
ifr1198.00
eagle_bmw182.50
      05-13-2020, 12:56 AM   #205
jaimeen77
jaimeen77's Avatar
68
Drives: BMW 330i
In the meantime, you can use this FDL Cheat Codes file to get my settings. The file is here: https://pastebin.com/tLnqZc6f and the colours and colour mappings are:
6 colours:
00 Magenta
01 Blue
02 Cyan
03 Orange
04 Red
05 Purple
11 combinations
Oh, You mentioned me
BTW G05 has much better compare with G20 ambients...
LexxM31698.50
eagle_bmw182.50
      05-13-2020, 03:31 AM   #206
Xmel`
Drives: BMW X5 G05
Is it possible to make suspension stay
in coded mode all the time?
I have coded sport individual mode, but after night standing or some longer time it gets back to comfort position level.
Is there any other other setting for that except FesWorldmode?
      05-13-2020, 05:27 AM   #207
ifr
ifr's Avatar
United Kingdom
1198
Drives: Tesla MY LR AWD
6 colours:
00 Magenta
01 Blue
02 Cyan
03 Orange
04 Red
05 Purple
11 combinations
Great work both!
      05-13-2020, 05:47 AM   #208
ifr
ifr's Avatar
United Kingdom
1198
Have you tried changing this?
7083\FesPiaDefaultLastUserMode werte=03
      05-13-2020, 07:06 AM   #209
Xmel`
Drives: BMW X5 G05
Yes, I did so.
That's what I meant.
I have tried wert=03 sport individual
and wert=05 last user mode
But it work only for some short period.
When you step out and return back in 5 minutes. Like it has some timeout.
Any idea why it happens?
Everyone have that issue?
      05-13-2020, 09:14 AM   #210
OzJedi
Australia
107
Drives: X5 2019 40i MSport Carb Black
6 colours:
00 Magenta
01 Blue
02 Cyan
03 Orange
04 Red
05 Purple
11 combinations
Great work!! So its using hexadecimal triplets for color coding.
      05-13-2020, 09:21 AM   #211
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
6 colours:
00 Magenta
01 Blue
02 Cyan
03 Orange
04 Red
05 Purple
11 combinations
Yes, RGB, 6 sets. That's the easy part. The tricky parts are that the table seems to have 1 byte 00 prefix (start), 1 byte FF suffix (end) which causes it to be misaligned unless taken into account, each colour entry appears to be 3x(x,y,R,G,B) but x,y meaning is unknown (to me) and only the first of the 3 does anything on G05/G06, and then there are several entries beyond the 6 colours that appear to be "junk DNA", but probably not actually useless (unknown). Like I said, a little more complicated.
The combinations table is trivial. Just 11x(a,b) entries where a,b are a set of 2 colour indexes from the colour table in order of listed combinations in the UI. First colour is index 0.
OzJedi107.00
      05-13-2020, 09:30 AM   #212
ifr
ifr's Avatar
United Kingdom
1198
Yes, I did so.
You mentioned fesworldmode not FesPiaDefaultLastUserMode?
      05-13-2020, 09:37 AM   #213
ifr
ifr's Avatar
United Kingdom
1198
Just coded it. Car now starts in Sport Individual mode.
I let the car sleep and unlocked and checked and still in SI mode.
Will leave it half hour or so and see what happens...
Edit: just checked over 30 mins later and still showing Sport Individual startup.
Coding it back to adaptive
Xmel`6.50
      05-13-2020, 12:10 PM   #214
Xmel`
Drives: BMW X5 G05
Yes, I did so.
It was a mistake. Sorry.
      05-13-2020, 12:15 PM   #215
Xmel`
Drives: BMW X5 G05
I have checked the wert. It is correct.
Mode SI
When I park car for a night it just gets back to comfort level.
When I start the engine it gets back to the coded parameter SI.
      05-13-2020, 12:44 PM   #216
tvasica
Drives: BMW G05 M50D
Originally Posted by lexxm3 View Post
Originally Posted by ozjedi View Post
anyone managed to code ambience light colors?
ok, based on much of the work done by member jaimeen77, we now know that it is, in fact, possible to code different ambient light colours! Below is one way, there may be other ways, and there is more to research and test in here beyond the basics presented.
It is fdl coding, so you need esys with a launcher (esysx or launcher pro) -- sorry, no bimmercode at this time, not even expert mode. It is a little more complicated than usual as one has to fill in two tables, so i won't go into the detail here yet, but perhaps will try to organize a structure tutorial at some point. Pm me if you want unstructured details earlier, but you'll have to pass a skill testing question: "what does this mean #7fffd4 and what is its base10 value?"
in the meantime, you can use this fdl cheat code file to get my settings. The file is here: https://pastebin.com/tlnqzc6f and the colours and colour mappings are:
6 colours:
00 magenta
01 blue
02 cyan
03 orange
04 red
05 purple
11 combinations
00 bronze/bronze --> cyan/cyan
01 bronze/white --> cyan/blue
02 orange/orange --> orange/orange
03 orange/white --> red/orange
04 white/white --> red/red
05 blue/blue --> blue/blue
06 blue/white --> magenta/blue
07 green/green --> magenta/magenta
08 green/white --> magenta/orange
09 lilac/lilac --> purple/purple
10 lilac/white --> magenta/purple
6 colours:
00 magenta
01 blue
02 cyan
03 orange
04 red
05 purple
11 combinations
      05-13-2020, 03:37 PM   #217
ifr
ifr's Avatar
United Kingdom
1198
Mode SI
Maybe a profile issue?
Have you tried with say A0 (adaptive), same issue?
      05-13-2020, 06:11 PM   #218
Xmel`
Drives: BMW X5 G05
Mode SI
Mode SI
Yes. I have tried it. But adaptive (A0)
has the same level of suspension as comfort. So it won't be visible.
And not only that mode. Sport individual/sport, wert=05 that saves the last mode and others. Same issue ((
The problem is that the car do not save the level for a long time.
It starts the mode you have coded but only after start of an engine. When you com to car it has its normal level of air suspension.
And I've noticed one more thing. When I just stop the car and go away it can stay low for a short period of time. But when I park it using rear speed it gets higher to base/comfort level when I just step out of the car.
Is it possible that
FesAktivPWF can be in play?
      05-14-2020, 02:16 AM   #219
ifr
ifr's Avatar
United Kingdom
1198
Is it possible that
I'm not sure we are talking about the same thing.
When I set a driving mode in coding, such as Adaptive, it sticks and that's all that is ever displayed in the CiC/KOMBI.
If yours is changing back to Comfort, then no that is not normal behaviour, when changing the FesPiaDefaultLastUserMode code
      05-14-2020, 09:26 AM   #220
Xmel`
Drives: BMW X5 G05
Is it possible that
I mean that no mater what coding I have done the level of air suspension returns to its normal position (equal to comfort mode) when I lock the car.
If I code SI and choose the suspension to run in sport mode it should stay one level lower than in comfort mode.
First I thought it was because of some conflict with DME, that wasn't set to remember last position of start/stop.
But coding it didn't help as well((
So that's why I thought that some other parameter can affect its behaviour.
Anyway thanks for your help.
Do you have air suspension on your car? If you could code some sport individual/sport/sport plus mode and leave it for a night it would be great.
