      12-01-2023, 08:54 AM   #1
maurinan
Drives: 2017 BMW X5 E40
xDrive transmission & tire rotation
Hi,
I recently got a 2022 x5 e45 (I had a x5 2017 before this one). The tires on the front have more thread than the ones in the rear.
My question is: does the xDrive transmission always provides 50/50 traction front/rear or it does something different (and maybe more adaptive)?
Basically I am wondering what I should expect in terms tires wear between front and rear moving forward and how I should go about it in terms of rotating these tires.
Thanks you all in advance!
      12-01-2023, 09:01 AM   #2
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
Originally Posted by maurinan View Post
Hi,
iDrive system in the 45e has 40:60 rear: front bias during normal driving and will dynamically change depending on road conditions
You didn’t mention wheel size. square or staggered setup?
      12-01-2023, 10:22 AM   #3
eelnoraa
Drives: G05 X5
Rear tires wear faster is normal for
RWD base car. Especially 45e type of car, that 700ish lb battery is mainly in rear axial. Traction is really a function of grip of the tires. When you out more weight on a axial or weight shift to that axial, that axial has more traction. Tires natural faster there.
As for rotation, I think if possible , it is always a good idea. So yes, do you have stagger or square setup?
2022 G05 B58/PHEV
+ a few very old BMWs
      12-16-2023, 04:27 PM   #4
maurinan
Sorry for the late reply. I have 20inch tires, I have a square setup (all tires are the same). Thank you for your replies!
