BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > Private Sellers - For Sale / Trade / Wanted > Misc. Automotive Items
      08-20-2023, 05:51 PM   #1
TNTMYM3
Drives: 2011 BMW e90 M3
WTS Voltfreaks 12v Lightweight Lithium Battery VPR-P6
BIMMERPOST / Classifieds
Asking Price:
Sold
Item Interest
Going back to semi-stock on some items, used this to swap my oem battery for weight reduction on my BMW e90 M3. Includes aluminum “Odyssey” brand aluminum mount kit for perfect fitment and also the 20’ push button switch wire extension kit.
Voltphreaks racing batteries are lightweight 12v batteries for sports cars, street cars, track cars, or race cars. They can be used anytime you desire to save weight with a lighter battery. The VPR-P6 is designed for users that want the best capacity/power versus weight combination. When you need the absolute smallest/lightest battery with a great performance/weight ratio, this is it.
Advantages:
1. Weight, much lighter than a comparable lead-acid battery.
2. Mountable in any orientation.
3. Can be “deep cycled”, meaning fully discharged, while protected from damage by the LVC.
4. Has an LVC (Low Voltage Cutoff) to prevent overdischarge. This turns off the battery before it is over-discharged to prevent damage to the battery. It may also allow you to still start your car if it’s parked long time (ex: 3 week vacation, etc).
5. Has fault protection circuitry to protect your battery, preventing damage from overcharge, etc.
6. Maintains higher voltage and charges more efficiently (can result in better MPG).
7. Circuitry allows charging/discharging at high rates, compatible with car alternators.
8. True physical disconnect of battery via an internal bi-stable hd relay. This allows battery to be used with cars that have sensitive electronics that require a direct battery connection.
9. Optional remote pushbutton can be used when battery is not accessible without electric power.
10. Designed and made in the USA. Tested, proven, and continuously improved for over 10 years.
Battery Specifications: VPR-P6
Nominal Voltage–12 volts
Cranking Amps (CA) –900 amps
Cold Cranking Amps (CCA) –500 amps
Capacity –31 Ah
Reserve Capacity (RC) –38 minutes
Dimensions –7.3″ x 3.1″ x 6.7″
Weight–6.25 pounds
https://hyperaktive.com/product/volt...eight-battery/
      08-30-2023, 11:48 PM   #2
TNTMYM3
Bump
      10-04-2023, 06:43 PM   #3
danvitmon
Drives: 2008 E90 M3 6spd
What's the longest you've had the car sit with this battery and the car still start ok? I understand it has a lvc but still wondering how long you could let the car sit without needing a charger or for the battery to enter lvc.
      10-04-2023, 10:05 PM   #4
TNTMYM3
About 8 days and the battery will enter lvc, the battery lvc is a great feature prevents full discharge and always leaves enough juice to start once reset/power switch is engaged. The reset/power switch extender is included and can be extended wherever convenient.
      11-02-2023, 11:11 AM   #5
TNTMYM3
Bump
      11-07-2023, 05:25 PM   #6
MLTD9192
Drives: 2011 potholed 335d
If you still have this next month, I may consider buying this from you. Im just buying a ton of xmas presents this month lol
      11-25-2023, 01:22 PM   #7
TNTMYM3
Bump still available
      01-16-2024, 02:50 PM   #8
mcp
Drives: 09 335xi (e92)
Was this on a daily or a track car? Wondering if a ultra lightweight can handle the occasional stop and go high load in the winter (heated seats, wipers, radio + ?) or if I should be considering a larger capacity lithium battery.
Tags
lightweight, lithium battery, voltfreaks, vpr-p6
m3post
