02-01-2024, 04:27 PM | #1 |
Rep 1,073
Unable to Remote Start, Remote Camera, Remote Unlock
I was unable to Remote Start, Remote Camera, Remote Unlock and wanted to post the solution in case someone else has this problem.
Digital key worked and the trip data was updated correctly in the app and online. The error I was getting was different based on what I was trying to do remotely. Remote start error - "Something went wrong, the following restrictions prohibit the execution of remote services. For safety reasons remote services are unavailable when in drive-ready mode. Remote services can only be executed when the battery is sufficiently charged. The Lock and Unlock remote services can only be executed when the driver's door is closed, and the door status is known." Remote Lock and Unlock error - "The country you are in prohibits the use of this connected service." Remote Camera error - "The country you are in prohibits the use of this connected service." The fix was to do the triple reboot while holding the volume button while parked. I tried while driving and that did not work. You hold the volume button down for about 90 seconds and don't let go until the system reboots 3 times and the ok prompt comes up on the 3rd reboot. That does a telematic reboot. Hope this helps anyone else having this issue and the battery is not the issue. |
02-07-2024, 11:27 AM | #4 |
13271
Rep 19,795
02-07-2024, 11:39 AM | #5 |
Rep 8,698
Drives: eVeRyOnE mAD!
OP said it didn’t work while driving, only when parked, but like Turtle said, it shouldn’t matter. I’ve done telematics reboots both while driving and parked (and with both engine on or off while parked). you just get better visual feedback of the reboots when engine is on (driving or parked), thus a potentially higher chance of performing it correctly
sledman1.50 |
02-07-2024, 12:36 PM | #7 |
Rep 1,073
02-07-2024, 12:37 PM | #8 | |
Rep 1,073
sledman1.50 |
02-09-2024, 08:18 AM | #11 |
Rep 2,858
Had this same issue with engine remote start not working after I picked up a '24 X5 M60, the telematic reboot solved the issue. Thank you for this thread.
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
TechCTU768.50 |
