04-07-2024, 06:47 AM | #1 |
Rep 13
Stains "in" paint
Hey guys,
I recently acquired a beautiful BMW m235i f22 in estoril blue in great conditions but unfortunately it has a couple "stains" on the hood. (See attached pictures) At first I thought it was just dirt but after giving it a good wash, I noticed that it was "inside" the paint and can't get it off. Tried to polish it but it didn't help much. Any ideas what it could be and if there's a way to fix it without having to repaint the whole hood? Thanks in advance for your help! |
04-07-2024, 10:18 AM | #2 |
1154
Rep 1,543
Can't tell from the pix but have you tried a tar remover (weird spot for it) or clay bar? If it is just surface contamination of the clear coat, the clay should take care of it.
- Jeff
bosstones' flickr |
tracer bullet2472.50 barbuse2.50 |
04-07-2024, 11:02 AM | #3 |
Rep 3,598
Agreed, clay bar or maybe some fine polish next, you might take care of it yourself. Be sure to "wax" it with whatever paint protector is your preference.
04-07-2024, 03:04 PM | #4 |
Rep 1,235
Well that's interesting, not sure I have seen that before. Let us know what you end up doing.
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (car-show car) |
04-07-2024, 03:20 PM | #5 | |
425
Rep 366
barbuse2.50 |
04-08-2024, 02:33 AM | #6 | |
Rep 13
Thanks for your replies guys!
So I guess I'll try with the clay but I'm pretty nood in that area, never used it. From what I saw, there are synthetic and natural clay bars, any thoughts on which one to take? From my understanding, I also need a clay lube. Any specific product to suggest? Quote:
Thanks again for your help! |
04-08-2024, 07:38 AM | #7 |
Rep 3,598
I wouldn't worry about what type of clay you use. Look for a kit perhaps in a local auto parts store. Meguiars is all over the place for example. It'll have everything you need. Plus you might end up doing more of the vehicle some day as well.
Paint sealants, wow, so many options. If you're not up for a ton of work then perhaps a ceramic in a spray bottle, something low percent that sprays on and wipes off. Grab a couple soft microfiber towels to go with it. |
barbuse2.50 |
04-08-2024, 01:49 PM | #8 | ||
41
Rep 46
Drives: '15 535i xDrive M-Sport, E30
Also- I've used plenty of traditional clay bars over the years and I just love the new synthetic clay mitts. Grab a cheap-o off amazon. Best part of the synthetic products is they aren't garbage if you accidently drop them. Lubrication requirements are the same for each. Quote:
Edit: you are in Switzerland so I’m likely wrong on local products! Last edited by s_ribs; 04-08-2024 at 09:28 PM.. |
04-11-2024, 07:23 AM | #9 | |
Rep 13
Thanks guys for your answers and for helping the noob that I am!
Any thoughts on which one would be more suitable for my particular problem? Do you think I also need a more coarse clay as the stains look pretty deep? |
04-11-2024, 07:33 AM | #10 |
41
Rep 46
Either of those kits will work. The first link will likely be a better value, but like I said, I prefer the new synthetic clay products as they work great and are easier to use.
Always start mild and go more aggressive only if required (for any car cleaning). If you do need a course clay bar then you will also need polish as they do mar the paint. Most standard stores won't carry anything but regular/mild clay so you will likely need to order it. Try the regular/mild version first. |
04-11-2024, 08:05 AM | #11 |
Rep 3,598
^^^ Agreed. I'd also go w/t he first kit. The other has a bit of ceramic added and that's OK but I'd rather keep that as a separate thing, filed under "wax" even though it's not wax, that being more of a generic term nowadays.
If the clay doesn't do it, I'd go to a liquid polish, something with a tiny bit of fine abrasive in it. The clay isn't a waste of money, you could go over the whole car with it at a later time. The polish is fairly specific so buy as little as you can, if it gets to that point. And I guess you could also just jump straight to it, the really fine polishes won't leave scratches behind. The clay should clean the surface of the paint, specifically the clear coat. The polish will begin to slowly remove the clear coat, hopefully taking the stain with it. So you don't want to over-do this one. |
04-11-2024, 08:55 AM | #12 | |
Rep 13
However, as stated in my first post, I already tried liquid polish at a local shop. It helped a little bit but the guy there suggested not over doing it otherwise it would be more visible than the actual stains. So is it even worth trying the clay? As for the sealant/protective layer, would that be good? https://www.meguiars.com/index.php/a...n-easy-use-wax |
04-11-2024, 09:55 AM | #13 | |
41
Rep 46
barbuse2.50 |
04-11-2024, 09:59 AM | #14 | |
41
Rep 46
OP- since you're new to this using a clay bar on your entire car (paint AND glass) is a) good maintenance, and b) proper procedure prior to applying an LSP (last step protection, i.e. wax/sealant/coating). It will clean imperfections from your paint that you didn't know were there. |
barbuse2.50 |
04-11-2024, 10:09 AM | #15 | |
Rep 3,598
An aggressive polish (compound) will indeed scratch the finish, it'll be hazy looking afterwards and ugly. But the process is done in steps, where the next step uses a less aggressive formulation, and it can even be done a 3rd time, ending up where you finally see no scratching / hazing at all. At which point you are done and apply a wax of your choice (ceramic, polymer, etc.). So a more aggressive formulation could do it, I tend to call them rubbing "compounds". Then followed up with "polishing" to remove the haze form the previous step. If that hasn't been done, you could try it. If it was already done, then - you might indeed decide to live with it or yes, truly get to work with a shop that either repaints it or hits it so hard they remove the clear coat altogether, hopefully taking the stain with it, and then following that up with a new layer of clear coat. |
barbuse2.50 |
04-11-2024, 10:18 AM | #16 | |
Rep 13
04-11-2024, 10:30 AM | #17 | |
Rep 13
But it was done at a "normal" garage so I guess I could go to a detailling professional and see if they can do anything. Anyways I'm gonna buy the clay and some wax for the rest of the car. |
s_ribs40.50 |
04-11-2024, 10:34 AM | #18 | |
41
Rep 46
Glaco isn't widely available here but they have some consumer grade products that also seem good. Beyond these two you're getting into much more specific and "enthusiast" level products (CarPro and Gyeon as an example, great stuff). Go for that if you are interested but this will be a much different discussion then. |
barbuse2.50 |
