      06-05-2020, 05:09 AM   #1167
Rmtt
Rmtt's Avatar
Drives: 2011 BMW 128i, 2008 LS3 C6
Also let's talk volume for those that hear it...but not quite sure baout it.
A stock can go from $2 to $20.......but volume determines how long it takes to get there. It's affected by Market Cap, Float, etc. Below is an example.
When you see a stock with low float which means they aren't that many public shares available, if there is a catalyst....the volume of people trying to get in goes up dramatically and those shares are worth far more than if a company has a ton of shares out there to buy.
Dilution is an enemy of the float. When it's time to sell...you want people clamoring to get what you own.
You could have a stock worth $100....but if no one is buying you just have a stock worth $100.
That is where you get into Level 2 Charts. I highly recommend looking at those and learning how they work. They let you know what the bid/ask is going for.
In my example below..you will see bid on the left and ask on the right. This is Xspa. This is something you should always consult if buying something that is "hot" as it allows you to see resistance, volume, and what the "spread" is. Volume right now is light. Yesterday it was over 100 million. It will ramp up again like crazy.
Volume is how you set up scanners to alert you that something is going on.
Everybody has a gameplan....until they get punched in the mouth.
Appreciate 4
Nuckle2228.50
E92inNC1712.50
clutchdj1886.50
      06-05-2020, 05:55 AM   #1168
Rmtt
Rmtt's Avatar
Also keep in mind....Fridays are typically "sell-off" days in the market!
So don't be swayed if you see your holdings drop some. It's always been like this!
Appreciate 4
Nuckle2228.50
E92inNC1712.50
clutchdj1886.50
      06-05-2020, 06:12 AM   #1169
SwaledaleDubz
Drives: Bmw 320D Lci
Meggit now at £3.71 up 9.47% today woopwoop
Ps anyone interested in an interesting penny share check out Kefi Minerals Plc an interesting punt with a bit of grunt behind it potentially.
Nuckle2228.50
      06-05-2020, 07:04 AM   #1170
Rmtt
Rmtt's Avatar
CDEV is another one that COULD break out. It's at 1.23...but if it hits 1.40...things could get interesting! Volume is slowly building. Almost 175K this morning.
Nuckle2228.50
      06-05-2020, 07:08 AM   #1171
Rmtt
Rmtt's Avatar
Also ACHV is primed to run. Just don't chase it!
If you can get in at a dip at .45 or less...you are good.
Nuckle2228.50
E92inNC1712.50
      06-05-2020, 07:15 AM   #1172
Rmtt
Rmtt's Avatar
Also for others looking for a solid group that pays dividends.....check out GEO and do your research.
Nuckle2228.50
      06-05-2020, 07:34 AM   #1173
Rmtt
Rmtt's Avatar
XpresSpa Group Signs Contract with HyperPointe™ for Airport-based COVID-19 Screening andTesting
https://investors.xpresspa.com/node/12311/pdf
Appreciate 5
tnsatbhs120.00
Nuckle2228.50
Run Silent15129.00
E92inNC1712.50
      06-05-2020, 08:05 AM   #1174
tnsatbhs
tnsatbhs's Avatar
Drives: 2020 BMW M340i xDrive
Good news there! Sounds like more to come as they announce new locations!
Rmtt8222.00
      06-05-2020, 09:25 AM   #1175
Rmtt
Rmtt's Avatar
Originally Posted by Nuckle View Post
Got in BIOL at .50 thanks!
BIOL starting to wake up....and on a Friday at that!
Nuckle2228.50
      06-05-2020, 09:26 AM   #1176
Nuckle
Drives: 2023 Defender X
Was just seeing that. Got a bailout number in mind?
      06-05-2020, 09:28 AM   #1177
Masterplan
Masterplan's Avatar
124
Drives: F87 M2 & G05 X5
Been keeping an eye on LK Luckin Coffee.
What's everyones thoughts?
      06-05-2020, 09:30 AM   #1178
Rmtt
Rmtt's Avatar
That was a buy-in earlier. I would tread carefully with that one as there are some variables that could swing it either way.
      06-05-2020, 09:32 AM   #1179
Rmtt
Rmtt's Avatar
Between .90 and a 1.00.
Now it may not hit that today...but it's worth that amount!
But remember...."green is green".
      06-05-2020, 09:34 AM   #1180
Masterplan
Masterplan's Avatar
124
I'm aware of its troubled past and the issues that may continue to haunt it. Seemed like Ive missed the boat on that one.
      06-05-2020, 09:35 AM   #1181
dreamingat30fps
Drives: Miata, Cayenne, Model 3, F350
Just saw VISL hit .80s for a bit
      06-05-2020, 09:40 AM   #1182
Rmtt
Rmtt's Avatar
Don't worry about it...there will be more that come along!
      06-05-2020, 09:54 AM   #1183
premier3is
premier3is's Avatar
1638
Drives: 2019 BMW 330i M-Sport
Too late to enter BA now too for long term. Damn. Would've made a killing on all airline stocks.
Rmtt8222.00
      06-05-2020, 10:01 AM   #1184
Nuckle
It's about to! It got to .78.
      06-05-2020, 10:09 AM   #1185
E92inNC
E92inNC's Avatar
1713
Drives: E92 335i
I’m in at 1.25. When I saw it falling off I doubled down for .90 but didn’t fill. Bummed I missed out.
      06-05-2020, 10:12 AM   #1186
Rmtt
Rmtt's Avatar
CHFS....I think we could see a Buck next week sometime. It;s at .49 last I looked...so double your money anyone?
Again....do your own research. I don't want anyone to lose. However...I did buy in.
      06-05-2020, 10:17 AM   #1187
Rmtt
Rmtt's Avatar
Yeah, being a Covid play it will go up and down. It will eventually get up there when people realize what's happening. Right now it like the movie where the dog yells "Squirrel".
But if you got in at .50....I could see taking .75 next time it comes around so you can play something else.
These things run in 1 month cycles...a lot of swing traders.
Another big one that my friend has been in for months. Ship.
Buys in around .12 for like a 100K shares...then sells at .18 within a day. It has made that same run for the last 5-6 months about once per month.
That's how day traders kill it.
      06-05-2020, 10:26 AM   #1188
Rmtt
Rmtt's Avatar
So I get in at .49....now it shot up to .55 and then back down to .52.
Still holding for more though!!!!
