01-22-2024, 02:05 AM | #1 |
Rep 3
Will 1.9% tire diameter difference harm the xDrive system?
The original tire size of my G05 X5 is:
Front: 275/45 R20 with 9J hub Rear: 305/40 R20 with 10.5J hub The tires needed to be replaced after 50,000 km. My friend happened to buy a new Porsche Cayenne at the time, with a tire size of: Front: 255/55 R20 with 9J hub Rear: 295/45 R20 with 10.5J hub He changed R22 hubs and gave the brand new ex-factory tires to me, then I installed them on my X5 because they have same hub size. Now after calculation, I found the Cayenne tires have a 1.9% diameter difference between the front/rear. However, I already used them for 5,000 km with no errors yet. Will this 1.9% difference harm the xDrive system? If so, how can Porsche design such big difference of the Cayenne tires? Thanks! |
01-23-2024, 09:06 PM | #4 |
Rep 208
The Cayenne may have a different type of a transfer case that is more forgiving to size deviation. I would absolutely not put on tires that are 1.9% off onto an X5.
01-24-2024, 09:23 AM | #5 |
Rep 8,835
Considering some people have the transfercase fail bone stock I would NOT risk it. The dealer would not cover it the moment they look at your tire size.
01-24-2024, 11:54 AM | #6 |
Rep 8,865
Drives: eVeRyOnE mAD!
I echo others’ statements. 1.9% difference between front/rear is too large for the BMW xDrive transfer case. your setup will very likely void any warranty claim related to the system
01-24-2024, 12:35 PM | #7 |
Rep 3,744
I agree as well. Not worth the risk. I think the largest front vs rear difference in X5 family is X5m 21/22 setup
295/35R21 315/30R22 The difference is only 1%. So maybe this is a good reference
2022 G05 B58/PHEV
+ a few very old BMWs |
01-25-2024, 03:49 PM | #8 | |
1021
Rep 1,521
PS: At least for as long as this thing is under warranty
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (show car) |
01-25-2024, 07:37 PM | #9 |
Rep 27
A little bit of a thread hijack but can you increase the side wall height by 5mm (so 10mm overall on diameter).
I'm on stock UK model with 22" Front: 275/35 R22 Rear: 315/30 R22 Is it reasonable to go to Front: 275/40 R22 Rear: 315/35 R22 In the UK there just seems to be more tyre choice when you search on tyres with the deeper side profile. Last edited by 5wany; 01-25-2024 at 07:44 PM.. |
01-26-2024, 04:35 PM | #10 | |
Rep 208
01-26-2024, 10:38 PM | #11 |
Rep 415
01-28-2024, 08:13 PM | #12 |
Rep 208
02-28-2024, 07:59 AM | #14 |
47
Rep 48
I have an X5M with 808M wheels from the factory with 295/35/21 front and 315/35/21 rear. Per my calculations that’s a 14mm difference, close to 1.9%. Is this ruining my transfer case?
02-28-2024, 08:27 AM | #15 | |
Rep 8,865
you may want to seek clarification in the F95/F96 sub forum |
