05-08-2018, 04:49 PM | #1 |
Space Force - 4 Star General
11463
Rep 3,264
Garage Door Opener Recommendations?
Does anyone have any recommendations on garage door openers? I currently have 2 Chamberlain “Ultra Quiet” or some BS marketing term like that. They are belt drive and are “smart” meaning I can hook them up to the Chamberlain IQ app and hub to remotely monitor and actuate them. I’m looking to replace both of them, even though they are barely 5 years old. My gripes:
1) They periodically open/close on their own. I’ve come home to an open garage door that I know I closed. I’ve been home alone and heard the garage door open, run downstairs to find it either open or in the process of closing back down. 2) The IQ wifi “smart” hub is garbage. Loses contact with the router. Stopped working entirely with one of the openers. Produced 20 to 30 false alarm alerts per day of the door opening. I want a simple, reliable opener that’s quiet and dependable. Both my doors are modern, metal doors, that are well balanced and pretty light. I don’t need a massively powerful motor. The wifi connectivity is a nice feature but not a must. Seems I have Genie, Chamberlain, and Craftsman to choose from. Any other brands out there that are worth looking at? |
05-08-2018, 05:10 PM | #2 |
douchebaggo
186
Rep 972
Isn't the MyQ hub a separate module? Sounds like the issue is not the opener but is with the MyQ hub. Why not try removing the MyQ hub and see if the random opening/closing continues? They are most likely simple and reliable without the MyQ hubs.
DETRoadster11462.50 |
05-08-2018, 05:19 PM | #3 | |
11463
Rep 3,264
Yeah, that MyQ hub stopped working with one opener about 6 months after I bought it. It still works with the other door, but, it gives dozens of false alerts each day. I unplugged it last summer. The phantom openings / closing continue, mainly in the summer months. So far it's only on my wife's side of the garage. Something is heating up and short circuiting, I suspect. I discovered that the door actuation panels on the garage wall function via completing a simple circuit. Two wires run from the opener to the button/panel on the wall. If you electrically connect those two wires, the door opens. After discovering this, I ran all new wires from the openers down to the buttons on the garage wall, thinking I might have put a staple through one of them, causing a short that shows up when the garage heats up and things expand. Bottom line I just dont trust the openers anymore. |
05-08-2018, 05:28 PM | #4 |
Rep 3,988
While still owned by Chamberlain, my side mount LiftMaster 8500 has been great, MyQ is not built in but I have the gateway.
I got it because I needed the room to fit my lift in the garage, but noticed it’s quieter than any belt driven unit I’ve ever heard, all you hear is the door making noise, has to lube everything up and it’s super quiet. Because it connects directly to the shalf, there are less moving parts. MyQ has never given me issues with it, never had any false opens in over 2+ years so far. My unit is hardwired to my router so maybe that is why. |
05-08-2018, 05:34 PM | #5 | |
Rep 3,988
MyQ 2.0 units might be more reliable, not sure about all the technical details but I think it’s more secure. It also doesn’t work with HomeLink in my M3 anymore because the M3 system is older. |
05-08-2018, 05:38 PM | #6 | |
34185
Rep 11,637
Drives: 2015 BMW i8, E63 M6, 328d
Good luck and let us know what you decide to purchase.
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion. |
05-08-2018, 05:44 PM | #7 |
douchebaggo
186
Rep 972
I've read a lot of the 'pros' prefer Chamberlain/Liftmaster. But I have personally installed and used 6 garage openers, both Chamberlain and Genie, and never had problem with any of them. I prefer Genie but only because of the smaller remotes.
You might want to research Sommer openers. Made in Germany and have lifetime warranty. I didn't go that route because I like having parts readily available at local stores. |
05-08-2018, 05:47 PM | #8 |
1341
Rep 1,881
i worked for 2 years as a commercial garage door contractor. We installed MANY LIFTMASTER belt drive openers. The problem with these is not in the design, but in the installation. This is true with ALL openers. Also there is a huge difference between the models that are for sale in retail stores, VS the models that contractors buy from the supplier. The retail openers are garbage. The rails are not 1pc, and are a huge weak point. Then there is installation, most people can install and make it work, but will it function reliably long term?
Also the wall mounted openers are only as good as the wall they are mounted to. I have seen countless examples where the wall mount is mounted into sheet rock, and while i may have lasted a year or so, it will fail. they must be mounted to studs. General contractors are notorious for installing garage door openers incorrectly, i have cleaned up dozens of faulty contractor installs. My advice is to find a reputable garage door specific contractor in your area, and have them come out to either tweak the current installed opener, or recommend a better suited model for your application. Make sure they warranty their work, so if you have issues you can rely on them to make it right. |
05-09-2018, 08:21 AM | #10 |
Rep 3,032
I'd pay a lot of attention to button pad, avoid anything with virtual buttons or soft buttons. Virtual or flush you know will fuck up and the soft ones give no tactile feedback and i have had huge issue with them not working in the winter.
OT but in general i find buttons, on anything from a toaster to a remote, absolute shit with a few exceptions. The Amazon fire stick buttons are excellent, a hard "click" ... you know it worked ... most are shite. |
05-09-2018, 08:26 AM | #11 | |
11463
Rep 3,264
11-29-2018, 03:12 AM | #13 |
Rep 1
I don't like my Liftmaster 8500s. They are slow and the remote reception is very limited. To use the openers with my GM cars I had to buy an additional repeater to translate from one system to the Liftmaster.
I wanted to get their remote door monitors. No problem for the 8500 and they told me the MY-Q Garage would adapt the monitor to my Genie. Wrong and that was about $90 wasted. I had a problem with one of the lights. A call was handled quickly and professionally and a new light kit was in the mail, no proof of purchase or returning of the old light needed. I love my Genie Xlerator like this https://mechanicguides.com/best-garage-door-rollers/ - fast and quiet. Lifetime warranty on the whole thing. |
11-29-2018, 11:51 AM | #14 |
Rep 611
Drives: ‘18 M240i, Estoril Blue
In three years of heavy use, I've never had a single problem with my Chamberlain system (same model/setup as the OP), including zero MyQ connectivity or operational faults. Really like the setup.
—Steve
'19 MX-5 Miata GT-S soft top Past BMWs: two '57 Isetta 300s, '70 1600, '72 Bavaria, '78 320i, '18 M240i |
05-08-2019, 10:28 AM | #16 |
I'll get back to you
7560
Rep 2,132
so my "Overhead Door" garage door openers are almost 30 years old, had them serviced once since i've owned the house. they work great but its time for an update. the boys are getting older and i want them to be able to use a key pad to open the doors and my system is just too old. i had overhead door come by to give me an estimate. $795 installed tax included for two units, outdoor keypad and inside the garage pad. oh and 2 remotes. i looked on Lowes website and their comparable units installed was approximately the same price. thoughts?
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
05-08-2019, 10:37 AM | #17 | |
11463
Rep 3,264
I've always installed these myself. The first one will take you about 3 hours. The second one will take about 1 hour. Lol. So start at 8, your done by noon, and you can go enjoy your $400. If you decide to have it professionally installed I'd go with a local company. I NEVER use Lowe's of Home Depot for any installs as they simply contract out and you have no control over who shows up at your place. |
05-08-2019, 10:44 AM | #18 | |
7560
Rep 2,132
Overhead Door is a national brand but they have a local office here
2018 Stinger GT
05-09-2019, 02:14 PM | #20 | |
Space Shuttle Door Gunner
6430
Rep 5,309
upstatedoc7559.50 |
