06-29-2020, 10:26 AM | #1 |
Rep 444
Gear indicator
Am i missing a setting that will show me which gear the car is in, I had one on my last motor which I found useful. And whilst I'm here, why is the fuel computer so awkward to bring up
06-29-2020, 10:37 AM | #2 |
Rep 108
Do you see something here when you switch over to M/S? Perhaps I misunderstood.
Last edited by phillydilles; 06-29-2020 at 10:57 AM.. Reason: Added better pics, albeit apparently horizontal |
06-29-2020, 11:19 AM | #3 |
Rep 2,609
Not every dash layout under every drive mode with every selected right side display shows the current gear. The M dash layouts and Sport displays seem to be reaching infamous status in assuming "performance" driver don't care about the gear. Try other layouts and/or other driving modes, it's the simplest way to learn what does and what doesn't show. Incidentally, the poster above me shows the Alpina dash (coded), which I assert is the best dash for G05 X5 for this and many other reasons.
The answer to the other question/complain is similar. That is ... BMW, "pedantic" common pattern of German UI mentality, general and highly common UX design incompetence ...
Addbuyer826.50 |
06-29-2020, 12:00 PM | #4 | |
Rep 444
phillydilles74.00 |
06-29-2020, 12:02 PM | #5 |
Rep 444
06-29-2020, 12:17 PM | #6 |
Rep 457
Really annoys me on my M50i that the M
HUD doesn’t show the gear like it did in my M4. Not really an issue when in auto but when manual shifting it’s a PITA having to look down at the dash. The new HUD is superb but for the M setting not really adding anything of value. |
06-29-2020, 12:23 PM | #7 |
Rep 444
06-29-2020, 01:04 PM | #8 |
Rep 289
In manual mode you need to have an idea what gear you are in so that you know what you are going to shift to for whatever the required situation is. If the box is on full auto it's going to decide for you whether you can see the gear number or not, so does it really make that much difference? I can't imagine you would be that bothered if it was in 5th instead of 6th, or 6th instead of 7th, the shift is so smooth anyway...
2014 X5 35i Sophistograu A90 (Dark Graphite) Terra Dakota
Eibach Pro Kit & Lowering Links, RC GTS Black 2014 M135i 3dr |
phillydilles74.00 |
06-29-2020, 01:16 PM | #9 | |
Rep 108
While on the subject of missing usual dash info - there's no way to always show the current mileage odometer reading, is there? |
06-29-2020, 01:26 PM | #10 | |
Rep 444
phillydilles74.00 |
06-29-2020, 01:39 PM | #11 |
Rep 457
06-29-2020, 02:13 PM | #12 | |
798
Rep 1,786
phillydilles74.00 |
06-29-2020, 02:19 PM | #13 |
Rep 1,386
Drives: 2023 iX xDrive50 & 2020 M850i
Funny because I've driven manual transmissions most of my life and only switched to automatics when BMW stopped offering them on the 5-series. Never, did I ever think about what specific gear I was in much less while driving an automatic. My gear selection was always dependent on feedback from the engine and driving conditions. Sure, subconsciously I knew but I didn't need an indicator to tell me I was in the wrong gear.
That said, flip the shifter to manual and tap a paddle and the dash will give you an indicator of the gear. |
06-29-2020, 03:23 PM | #15 | ||
Rep 127
06-29-2020, 03:58 PM | #16 |
Rep 4,246
BimmerCode app to display ALPINA display layout
06-29-2020, 04:31 PM | #18 |
Rep 444
Guys as we have moved a little sideways, gear indication to mileage, I will throw another niggle into the mix. Does anyone use KW when talking about the power of their engine? I note that the sports mode screen states power in KW which means bugger all to me as I don’t see why I should have to convert it in my head.
Again, I hope there’s a setting to change to BHP that I haven’t yet discovered |
06-29-2020, 04:35 PM | #19 |
Rep 444
06-29-2020, 06:41 PM | #20 | |
Rep 98
06-30-2020, 05:41 AM | #21 | |
Rep 457
06-30-2020, 06:14 AM | #22 | ||
Rep 2,415
That why some engines seem to heave strange numbers in HP but are round numbers in Kw. Some taxes and insurances are more expensive above a certain Kw/hp that's why it is limited by the manufacturer to be in a more interesting tax scale. But you are correct. Nobody uses this like that in real life. |
Unit218.50 |
