03-30-2023, 04:47 PM | #1 |
Rep 2
Hi everyone. Does anyone have experience with the 20s or 21s rims without run-flat tires?
My X5 is without air suspension and I live in Ukraine - which means the roads are really bad(. Currently, I am on 21s run-flat and I don’t like ride comfort so I am thinking of changing to 20s none-run-flat or staying on 21s only changing tires to none-run-flat. 21s - I like them more because of their look but not sure if changing to none run-flat tires will improve the comfort that much compared to 20s. Just wanted to get some feedback if some of you have changed tires like these. Thank you. |
03-31-2023, 04:47 AM | #2 |
Rep 2,072
I went from 21 RFT (P Zero) to 21 non-RFT (P Zero) to 22 non-RFT (Continental)
21 non-RFT was noticeably more comfortabte than RFT. Even the 22 non-RFT is more comfortable than the 21 RFT were. I am on air suspension, but ultimately the difference between the tyres will remain, no matter what suspension you are on. |
03-31-2023, 04:01 PM | #3 | |
Rep 2
04-02-2023, 07:51 PM | #4 |
Rep 2
Do you mind sharing what non-rft tires you ended up getting and in what sizes/specs? Was it the same as the original 275/40/21 - 315/35/21 ?
05-01-2023, 01:36 PM | #5 |
309
Rep 1,733
Drives: 2003 M3
What do people run for non RFT 21" ?
05-03-2023, 01:24 AM | #6 | |
Rep 1,145
Drives: 2022 x5 40!
