05-07-2023, 03:17 PM | #1 |
Rep 1,075
For those of you with lowering links and air suspension…
Curious to know how lowering links have faired with you since installation, especially with the adjustable air suspension.
- Any suspension issues since installation? - How is tire wear and did you need an alignment? - How is the ride and is there considerable difference from stock since installation? - how low did some of you go from OEM height? Thanks in advance! |
05-08-2023, 07:55 AM | #2 |
Rep 704
Zero suspension issues since installation. I wouldn't be able to tell you about tire wear since I have a separate winter set and I change wheels and tires nearly every season, but in the time I do have a certain set of tires, no uneven wear. I probably could benefit from an alignment but I've never had one yet.
The ride is slightly harsher, but handling is slightly improved comparing one specific height setting pre and post links. The old load setting is now my sport setting. |
05-08-2023, 12:19 PM | #3 | |
Rep 1,075
05-08-2023, 12:50 PM | #4 | |
Rep 704
I'm running BBM lowering links. |
rundeyvoo891.50 |
05-08-2023, 01:02 PM | #5 |
Rep 8,698
Drives: eVeRyOnE mAD!
https://g05.bimmerpost.com/forums/sh....php?t=1747978
https://g05.bimmerpost.com/forums/sh....php?t=1844354 you really should utilize the search function |
rundeyvoo891.50 |
05-08-2023, 01:33 PM | #6 | |
Rep 1,075
I do appreciate the info though, thank you! |
nZtiZia4653.50 |
05-08-2023, 01:42 PM | #7 |
Rep 1,075
05-08-2023, 04:00 PM | #8 |
Rep 3,035
Drives: 2022 BMW X5
I've been driving with lowering links from RG Sport for little over a year, no issues to report here, I'm using recommended settings.
The only thing I can recommend if you going with them is to coat them before installing, they kinda rusty now (but this only on outside parts) no functional issues. I might be getting new set again, just to coat them first or maybe I'll see if they have newer coated version now. Hope this helps/
r33_RGSport12971.00 |
05-08-2023, 05:49 PM | #9 | |
Rep 1,075
05-08-2023, 05:55 PM | #10 | |
Rep 3,035
Drives: 2022 BMW X5
as for alignment, no I didn’t have to do it, I change wheels quite often as well as I only drove 8k miles for the last year and half.
rundeyvoo891.50 |
05-09-2023, 03:10 AM | #11 | |
Rep 1,075
If I do get the ones from RG Sport (Ben) I'll definitely ceramic coat them. Are there any other lowering links apart from the ones from RG Sport or BBM? |
05-09-2023, 06:04 AM | #12 | |
Rep 3,035
Drives: 2022 BMW X5
yes Ben is good way to go if you in US.
05-09-2023, 07:48 PM | #13 | |
Rep 1,075
Anyone else that installed the RG Sport lowering links experience it rusting? |
05-11-2023, 07:06 PM | #14 | |
12971
Rep 18,716
I was thinking to anodize them, but anodizing will add thickness and I afraid it will create issue with the ball for not moving freely. The rust is only a surface rust, it won't break on you.
rundeyvoo891.50 |
05-11-2023, 07:08 PM | #15 | |
Rep 1,075
05-11-2023, 07:10 PM | #16 |
12971
Rep 18,716
