04-11-2024, 04:13 PM | #1 |
553
Rep 1,583
Just posting this here because I was actually surprised at the outcome of my first ever attempted bumper repair. I did this for my uncle ‘s car using a hot air gun at high-speed.
It certainly worth a try if you ever have something like this happen to you and want to leave out insurance. I had to replace the tail light, got that on eBay for $75.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
04-11-2024, 05:20 PM | #3 |
553
Rep 1,583
Yes, I was able to do it in place by first pushing it out first with the curved handle of a plier, And then get the remaining shallow dent out with my hand. Got lucky in that aspect that didn’t have to take the whole bumper off, but I would definitely take it off if can’t get to it properly.
04-12-2024, 04:04 AM | #4 |
Rep 20
Looks like a great job, well done.
As someone who has worked as a professional dent repairer in the past (on metal panels) I was occasionally asked to improve dents in plastic bumpers, as an alternative to putting them through the bodyshop. I used exactly the same method with a heat gun and pressure from behind. You did exactly the right thing by moving the heat gun really fast, as a word of caution to anyone else trying this make sure not to get the plastic too hot as the paint will crack and bubble pretty easily, as I've found to my cost on more than one occasion! |
fe7565552.50 |
04-12-2024, 04:10 AM | #5 | |
553
Rep 1,583
04-14-2024, 02:28 PM | #8 |
553
Rep 1,583
Thank you. I ordered on EBay a paint match kit with clear coat and will try to fix where the paint cracked. I think this part will be more difficult not messing up. But it does not have to look OEM, just should pass the 2-3 feet test.
