03-03-2021, 09:39 AM | #1 |
Rep 242
Downsides of disabling A.S.S in 2021 x40i
So, after a week and a half of having the car, I’m already tired of the A.S.S in my 21 X6. The shutting off the engine part doesn’t bother me, it’s the shudder when it starts back up. I understand the concept of how to use bimmercode to disable the option, but am wanting to know what are the downsides of disabling it. I get that fuel consumption may go up slightly (although I can’t imagine it will change much at all, since most of the time it restarts itself when I’m sitting at a light before I’m ready to go, and I can’t imagine an idling engine uses much gas anyway), but any unexpected consequences or interactions with other systems? Also not sure how it interacts with/affects the 48V mild hybrid system in the 21s. Does it have to be re-enabled before taking it to the dealer for service?
I’m naturally wary of messing with the software of a brand new, expensive, high tech car that’s under warranty and either screwing it up, or causing problems down the road. It’s strange that they deleted the button for the 21s since you can always defeat the function by selecting SPORT mode. It’s just that it’s a pain to do that every time, plus I really don’t want to run in SPORt mode all of the time. TIA for any insights. |
03-03-2021, 11:28 AM | #2 |
1176
Rep 1,502
The ASS system in the 21's is actually pretty damn good.
The "shudder" really isn't there as there is no started motor in a classical sense. Its a very smooth start and impermeable if you have the radio on or are talking with a passenger. My GF has no idea when the car shuts off or turns back on. A solution for you can be "sports mode individual" with all the settings on comfort. |
03-03-2021, 11:54 AM | #3 |
Rep 8,690
Drives: eVeRyOnE mAD!
i have not experienced start up shudder with active ASS
03-03-2021, 11:58 AM | #4 |
Rep 242
Actually owning and driving the car, I have to disagree that the “shudder” isn’t there. If the engine is off when you release the brake when it light goes green, then it’s barely noticeable as the car starts moving forward. But if you’re just sitting there stopped and the engine decides to restart while holding on the brake (I suspect in my case because the air conditioning is running), the car definitely shudders and it is noticeable.
Setting Sport Individual isn’t a good option for me. First, I’m not interested in having to select Sport every time I start the car. Also, I’m not interested in having a dumbed down Sport mode because there are times when I want to select Sport mode and have the real Sport Mode. I know you can multiple button press to get Sport +, but that’s more button mashing. |
03-03-2021, 12:11 PM | #5 | |
Rep 4,331
r33_RGSport12966.00 |
03-03-2021, 12:16 PM | #6 | |
12966
Rep 18,713
I never like or understand the idea of ASS. I think it is more ideal if they have it setup to turn off when you are idle in traffic for more than 30 seconds. But for on road driving, the engine stop when you do proper stop at any stop sign. Which is very annoying. So far, I don't notice any MPG drop by not having ASS. The only thing that is in-tact is my sanity. lol.
03-03-2021, 12:28 PM | #7 |
Rep 485
I can feel the shudder, but it's VASTLY improved over what it's like in, say, the X3. Which in turn is light years ahead of, say, a 2020 Honda Odyssey.
That said, that was my primary reason for getting Bimmercode a while back was to keep ASS off. I'm sure the 48 v mild hybrid system helps a little, but ASS kills 12v batteries. I'm sure it's not great for overall wear and tear either. Other than some miniscule improvement in mpg, I don't think there's any good reason to keep it. |
03-03-2021, 05:57 PM | #8 |
X5 Enthusiast
461
Rep 762
Drives: 2021 X5
You can use Bimmercode to make the vehicle remember your last driving mode or make other driving mode as default. Many owners make sports individual default as they can dial in the driving characteristics they like. This way you are not disabling ASS and it'll be available if you want to use this option at other times - for instance during highway drive, long trips etc.
I don't mind the ASS during coasting/slowdowns, but don't like it at the traffic light/stop sign; I found instances when it was not a smooth restart. I dislike the brake pulsating feel even more when it tries to regen energy.
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
03-03-2021, 08:11 PM | #9 |
805
Rep 1,790
I drove a loaner 2021 X5 a couple of weeks ago and I noticed the ASS on the very first stop/start. It is better but still very noticeable and totally ANNOYING!!! More so on the start up after the engine turns off.
I find it odd that people don't notice this right off the bat. Probably because I'm a retired Engineer and am trained to notice these anomalies. |
03-03-2021, 08:13 PM | #10 | |
Rep 1,236
Most tests estimate about 8-10% fuel saving in city driving. Link Link |
03-04-2021, 02:41 AM | #11 |
Rep 2,609
There are no downsides to permanently disabling ASS that you haven't considered (fuel, if your driving MO is stationary traffic). And you're not changing any software with coding, you're flipping a settings switch that is already in the software and should have been in the UI in the first place (and is on most other sane car designs).
03-04-2021, 05:59 AM | #12 |
Rep 76
I'm expecting my 2021 40i to arrive in about a month and I'll probably turn off the ASS function with Bimmercode, and I have a quick question for the pros.
I have never used Bimmercode before so please excuse my ignorance but would it be possible to use Bimmercode to display an "on/off ASS" switch on the iDrive menu? My guess is not but I figure it won't hurt to ask the pros. Thank you in advance for you inputs. |
03-04-2021, 08:45 AM | #13 | |
1053
Rep 1,952
03-04-2021, 08:52 AM | #14 | |
Rep 744
VTENGR1052.50 |
03-04-2021, 10:29 AM | #15 |
Rep 242
03-04-2021, 01:54 PM | #16 |
805
Rep 1,790
03-04-2021, 05:45 PM | #17 | ||
Rep 589
03-04-2021, 05:56 PM | #18 |
Rep 91
Drives: 2015 Toyota Tundra Limited
What module is it in to disable A.S.S using Bimmercode?
2021 BMW X6 (G06) x40i - Manhattan Green/Coffee - 02/2021
2017 BMW 740xi (G12) (SOLD) |
03-04-2021, 06:27 PM | #19 | ||
Rep 2,609
However, it is correct that no coding currently known adds any ASS control menu (UI) items. Too bad — BMW UI designers had their heads up their asses on this issue. Now, is this the current record for the most frequent use of the word ASS in one post? 13, I believe ... sorry for being an ass. 14.
03-05-2021, 04:23 PM | #22 | |
Rep 7,475
Again, just tossing a suggestion out there if the M/S gate is still being used in the new BMW models. And on the F chassis models...moving the lever over into the M/S gate will disengage the ASS, as well if you haven't coded it off.
