03-05-2021, 04:10 AM | #1 |
Rep 253
Constant KAFAS error : "no enabling code " in ISTA
So I picked up a power supply to update my software at home the right way and i couldn't get rid of this error code relating to KAFAS ecu. I tried deleting fault codes a number of times... Reverting to a stock ECU coding (to undo all the coding I've done /tried) but with no success. Executing the measure plan is grayed out which i suspect is due to the error code above. (maybe wrong here)
I tried checking the KAFAS FSC and its there and accepted according to esys. After a few hours last night of thinking of new ways to get rid of this code, nothing. Could use some help maybe I missed something. Tried the diag in ISTA... Going for a drive then again but nothing helped. All systems are working in the drivers assistant features for my region. I'm coding via enet cable (which has worked just fine previously). Last edited by Silver.Solid; 03-05-2021 at 04:49 AM.. |
03-05-2021, 05:59 AM | #2 |
1198
Rep 1,587
That's a pre-existing issue probably from your last upgrade I assume?
What did you upgrade from last time i.e. i-step version xxxx to 20-07-560? It looks like you didnt complete all the post upgrade tasks, which often requires import of FSC from a repair kit. There has been activation code campaigns for DSC_VIP and KAFAS in the past, and I have had to import those codes after upgrade. It could be one of many KAFAS FSC thats missing - HBA, SLI, lane departure warning, GWW/WWA, etc You need to list all FSC, determine which is missing then import it from your repair kit I expect. Get your repair kit from your dealer, or ask someone on the cartechforum to help PS 03/2021.525 is out now, so you may as well upgrade to that |
Silver.Solid116.00 |
03-05-2021, 07:06 AM | #3 |
Rep 253
Ifr, as expected, thanks for chiming in.
I don't recall seeing this issue previously but i could be mistaken because i wasn't looking for it... Esp since i didn't notice any other issues. I also suspected it may be due to me trying to enable lots of new traffic light type of codes recently released hence i restored old version of all those ECUs. So I've got an FSC repair kit. What's the best way to upload them to the car via esys i take it? Is there a specific file or one by one (still searching how to do this ) Would the fsc log generated from esys help show what issues are there? Finally, I noticed 03/2021.525 is out from your thread... Downloading 4.28.13.7z as we speak Thanks again! Last edited by Silver.Solid; 03-05-2021 at 08:54 AM.. |
03-05-2021, 01:24 PM | #4 |
1198
Rep 1,587
You should be able to see the status of all FSC in your operations report.
I've only ever added it during post processing after a software update on ISTA so not sure if you'll have the option elsewhere. You can definitely import FSC in esys. |
03-06-2021, 01:19 AM | #5 |
Rep 2,244
Try VO coding your Kafas in ista to restore the coding data to default first , see if that makes it go away
03-06-2021, 01:37 AM | #6 | |
1198
Rep 1,587
I assume you mean you VO Coded KAFAS, SAS3, MGU and BDC (7083) against your stock FA, and not that you reverted the i-level of those ECU? There is no relevant TLA coding for KAFAS so would not have impacted you. Some think that the FSC enabling code for KAFAS GWW is needed for TLA but I almost certain it is not. So your coding for TLA is irrelevant, and the suggestion to VO Code KAFAS makes sense, but I suspect you have already done that. Your ISTA Ops Report should give the info you need, like this: |
03-07-2021, 06:45 AM | #7 | ||
Rep 253
On the second point, you said i could try recording my KAFAS ecu in esys correct? which is reverting to an older saved version of settings? i didn't spot an ECU with that name but now im interested to go back and check. I'll also examine the ISTA report for any info and report back. thank you both... reallly stuck here and want to fix this asap so i can go back to updating the software. |
03-07-2021, 07:39 AM | #8 | |
1198
Rep 1,587
Doesn't really matter though. Just do this 1. do a full vehicle test in ISTA 2. review the ops log FSC section and check the status of you enabling codes for KAFAS 3. import FSC code in esys or ISTA (if you can find where to do it) That's what I'd do, but I'll caveat that I haven't had this issue so just speculating. |
03-07-2021, 10:01 AM | #9 | |
Rep 2,244
03-08-2021, 02:12 PM | #10 | |
Rep 253
any thoughts on what could be done? p.s. You can also see where there are none for Carplay and android Auto |
03-08-2021, 02:16 PM | #11 | |
Rep 253
could I try (force) something differently via esys perhaps? |
03-08-2021, 02:42 PM | #12 | ||
1198
Rep 1,587
Check 40F8 vfw_country_variant_mode is baustand_1903 or other depending on your model year |
03-08-2021, 03:04 PM | #13 | |
Rep 253
Thanks for the quick response I think you are correct but i thought i had already done that when i reverted to old settings. I'll check it out. |
03-09-2021, 08:49 AM | #14 |
Rep 1,292
I don't know if this is relevant. I don't code nor do I understand the coding language. I just installed a Stealth Hitch, combox and OE harness and had someone code via esys. He mentioned an error code relating to the KAFAS . He attempted to fix the error and was using ISTA as well. No fix was executed on the KAFAS after a few attempts to repair. He did say that it was the driver attention camera on the cluster that suspected was faulty, camera or module. I do not get any warnings. I am on 11/2020/53 and the coder said it may have been the last update done before I took delivery in December 2020 the Dealer might have not properly did the upgrade (stop sale at that time due to issue with gas tank venting required upgrade for fix) I was just at the Dealer and asked them because I was going to have them look at this error . They advised not to attempt to look at it for fear of BMW flagging the car (2021 X6M) because of recent coding ( I had a bunch of other coding done,( Anti-Dazzle, Video in Motion, door locks etc.) They said if there are no warnings and everything seems to work just leave it. The Service advisor did say they have been changing the KAFAS cameras in the mirror housing almost on a weekly basis across different models. Like I said I don't know if this is relevant or helps, but thought I would share.
03-09-2021, 03:03 PM | #15 | |
Rep 253
Id like to buy you a drink when I'm in the UK. |
03-09-2021, 03:45 PM | #16 | |
Rep 253
Thanks for sharing. One thing i read while researching this issue is the release notes of the latest ista was the issue with kafas but it was a software issue with ista itself. One thing you can do is do a diag using bimmer link and it will tell you if it's really an issue rather than an ista issue. I tried the fix our resident bmw coding genius suggested and im back in business. Almost done upgrading to 03/21. |
03-10-2021, 02:04 AM | #17 |
1198
Rep 1,587
03-12-2021, 03:43 AM | #18 |
Rep 253
So after the updates, i noticed a few actions to be completed. I also noted it asked for FSC related to "sport VDM" under "activating enabling code VIP"
anyone know what this is about? is it something i missing or an added feature? |
03-12-2021, 10:49 AM | #20 |
Rep 253
03-12-2021, 10:50 AM | #21 | |
1198
Rep 1,587
It's mandatory for when VIP is updated. Only bmw know why |
