03-06-2021, 07:46 PM | #1 |
Rep 167
DAPP capabilities
Hi guys, was trying out DAPP the other day when coming up on a bend in the road, not too large, the car failed to follow the lane and disengaged alerting in yellow lights and continuing into the next lane. Read the manual and saw that the car is supposed to slow down in situations like that to take the turn, but mine just went full speed ahead into the other lane. Haha Wondering if I'm doing something wrong, or if anyone has any tips on this?
P.S. hands were on the wheel at all times and I quickly corrected. |
03-06-2021, 08:20 PM | #2 | |
Rep 293
03-06-2021, 08:25 PM | #3 | |
Rep 581
03-06-2021, 08:44 PM | #4 |
Rep 283
I don’t think so. At higher speeds, some curves are just too tight for the DAPP to make. It’s common on most every system like this. That’s why you should always use as an aid card replacement to driving. I do notice the yellow alert when it thinks it won’t navigate the turn, that’s pretty nice.
I have found slower speeds on the same curve are fine but faster speeds won’t work with the system. Overall I really like it, just wish the lane keep was stronger without having the while DAPP system engaged like in many other cars. |
03-06-2021, 09:01 PM | #5 | ||
Rep 293
03-06-2021, 09:27 PM | #6 |
Rep 4,486
Drives: 2022 iX xDrive50, DGM
Couple of points - DAPP needs to "see" lane markers, including roadside markers, to stay in the lane. One of the limitations of all the "lane keeping" systems now, although some "see" better than others. The lane markers in the instrument cluster will turn green (one or both) when the system is active. Lighting, weather, and the condition of the markers (and the camera lenses) all make a difference. Second point - the predictive function of speed correction following the road only works if navigation is active and a destination is set. As noted, knowing the limitations of the system, and being prepared for driver intervention, makes for a better experience.
03-06-2021, 09:44 PM | #7 | |
Rep 581
03-07-2021, 02:40 AM | #8 |
1197
Rep 1,587
What model year do you have?
MY21 will adapt to known conditions (bend, junction, highway exit, roundabout, etc) by slowing in anticipation. This is shown in cic/ hud as an accepted condition before the deceleration occurs. Supported vehicles earlier than MY21 need istep 11/2020 or later, and probably coding. |
volodp196.50 |
03-07-2021, 03:45 AM | #9 | ||
Rep 167
03-07-2021, 04:12 AM | #10 | |||
1197
Rep 1,587
I have coded mine so there may be regional differences. |
03-07-2021, 06:04 AM | #11 | |
Rep 2,620
03-07-2021, 12:41 PM | #12 |
1164
Rep 1,774
I totally did not know this, thanks. I too noticed it would randomly slow down on curves sometimes, and other times it would just drift off. I never correlated that I had the navigation system engaged on the days it did slow down on the curve.
03-07-2021, 01:00 PM | #13 | |
Rep 4,246
thereef5101164.00 |
03-07-2021, 01:07 PM | #14 |
Rep 4,246
The steering and lane control assistant works well for long, wide curves versus short, sharper or narrow curves.
It's a system limitation and require many functional requires to perform as intended, for example: - Above 43mph, lane markings on both sides need to be detected and below 43mph, lane markings on both sides or a vehicle driving ahead - Wide curves, sufficient lane width - No turn signal - Cruise control with distance control active Many more covered in manual.
03-07-2021, 03:08 PM | #15 |
1197
Rep 1,587
I think it's worth clarifying for OP that there are enhancements to the 'Adapt to Route' system on MY21, at least in regions where supported.
It's now called 'adjust speed automatically to route' in idrive, and offers some additional benefits that aren't in the MY20 and earlier manual: - With nav running it will slow the vehicle for all manoeuvres including junctions. It slows just about perfectly to take the junction. Sometimes its 1 or 2 mph a little too fast for me if I don't have good visibility of the target road - Without nav running the car will slow for junctions if the driver indicates on the stalk - On highways it prompts to driver to change lane in cic/hud and via a wiggle of the steering wheel, in preparation for an exit - The urban bend control is MUCH improved, principally because it now acknowledges and slows for most bends, meaning it doesn't have to disengage cruise because it is already travelling at the right speed for the bend on approach This video, although in German (set English CC), demonstrates the junction part quite well at around 3:45: |
03-07-2021, 05:58 PM | #16 |
1164
Rep 1,774
1 year into ownership here's yet another thing i didn't know. How do you activate it while you're using DAPP? Do I have to press the LIM button?
03-07-2021, 07:45 PM | #17 | |
Rep 4,486
As far as the LIM button, I've seen videos where even the Genius appears confused as to its function. If you press the button at a particular speed (I believe it has to be 20mph or above), it "limits" your speed by slowing the throttle response as you reach that speed - as you press the accelerator you get less response from the accelerator as you reach the "limit" (and an alarm if you exceed it). You can adjust the "limit" up or down with the control wheel on the left of the steering wheel, just like adjusting the ACC, and It can be overcome by just pressing the accelerator a little harder, but it serves as sort of a reminder, and it shows up as an icon on the left side of the instrument cluster ("LIM" with a little speedometer beside it). Last edited by Paladin1; 03-07-2021 at 08:01 PM.. |
Auricom4360.00 thereef5101164.00 |
