12-26-2022, 09:42 AM | #595 |
12959
Rep 18,703
I see. Yea, you need to get it inspected. Never had issue on those that I've installed.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... Last edited by r33_RGSport; 12-27-2022 at 08:07 PM.. |
RR_Bimmers228.50 Shuja_a64.50 |
12-27-2022, 06:55 PM | #596 |
Rep 97
Drives: 2021 X5M Competition
Lowered MSS, stock comp wheels, aggressive.
r33_RGSport12958.50 |
06-02-2023, 10:00 PM | #597 |
Rep 80
I know this post is a little stale, but I just read through the whole thing again. I don't see anywhere that is listed for the max and min lowering available with this setup. I only see the preferred settings of 0mm up in front and 10mm up in rear. What does that translate to in amount of lowering? Has anyone actually measured it? I can't seem to get any info from the MSS site right now either. Thanks.
06-02-2023, 10:03 PM | #598 | |
12959
Rep 18,703
07-25-2023, 06:35 PM | #599 |
Rep 89
Anything on this? I’ve had the clicking sound since dropping it and when I brake and take my foot off the brakes the car rolls forward a slight bit then stops. Drives me absolutely crazy, thinking about just raising it back up to stock
07-25-2023, 07:34 PM | #600 | |
12959
Rep 18,703
The rolls forward, not so sure.
07-26-2023, 09:01 AM | #601 |
23
Rep 38
with the MSS spring setup, do you still have access to the in car menu to adjust from comfort, sport, sport-plus? Or is that button ignored...
what does it actually do? Ha..no idea. |
07-26-2023, 09:04 AM | #602 | |
12959
Rep 18,703
It is your shock setting.
akoni21023.00 |
08-02-2023, 04:53 PM | #603 |
68
Rep 42
Mileage report from anyone? I’m at 13k have some wearing on the insides of mainly my front tires due to some camber. Anyone else have this issue? Any thoughts on correcting it?
r33_RGSport12958.50 ipayincash39.50 |
08-02-2023, 08:48 PM | #604 |
Rep 145
Think this is par for the course since you changed the suspension geometry to even more negative camber. Only solution, depending on who you ask, is to swap out the front upper control arms with units from the X5 M50I.
08-02-2023, 09:43 PM | #605 |
68
Rep 42
Has anyone done this on a F95 with any success?
08-03-2023, 11:50 PM | #606 |
12959
Rep 18,703
A few guys did.
Some are sceptical about it. I may give it a shot on my XM once I finalized the suspension setup.
TufLuk1368.00 |
08-06-2023, 09:40 AM | #607 |
Rep 27
08-06-2023, 10:24 AM | #608 | |
12959
Rep 18,703
But, based on my testing and measurement, it only give about 1.25” drop from initial install. Probably after settled, it would go to 1.5”. And all of them they I’ve sold and installed in house are the same outcome.
phillipeino35.00 |
08-06-2023, 10:36 AM | #609 | |
Rep 27
r33_RGSport12958.50 TufLuk1368.00 |
08-06-2023, 10:58 AM | #610 |
12959
Rep 18,703
08-08-2023, 10:03 AM | #612 |
Rep 151
Im running all season tires, lowered and reporting that I got 13k miles out of the rears and they need replacing.. inside of the rear tires are bald. the Fronts are on their way and just about bald. So if your lowered replacing tires will be a way of life while having lowering springs.
@scott_Kaz73 ( Instagram )
TufLuk1368.00 |
08-08-2023, 02:14 PM | #613 | |
Rep 432
08-08-2023, 02:49 PM | #614 | |
Rep 151
GotBeemed415.50 ipayincash39.50 |
08-08-2023, 04:52 PM | #615 | |
Loving Life
56
Rep 32
It will not eliminate the negative camber completely, but will definitely help with tire lifespan. Considering that the new set of tires is >$2K, over time, lowering will become an expansive modification. |
GotBeemed415.50 |
08-09-2023, 12:07 PM | #616 | |
Rep 432
My last set lasted over 25K miles. However, this is still reducing the tires life by half at least depending on the tire. I am running Nitto 420V tires. Please no one start about Michelin this, Michelin that. I am not buying them. Yes, it is the problem that continues to plague this chassis!!!! A manufacture needs to make a SOLUTION to those that want to mod. |
fallen56.00 |
