      01-26-2024, 03:55 PM   #23
aaaaaaaaaz
Drives: 2024 X5 50e (CB/Coffee)
Originally Posted by TurtleBoy View Post
do you mean the kph to mph conversion? I think the last should be 37.
yea... I guess so
      01-26-2024, 05:45 PM   #24
eelnoraa
Drives: G05 X5
I don't think that is the case from the documentation or lack thereof. When the vehicle is lowered but the damper rate stays the same. Any loss of comfort would be due to the springs being compressed.
oh really, I always think when we lower the setting to sport setting, the damper is tighten up. are the dampers electronically adjustable?
2022 G05 B58/PHEV
+ a few very old BMWs
      01-26-2024, 06:15 PM   #25
TurtleBoy
TurtleBoy's Avatar
13266
Drives: 2019 X5 40i,2021 M340i
I have not ever seen anything saying that the damping is effecting when lowering the height using the rocker switch. It is of course when you use the DDC Sport button. The docs mention that the transmission is altered in some instances when using the rocker switch, high and off-road mode so would imagine that it would have mentioned the damper control being altered if it was also.
Yes, all suspensions for the G05 have electronic damper control.
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50
eelnoraa2032.50
      01-26-2024, 07:32 PM   #26
eelnoraa
Drives: G05 X5
Oh understood. Thinking back a bit, I know why I made that assumption that damper setting is tight to suspension height. It is the Electric Individual setting. If I set damper to comfort, car will use mid level. If I set to sport, car will use -1 height. Making me think they are related. But I agree, I cannot say for sure. If I use Hybrid mode and reduce height to -1 by the rocker switch, what is the damper setting. Good catch good catch!!
2022 G05 B58/PHEV
TurtleBoy13266.00
      03-09-2024, 05:40 PM   #27
nzzzzz0832
Drives: BMW x5 45e
Range rover has the feature where if you park the vehicle, air suspension will adjust lower for easier access to the car then return to normal if you start to drive. I wonder if X5 can do that too?
      03-09-2024, 05:41 PM   #28
TurtleBoy
TurtleBoy's Avatar
13266
No it can not, you have to manually lower it.
      03-10-2024, 03:05 AM   #29
Bristle Hound
In The Dog House ...
Bristle Hound's Avatar
360
Drives: MY23 BMW X5 xDrive30d M Sp
May help
https://g05.bimmerpost.com/forums/sh....php?t=2029758
