      03-06-2024, 02:29 PM   #1
5ive7even
Drives: 2024 X5 40i, E63s AMG
Where can I source a replacement knob?
My wife's 2024 X5 40i LCI is less than a month old and I went to install the crystal volume/power button for the radio this afternoon and inadvertently cracked/broke the outer volume knob ring.
I called two nearby BMW parts departments and both said they do not sell the volume knob ring individually and I would have to replace the entire panel (~$1000). This is ridiculous for part that probably only costs 5-15 dollars retail and pennies to manufacture. My dealer is opening a ticket with BMW USA but they didn't give me the warm and fuzzies that it would do any good.
Does anyone know where I can source a replacement ring for a reasonable price? Picture of broken part below... Thanks!
I glued it back together and worst case, I guess I'll try to fill and respray this one.
      03-06-2024, 06:31 PM   #2
R3v1v3
32
Drives: 2019 X5
Try claiming warranty?!?
E91toG05342.50
      03-06-2024, 07:02 PM   #3
davchr
Drives: X5 40i, 718 Cayman, 65 Etype
If you know someone with a 3D printer that looks like a reasonable 3D print part.
5ive7even129.00
      03-06-2024, 07:06 PM   #4
TurtleBoy
TurtleBoy's Avatar
13266
Drives: 2019 X5 40i,2021 M340i
Unfortunately your dealer is correct and it seems it is only available as part of the unit. There are some used ones on eBay that will be a lot less expensive than going through a dealer. Maybe getting off those and pop the ring off.
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50
      03-06-2024, 07:45 PM   #5
AvGeek
Drives: 24' X7 M60i; 22' TRX
Can we please get a picture of your hulk hands?
Appreciate 3
mobilejo1114.50
Ibiza3611.50
      03-06-2024, 08:11 PM   #6
5ive7even
Thanks. I did look on ebay and see quite a few control modules under $100 but they are for G05 earlier years (e.g. 2020+). Do you know if the volume ring is the same size between the earlier G05s and the LCI?
      03-06-2024, 08:13 PM   #7
5ive7even
That stings! I'm so mad at myself as I should have known better. Thought this was going to be a 5 minute job and ended up ruining my entire afternoon. (first world problems).
mobilejo1114.50
      03-06-2024, 08:14 PM   #8
5ive7even
I have a very nice 3d printer. However, my design skills aren't great and I have no idea how to model it in Fusion 360 or the like.
I just can't believe there is nothing available online as a replacement part. I even looked on Aliexpress and Alibaba.
      03-06-2024, 08:15 PM   #9
5ive7even
It was my fault. I did call my dealer and asked them if they could contact BMW and try to get me a replacement. Hopefully, they can make it happen!
      03-06-2024, 08:16 PM   #10
TurtleBoy
TurtleBoy's Avatar
13266
I think they are the same but have not seen anything saying so.
5ive7even129.00
      03-06-2024, 09:58 PM   #11
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
What part or unit is it connected to? Get the 11 digit BMW part number for that part, then cross reference the part to see what other BMW models use the same part number.
This will expand your search online for a whole replacement unit…or perhaps you can find the knob by itself.
EDIT: For example…if #2 is the knob you are referring to…when you look up that unit to get the 11 digit BMW part number for what I assume you have is the glass knob…when you click on that 11 digit part number the g05 X5, g06 X6, and g-7 X7 all use the same unit…those the same knob.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
5ive7even129.00
      03-07-2024, 08:58 AM   #12
davchr
If you can give me an ACCURATE drawing of it I can model it in Solidworks and give you .sldprt and .stl files, or almost any other solid format.
5ive7even129.00
      03-07-2024, 05:05 PM   #13
5ive7even
Thanks for the offer! I ended up ordering a used panel on ebay. Not sure if the knob from the older panel will fit or not so I will reach out to you if I get it and it doesn't work out.
      03-10-2024, 01:53 PM   #14
5ive7even
While I wait for the replacement module/knob to arrive (from UK to US), my son who is majoring in Mechanical Engineering designed this in SolidWorks and we 3d printed for fun. Turned out really nice and will use it if the one I ordered isn't a direct fit. Here's a pic of the prototype next to the original.
Appreciate 10
TurtleBoy13266.00
Ibiza3611.50
dbull258.00
davchr80.50
X6ix GTA142.00
AvGeek121.00
biterror515.50
EPTXM577.50
