FS: E90, E91, E92, E93 Park Distance Control (PDC) Kits
04-05-2012, 09:17 AM | #1 |
264
Rep 749
Hi, Im offering for sale PDC front and rear kits. Rear PDC kit consists of - rear PDC harness - power supply harness for PDC module - PDC module (used) - 4 sensors painted to match your bumper(used) - set of mounts to bumper - 4 rubber rings for sensors (spacers) - PDC module bracket - fuse - 3 connectors Price $450 shipped front PDC kit consists of:- 4 sensors (used) - set of mounts to bumper (PDC holders) - 4 rubber rings (spacers) - front PDC harness - PDC switch (I need to know VIN # or options which you have in your car to sell you proper switch) - PDC module (used) Price $450 shipped If you have only rear PDC and would like to add front PDC, then it is necessary to change PDC module. If you decide to buy both kits then you need only one PDC module and you will save $125. I will provide you installation instruction with these kits and help with remote coding as well Last edited by marius76; 10-26-2012 at 08:22 AM.. |
04-09-2012, 12:59 AM | #3 |
Rep 34
Marius, I have a 2007 E93 with rear PDC and iDrive. Interested in the front kit. Atlantic Blue. Is signal generator required? Where from and how much?
06-01-2012, 02:48 PM | #13 |
264
Rep 749
Installation instructions says that you need to install signal generator if your car was built before 09/07. I think the best bet will be to call BMW, tell them your VIN # and ask if you need the signal generator or not.
07-05-2012, 03:47 PM | #18 |
Rep 1
front PDC
Hi I am interested in the Front PDC upgrade.
Mine is a E90 320d built in December 2007.(2008 model facelift). Could you PM whats involved including all details? Thanks |
07-06-2012, 01:09 PM | #19 |
264
Rep 749
I cant send you PM because you havent post enough.
In short, you need to run additional PDC front harness, drill holes in your front bumper for 4 sensors, replace rear PDC module with the new unit which I will send you, install new PDC switch which allow you to turn on/off sensors and finally code your car. |
