      10-08-2016, 05:03 PM   #1
6MT_Addict
6MT_Addict's Avatar
283
Drives: 08 135i M Sport 6MT, 15 X3 35i
2008 BMW 135i  [10.00]
DIY - Change CBS Oil Change Distance
BMW E9x & E8x CBS Oil Change Value Adjustments DIY (coding)
Foreword
1. This is a summary made in part from a DIY found on Bimmerpost, I am not the mastermind behind this
2. This DIY compresses scattered information into one central DIY and adds some of my own insights
3. Read this entire DIY before starting.
4. By following this DIY, you are doing so at your own risk, I am not responsible for any damage that may occur to your vehicle.
5. Warning: This process may trigger a tamper value for the CBS that could cause a headache if still under warranty: "Also, executing 'cbs_reset' Job you set MANIP_CBS flag, which essentially says: "System has been tampered with".." --> http://www.bimmerfest.com/forums/sho...p;postcount=19
6. This process will reset the CBS value, so if you did an oil change a few months back, you'll need to remember when to change the oil next without relying on the CBS reminder.
7. Before beginning, attach a battery charger or tender to the car to keep the battery powered up. Turning the headlights to off is also a good idea to preserve the battery. You do not want the battery dying while in the middle of coding. I'm not sure what would happen, but I presume damage to the code within the module, in this case the DME.
8. After each Oil Change + OCI reset, you'll need to perform this coding. You're manually adjusting the CBS data for the current oil life by saying it is x percent of 100
Requirements
You will need INPA, and Tool 32 to accomplish this, both are contained within BWM Tools 2.12. You will also need a K+DCAN cable to connect your BMW.
If you are new to coding, begin here before progressing further: http://www.e90post.com/forums/showthread.php?t=451145
Procedure
Step 1: Disable JB4 if equipped (Map 0), or any other tuning which may interfere.
Step 2: Connect car, confirm connection with INPA, close INPA
Step 3: Open Tool 32, run MSD80.prg, or other DME file if applicable
Use Real OEM to confirm your vehicles DME --> Enter the last 7 of your VIN --> Engine Electrical Systems --> DME
DDE6: Diesel (03/2005 - 09/2007)
DDE7: Diesel (09/2007 - 2013)
MV946: 116i, 118i, 120i, 316i, 318i, 320i, 320si
MSV70: 125i, 130i, 325i, 330i
MSV80: 128i, 328i
MSD80: 135i, 335i (N54), 325i (N53) (06/2006 - 07/2008)
MSD81: 135i, 335i, 1M (N54), 325i (N53) (03/2008 - 03/2013)
MEVD172: 135i, 335i (N55)
MEVD1726: 135i, 335i (N55)
MSS60: M3
Step 4: Navigate to cbs_daten_lesen and run the job
Step 5: In the results, find COU_RSTG_CBS_MESS_WERT make a note of the value here, it will be between 0 and 30. This value will be needed later on if you decide to adjust the month/year manually. The below screen capture is of my car, notice how the value here is 08. This value is the number of times the CBS oil counter has been reset, so my car has had the CBS oil counter reset 8 times, or has had 8 oil changes done in its life time (assuming the CBS reset was done correctly each time the oil was changed)
Step 6: Close the results and navigate to cbs_reset. In the Arguments box, enter oel;XX;YY, where:
XX = the service interval (Approximate percentage of the original value, in multiples of 1. The 100% value is 27,580km)
YY = your current CBS counter value
A few options for XX, in increments of 5, are:
oel;50;YY=14,000km (13790km rounds to 9,000 miles)
oel;45;YY=12,000km (12411km rounds to 8,000 miles)
oel;40;YY=11,000km (11032km rounds to 7,000 miles)
oel;35;YY=10,000km (9653km rounds to 6,000 miles)
oel;30;YY=8,000km (8270km rounds to 5,000 miles)
oel;25;YY=7,000km (6890km rounds to 4,300 miles)
oel;20;YY=6,000km (5510km rounds to 3,700 miles)
oel;15;YY=4,100km (4130km rounds to 2,500 miles)
oel;10;YY=2,700km (2750km rounds to 1,700 miles)
To pull this all together, my counter value is 08 and I want an oil change interval of 8,000km, so I entered: oel;30;08
Once you have entered the value, double click on cbs_reset to run the job, or press F5.
Step 7: Navigate to cbs_daten_lesen and run the job again, view the info and look for a change in RMMI_CBS_WERT value. This value is multiplied by 10 to give the OCI, ie 827 x 10km = 8270km for the OCI.
Step 8: Check the Service Info section via the stalk to see your Oil Change Interval
Step 9: Enable JB4 if equipped, or any other tuning disabled in Step 1
Happy coding!
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport
Full 3M Vinyl Wrap | Flat Black Grilles
Appreciate 5
Dackelone10615.50
ShocknAwe3238.50
vtl1496.00
1and11864.00
      10-08-2016, 08:11 PM   #2
greenthumb
greenthumb's Avatar
Drives: '12 135i ///M-Sport
2012 BMW 135i  [10.00]
Nice work! Glad to see some coding make it into this forum. I wonder if it's possible to change the brake fluid interval for those of us running race spec stuff.
      10-09-2016, 09:24 AM   #3
ShocknAwe
1Addict
ShocknAwe's Avatar
3239
Drives: E82 Mutt, M57 Truck
Thanks 1AA!!
I'd imagine it's basically the same procedure, just gotta figure out the code locations and time scales for brake fluid vs oil vs other maintminder stuff.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      10-09-2016, 11:38 AM   #4
6MT_Addict
6MT_Addict's Avatar
283
Originally Posted by ShocknAwe
Thanks 1AA!!
+1
You would just need to discover the argument needed to adjust it, I've read posts that alluded to users coding it but have yet to find that info.
Also original post updated with additional values for distance
      10-09-2016, 12:58 PM   #5
6MT_Addict
6MT_Addict's Avatar
283
Upon revisiting some older coding posts and looking again at the CBS reset prompts, running them through a translator... (See image below step 6, yellowish box). Prompts 1 through 3 are used in the above DIY, 4-10 are not, which retains the other information as was previously programmed.
Prompts 4 and 5 would allow you to customize the month/year of the oil service by adding these values (ie oel;XX;YY;MT;YR)
1: CBS_Kennung: CBS ID
2: CBS_verfuegbarkeit: CBS Availability
3: CBS_anzahl_service: CBS Number Service
4: CBS_ziel_monat: CBS Target Month
5: CBS_ziel_Jahr: CBS Target Year
6: RMM_CBS_Wert: RMM_CBS_Value (Not sure what RMM is)
7: ST_UN_CBS_RSTG: (not sure what these are abbreviating? Dackelone maybe you can help shed some light)
8: FRC_INTM_Way_CBS_Mess: FRC INTM WAY CBS Measuring (again, not sure whats being abbreviated)
9: FRC_INTM_T_CBS_Mess: FRC INTM T CBS Measuring (Same comment as 8)
10: Res_Byte: Reset Byte?
The trick for CBS brake fluid service would be determining the ID that the CBS uses for brake fluid, then using either a 3 prompt or 5 prompt string you could be able to reset it.
At the moment the following prompts I know to be confirmed for prompt 1 above, I'm making some assumptions on what the abbreviations translate to in German, having only a single letter to go off of:
OEL = Motor Oil (Motoroel)
BR_V = Brake Pad Sensors - Front (Bremse Vorderseite)
BR_H = Brake Pad Sensors - Rear (Bremse Hinten)
ShocknAwe3238.50
      10-09-2016, 07:02 PM   #6
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
Originally Posted by 1AddictsAnonymous View Post
7: ST_UN_CBS_RSTG: (not sure what these are abbreviating? Dackelone maybe you can help shed some light)...
I have no idea when it comes to line coding. But I asked some friends about this. I'll get back to you.
      10-10-2016, 02:02 PM   #7
6MT_Addict
6MT_Addict's Avatar
283
Ok, did more digging... When you click 'CBS_Reset' once, Tool32 actually gives you all the possible variations you may use. The raw export is pasted below from my car, I would imagine Brfl is brake fluid/Bremsflüssigkeit in German. I've run it through a translator below.
Original:
comment : CBS Daten Zuruecksetzen (fuer CBS-Version 4)
KWP2000: $2E WriteDataByCommonIdentifier
Modus : Default
Musterparametersatz fuer Bremsbelagverschleiss Vorder/Hinterachse
br_v,100,1,0,0,0,1,0,0
br_h,100,1,0,0,0,1,0,0
jedoch mit "Strich_Punkt" getrennt (nicht mit Komma!)
argument : CBS_KENNUNG
type : string
comment : gewuenschte CBS-Kennung
table CbsKennung CBS_K CBS_K_TEXT
Werte Kombi-Umfaenge: Brfl, ZKrz, Sic, Kfl, TUV, AU, Ueb, H2
Werte externe Umfaenge: Oel, Br_v, Br_h, Filt, CSF, Batt, VTG, ZKrz_a, DAD
Defaultwert: 0x00 (ungueltig)
argument : CBS_VERFUEGBARKEIT
type : int
comment : gewuenschte Verfuegbarkeit in Prozent: 0-100
Schalter, keine Aenderung: 255
Defaultwert: 100
argument : CBS_ANZAHL_SERVICE
type : int
comment : Anzahl der durchgefuehrten Services: 0-30
Schalter, Erhoehung der Anzahl um +1: 31
Defaultwert: 31
argument : CBS_ZIEL_MONAT
type : int
comment : Ziel-Monat (HU/AU) Januar-Dezember: 1-12
Defaultwert: 255
argument : CBS_ZIEL_JAHR
type : int
comment : Ziel-Jahr (HU/AU) 2000-2239: 0-239
Defaultwert: 255
argument : RMM_CBS_WERT
type : int
comment : Restlaufleistung in km oder % (siehe Argument Einheit)
Schalter, keine Aenderung: 8000h
Defaultwert: 8000h
argument : ST_UN_CBS_RSTG
type : int
comment : Einheit Restlaufleistung
0hex -> %
1hex -> km*10
Fhex -> d.c.
Defaultwert: Fh
argument : FRC_INTM_WAY_CBS_MESS
type : int
comment : Prognose Wegintervall
Umrechnung 1-254*1000km
Schalter, setzt auf Defaultwert zurueck: 0h
Schalter, keine Aenderung: FFh
Defaultwert: FFh
argument : FRC_INTM_T_CBS_MESS
type : int
comment : Prognose Zeitintervall
0-254 Monate
Defaultwert: FFh
argument : Res_Byte
type : int
comment : Reserve Byte (noch unbenutzt)
Defaultwert: 00h
result : JOB_STATUS
type : string
comment : OKAY, wenn fehlerfrei
table JobResult STATUS_TEXT
result : ECU_ADR_WERT
type : int
comment : Steuergeraeteadresse als Zahl
result : ECU_ADR_HEX
type : string
comment : Steuergeraeteadresse als Hex-String
result : ECU_ADR_TEXT
type : string
comment : Steuergeraeteadresse im Klartext
result : _TEL_AUFTRAG
type : data
comment : Hex-Auftrag an SG
result : _TEL_ANTWORT
type : data
comment : Hex-Antwort von SG
Translated:
Comment: CBS data reset (for CBS version 4)
KWP2000: $ 2E WriteDataByCommonIdentifier
Mode: Default
Pattern parameter set for brake lining wear front / rear axle
Br_v, 100,1,0,0,0,1,0,0
Br_h, 100,1,0,0,0,1,0,0
But separated with "Strich_Punkt" (not with comma!)
Argument: CBS_IDENTIFICATION
Type: string
Comment: desired CBS ID
Table CbsCode CBS_K CBS_K_TEXT
Values ​​Combined Envelopes: Brfl, ZKrz, Sic, Kfl, TUV, AU, Ueb, H2
Values ​​external circumferences: Oel, Br_v, Br_h, Filt, CSF, Batt, VTG, ZKrz_a, DAD
Default value: 0x00 (invalid)
Argument: CBS_ABILITY
Type: int
Comment: Desired availability in percent: 0-100
Switch, no change: 255
Default value: 100
Argument: CBS_NUMBER_SERVICE
Type: int
Comment: Number of services performed: 0-30
Switch, increase the number by +1: 31
Default value: 31
Argument: CBS_TARGET_MONTH
Type: int
Comment: target month (HU / AU) January-December: 1-12
Default value: 255
Argument: CBS_TARGET_YEAR
Type: int
Comment: target year (HU / AU) 2000-2239: 0-239
Default value: 255
Argument: RMM_CBS_VALUE
Type: int
Comment: Residual power in km or% (see argument unit)
Switch, no change: 8000h
Default value: 8000h
Argument: ST_UN_CBS_RSTG
Type: int
Comment: Unit residual power
0hex ->%
1hex -> km * 10
Fhex -> d.c.
Default value: Fh
Argument: FRC_INTM_WAY_CBS_MESS
Type: int
Comment: Forecast path intervall
Conversion 1-254 * 1000km
Switch, resets to default value: 0h
Switch, no change: FFh
Default value: FFh
Argument: FRC_INTM_T_CBS_MESS
Type: int
Comment: Forecast time interval
0-254 months
Default value: FFh
Argument: Res_Byte
Type: int
Comment: spare byte (still unused)
Default value: 00h
Result: JOB_STATUS
Type: string
Comment: OK, if error-free
Table JobResult STATUS_TEXT
Result: ECU_ADR_VALUE
Type: int
Comment: Control device address as number
Result: ECU_ADR_HEX
Type: string
Comment: Control device address as a hex string
Result: ECU_ADR_TEXT
Type: string
Comment: Control device address in the plain text
Result: _TEL ORDER
Type: data
Comment: Hex order to SG
Result: _TEL ANSWER
Type: data
Comment: Hex response from
      10-10-2016, 06:47 PM   #8
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
tool32...
Ok 1AddictsAnonymous I talked to my BMW AG "source"... he gave me these screen shots. Maybe this will make sense to you. Like I said I am not a "coder". He uses: tool32...
ST_UN_CBS_RSTG...
Name:  coding 1  14656347_1114136698664917_2207345236640630035_n.jpg
Name:  coding 2  14516440_1114137061998214_1512584182632435386_n.jpg
Name:  coding 3  14656393_1114137221998198_7854683874371063286_n.jpg
      10-10-2016, 10:13 PM   #9
6MT_Addict
6MT_Addict's Avatar
283
Thanks Dack. This mirrors the info I was able to pull from Tool32 as well. I tried altering values progressively, ie prompt 1-3, prompt 1-4, etc. Looks like only 1-3 are actually editable via Tool32 for oil.
Dackelone10615.50
      02-28-2017, 01:43 AM   #10
v3n0m
Drives: 2013 MCB M5
Has anyone been able to get this to work on an f-series? I can read the data but when I try to run cbs_reset, it gives me the error:
ERROR_ECU_CONDITIONS_NOT_CORRECT
At first I thought it might have to do with the ignition being in aux or on, but I tried both and it didn't work.
      02-28-2017, 07:20 AM   #11
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
Perhaps you should post this question on the e90forum coding section - there are more "experts" over there. or maybe bmwretrofit might know more ?
e90 coding forum...
http://www.e90post.com/forums/forumdisplay.php?f=368
      02-28-2017, 11:42 PM   #12
6MT_Addict
6MT_Addict's Avatar
283
The DME file may not be correct, but that's just a guess. I haven't experienced that error myself. Dack has a good suggestion, the coding forums will have a larger knowledge base
      11-14-2017, 06:58 PM   #13
AutoEngBM95
AutoEngBM95's Avatar
Drives: 2009 BMW E90 335xi LCI
For some reason, when I try to open my MSD80.prg file in Tool 32, it doesn't load, it just gets stuck on a blank window within Tool 32 labeled Results.
2009 E90 335xi LCI
BMS DCI, JB4, OCC, OEM Rebuilt Turbos, Ctls DwnPps, Ctls Midpipes
Max Brakes Carbon Ceramic pads, cross drilled & slotted rotors, RTX GRAZ Wheels
      11-14-2017, 10:36 PM   #14
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
Drives: '08 128i
1992 Honda Beat  [9.50]
2008 BMW 128i  [10.00]
2014 BMW 528i  [10.00]
Run tool32 as admin
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded
Instagram @Andreys_128i and @Honda.Bito
      03-28-2019, 05:10 PM   #15
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
I came into this thread to learn how to do this, and left with these in my amazon cart...
https://www.amazon.com/Oil-Change-Se...gateway&sr=8-3
      03-28-2019, 05:33 PM   #16
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
^^lol
You don't have to revert to using those Jiffy Lube windshield stickers. I guess you haven't seen this thread of mine. I made it a sticky so it's easy to find...
DIY resetting service "due" lights…
https://www.1addicts.com/forums/showthread.php?t=415111
All you need is to enter the hidden menu on the speedo cluster and then use the BC and RESET buttons to reset your service(oil) lights.
You can find more interesting DIY "sticky" threads here...
https://www.1addicts.com/forums/forumdisplay.php?f=261
Dackel
      03-29-2019, 03:42 PM   #17
dtla1
dtla1's Avatar
828
Of Course I've seen your sticky Dack, but I'm only coming back to the forums since I've been away a few years and wanted to give everyone who looked at this thread a little chuckle.
But also, I'm switching to oil changes every 5k miles now, so... Either follow this monstrosity and trick the computer via INPA, or give myself a little old school reminder right there on the windshield.
      04-20-2019, 07:08 PM   #18
6MT_Addict
6MT_Addict's Avatar
283
I got a chuckle out of that!
I have a full maintenance log for all my vehicles, which is super useful for this. I gave mileage service performed at and next due.
Whatever you use for in vehicle reminder I find keeping some form of log extremely valuable
Dackelone10615.50
1addicts
