05-30-2023, 10:55 AM | #1 |
Rep 23
X5 50E Limit for AC Charging
Picked up my wife's X5 50E yesterday and had a question about charging. We dont have a L2 charger or capabilities at home but she does have L2 charging capability at work so our thought is that we use the standard 15 amp circuit for L1 charging at home to 'top' off and use the L2 charger at work to do rapid charging.
After bringing the vehicle home yesterday, I plugged it in but received a charging error. I remembered the Genius at the dealership setting the AC limit to 32 amps (the finance guy who has a 45e also said in passing to ensure it was set to the maximum limit, i.e. 32 amps). I changed it to 10 amps, reconnected the cable and it started charging. This morning I noticed I could set the limit for AC charging to Unlimited, which I did while the vehicle was plugged in and it continued to charge. So based on how we plan to charge, is leaving it at unlimited the way to go or should she be adjusting the setting when at home vs. when in the office? My thought is we leave it unlimited but was not sure why the dealership set it up at 32 amps and if there was an intentional reason to do so. One other thing I noticed this morning, when I walked into the garage (without keys) I noticed the screen was on with the BMW logo in the center. The car was locked and had not been unlocked since the previous night. When I locked it, all the screens shut off eventually. Has anyone else seen this with theirs? |
05-30-2023, 12:47 PM | #2 |
Rep 8,753
Drives: eVeRyOnE mAD!
while I have the 45e, charging is similar in some respects.
when charging at home using the included flexible fast charger at level 1, the vehicle can pull up to the FFC’s maximum charge rate which is 10A. the only time it’ll pull less than that is if you set it lower in the vehicle. even by setting it to UNLIMITED, the 50e will only charge up to 32A max at level 2 even if you connected an EVSE rated higher than that. remember, the actual charger is inside the vehicle. when you plug an EVSE in, the on-board charger will accept up to 32A unless you set it lower in the vehicle. may wanna read your manual as to the purpose for setting it to UNLIMITED. I’m really not certain. as for the display remaining on, I’m not 100% certain the logic is the same as the 45e, but in order for the 45e to shut down properly, you must first press the Start/Stop button to end your trip before opening the door (similar to pressing the button in a modern fuel-only vehicle to shut off the engine). |
05-30-2023, 03:30 PM | #3 |
Rep 6,872
Each EVSE sends out a pilot signal that annouces to the vehicle how much its maximum current setting is. It is then up to the vehicle to never try to pull more than that, so if everything is working properly, there's no reason to lower that limit from maximum. The reason it's there is that, especially with the level 1 device, it could be on a shared circuit, and the combined current from say the garage door opener, lights, and maybe the occasional vacuum cleaner, could easily exceed the circuit's capacity and trip the breaker. To avoid that, BMW chose to not set the EVSE up so it could pull the max (which is 80% of the circuit's capacity, i.e., on 15A common circuit, 12A). This is to help prevent nuisance tripping of the breaker, but less than ideal if you have a dedicated circuit.
The power supply is in the X5, and in the 50e, the max it can provide is 7400W (3700W in the 45e), which might take up to 32A, depending on your input voltage (power=volts*amps). Where I live, my typical input voltage is around 247vac, so my 30A EVSE can max out that vehicle, but might not if the voltage was a bit lower because of the current limit. |
Steve737106.00 |
05-30-2023, 06:51 PM | #4 |
Rep 905
Lol half of new thread on the forum is for 50e. Maybe it would be a good time for spin off a new sub-forum for us hybrid owners/potential owners to avoid spamming the main forum?
05-30-2023, 09:11 PM | #5 |
Rep 8,753
05-31-2023, 10:34 AM | #6 | |
Rep 23
In general what you say makes sense and I have always understood that the vehicle has the charger and does the work to determine capabilities. It charged fully without any issues - I think the test will be once my wife takes it to work and charges it there. I am leaving it in the Unlimited setting for now. |
05-31-2023, 10:35 AM | #7 |
Rep 23
05-31-2023, 10:46 AM | #8 |
Rep 869
I don't think it makes any sense to make a sub-forum just for the 50e. If anything needs to change, add a sub-forum for topics related to the 45e/50e charging questions.
M3 - X5 - 911 - Miata - Raptor - Edge
05-31-2023, 11:04 AM | #9 |
Rep 905
yea for charging and battery / range / hybrid mode behavior. These topics are probably not interesting to non-hybrid X5 owners on the forum and there are a lot recently
05-31-2023, 12:04 PM | #10 | |
301
Rep 382
05-31-2023, 12:35 PM | #11 |
Rep 6,872
The J1772 plug only has two pins for ACV, so is unable to use 3-phase when configured that way, but the Minekes plug supports 3-power lines coming in. I do not know if the onboard charging unit is the same, but it's not wired the same everywhere. But, yeah, where available, 3-phase power is possible as an input, just not in the USA (or Canada, and I'm not sure where else that plug is used).
06-01-2023, 12:40 AM | #12 | |
301
Rep 382
06-01-2023, 03:35 PM | #13 |
Rep 208
08-31-2023, 02:50 PM | #14 |
Rep 16
Drives: 2024 X5 50e
Couldn’t find it in the tread but does anyone have the part number for the 220v adapter to purchase separately to use with the charger that comes with the 50e? The salesman was telling me some just use a generic adapter that can be bought on Amazon. But would need the specs on the bmw adapter if I was to buy an equivalent one. Thanks
08-31-2023, 03:01 PM | #15 |
Rep 6,872
The cord for the FFS has more than just the power lines going through...there are some extra pins that reprogram the FFS to allow it to change the pilot signal that tells the vehicle it can provide more power. IOW, just plugging the existing cord into an adapter would still double the power to the vehicle, but would still be limited to 10A. I do not know if it would be damaged, but probably not, by plugging the level 1 power cord into an adapter and then 240vac. Power=volts*amps, so 240 versus 120 would double the power, but not max the charging rate out.
08-31-2023, 03:02 PM | #16 | |
13475
Rep 20,088
https://g05.bimmerpost.com/forums/sh...&postcount=334
Baze10.50 |
10-12-2023, 11:44 AM | #17 |
Rep 196
I have a question about charging to 80%. Dealer intro said yes, charge to 80% unless going on special trip. I have seen other comments the X5 has a buffer built in and you can charge to 100% all the time. If you use the 80/20 rule like on the i4, that 40 mile range drops pretty low. Any thoughts?
2024 X5 xdrive50e. Ruby Red II, Silverstone Sensafin, M Sport, M Sport Pro, Premium Pack, Contour Seats, Climate Pack, PAP, DAP.
10-12-2023, 12:10 PM | #18 | |
Rep 3,699
Apple to apple comparison for ideal case (power factor = 1) - US single phase 240V (RMS): peak to peak is 339V. At 32A, RMS power is 7.4kW - 3 phase supply with peak to peak of 339V, to achieve 7.4kW, each phase needs to supply 12.5A.
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 10-12-2023 at 12:29 PM.. |
10-12-2023, 12:33 PM | #19 | |
Rep 8,753
the practice of the "80% rule" only applies to full EV that have access to the gross capacity. charging the gross capacity from 0-100% = 1 full charge cycle, thus charging to 80% is 0.8 charge cycle. this increases battery longevity because of a decreased charge cycle. on the US 50e, you can safely charge to 100% because usable capacity is <70% of gross capacity, so charging the usable capacity from 0-100% is only 0.68 charge cycle. as you can see, battery longevity is built-in because of the decreased charge cycle when fully charging the lower usable capacity. this was likely done so the HV battery's capacity won't dip below 70% of the original (usable) capacity throughout its warranty period which can vary by state. FYI, EU and rest of the world allow their 45e and 50e to tap into more usable capacity, but this decreases battery longevity which is purportedly why their warranty period is shorter than the US (and Canada, i presume). you can charge to 80% if you like, but it's unnecessary if they are advising it because of battery longevity on their PHEVs Last edited by nZtiZia; 10-13-2023 at 11:12 AM.. |
tooloud10786.00 |
10-13-2023, 02:10 AM | #20 | |
301
Rep 382
biterror521.50 |
