01-25-2021, 12:32 PM | #1 |
Generalissimo
641
Rep 1,392
45e Charging Questions
I just got my 45e recently and have a few questions about charging.
1) The instrument cluster and the BMW Connected app show different electric range miles while charging. Usually the app shows 1 or 2 miles more. 2) The estimated time of full charge completion is several hours off and again there is a few minute difference between what the car and the app show. The time usually changes by a few minutes back and forth. Once it actually jumped back by a few hours to show the proper estimated completion time but the last time I charged it kept showing 4:20 pm and it actually finished around 2:00 pm as I was estimating. 3) How long does it take for people to charge using a 110v outlet at 16 amps? Mathematically it should be around 13.7 hours. Mine takes 14,5 hours. Is anyone experiencing any of the above issues? Last edited by javapro; 04-12-2022 at 11:59 PM.. |
01-25-2021, 01:05 PM | #3 | |
Generalissimo
641
Rep 1,392
cptcolo102.00 |
01-25-2021, 01:27 PM | #5 |
Rep 232
Something like this?
https://www.amazon.com/ChargePoint-H.../dp/B07WNXTHNW ChargePoint Home Flex Electric Vehicle (EV) Charger upto 50 Amp, 240V, Level 2 WiFi Enabled EVSE, UL Listed, Energy Star, NEMA 6-50 Plug or Hardwired, Indoor/Outdoor, 23-Foot Cable |
01-25-2021, 01:31 PM | #6 | |
199
Rep 353
That's the one I have. Works great |
01-25-2021, 02:04 PM | #7 |
Rep 6,799
A few things to keep in mind
- regardless of the size of the EVSE, if it's at least 16A, the X5 will be charging at its maximum rate...more doesn't buy you anything at least with this vehicle - There's always some conversion losses in heat, cooling fans, etc., and changing from ACV to DCV, so it will take more watts in than what ends up being stored - a level 2 device (240vac) will be more efficient than a level 1 device (120vac) - since power = volts * amps, a 16A, 240vac device will charge twice as fast as a 16A, 120vac device, plus a bit more because of the above - it seems that arbitrarily, sometimes, the vehicle will switch to 6A maximum charging rate, and that will slow charging down arbitrarily. Eventually, that bug should be fixed! In the meantime, it's a good idea to verify what your iDrive menu is set to, or you may be surprised that it takes so long. The only reason to set it lower than max (16A), is if the EVSE has to share the branch circuit with something else, and you don't want to potentially pop the circuit breaker...you won't hurt the X5 or the EVSE, just your patience. - if the vehicle is really cold or extremely hot, the charging rate will be slower - the actual charging rate slows down as the state of charge (SOC) gets closer to 100%, so the last 10% or so will be slower than the first 90% |
icantchat1.50 |
01-25-2021, 06:48 PM | #8 | |
Generalissimo
641
Rep 1,392
01-25-2021, 07:24 PM | #9 |
Rep 6,799
The vehicle will never (if it's working right) try to pull more amps than the EVSE says it has in the pilot signal it sends out. The setting in the vehicle is only there to help prevent overloading of a shared circuit the EVSE might be trying to share with say your garage door opener, or a saw you want to use in the garage. Otherwise, leave it at maximum.
After a long, aggressive drive on a hot summer day, the battery pack may be quite warm, and the cooling will eat up more of the input power when recharging to help preserve it. As would parking out in the open over asphalt that has been cooking in the sun all day, potentially increasing the cooling load maybe before the charging can even begin. So, charging efficiency is a temperature and EVSE limited situation. At 120vac, it appears to be in the low 90% efficiency range while 240vac is closer to 95%, so you lose some when supplying it with the lower voltage input, disregarding any cooling that may be required in the process. |
01-25-2021, 11:08 PM | #10 | |
Generalissimo
641
Rep 1,392
Can you or someone answer my questions #1 and #2? |
01-26-2021, 12:33 PM | #11 |
Rep 6,799
Does your EVSE have a display that shows how many amps are being drawn from it? The vehicle doesn't that I'm aware of. The menu setting SHOULD limit it to the value you set, but never more than what the device announces that it has (it's a PWM signal that has to be interpreted by the vehicle).
IOW, if the menu is set to a max of 13A, and the device says it has 16A, the maximum draw should be limited to 13A by the vehicle. FWIW, the EVSE is a fancy on/off switch that essentially, just passes power through it. All of the smarts and conversion is done inside of the vehicle. To run the logic board and lights on a typical EVSE, it might draw 1-3W or so just for itself. When it activates its power contactor, it will probably pull a few more watts for itself. |
01-26-2021, 12:45 PM | #12 | |
Generalissimo
641
Rep 1,392
01-27-2021, 12:13 AM | #13 | |
Rep 83
Drives: G05 45e, Porsche Macan GTS
#2) I don't usually pay much attention to the estimated charging time, but on the occasions I have looked, it is always a bit off from reality. I don't know why, and haven't really cared enough to look into it. #3) I don't normally charge off a 110V outlet, as I use the 220V circuit from my clothes dryer with a Level2 charger that I started using with my F15 40e back in December of 2019. I do have a Level1/Level2 portable charger that I use at our ski condo on a 110V outlet, but haven't really paid close attention to charging time. I do know it took A LOT LONGER than the 4-5 hours of charging on my L2 charger on 220V. FWIW, I have been using the ChargePoint Home Flex Level2 charger for a little over a year and have been pretty happy with it. I did recently start having an issue with the wifi and BT connection (it basically stopped all communication), but after contacting ChargePoint support and giving them some info about the problem and my unit, they shipped a new one out today that should arrive on Thursday. Very good support experience thus far. (I received this charger at no cost as part of a product evaluation program, but would very seriously consider purchasing this charger at the current ~$650 price if I needed to purchase another.)
'21 X5 45e
'18 Macan GTS '15 Ram 1500 EcoDiesel |
01-27-2021, 09:31 AM | #14 | |
199
Rep 353
I also have this charger and it's been great. I just get out of the X5 and plug it in. It charges flawlessly at 16 amps every time. I've never had the X5 reset to 6 amps as many others have. Highly recommended charger |
01-27-2021, 11:42 AM | #15 |
Rep 83
Same here - my dealer set my 45e to 16A charging when I took delivery back in October and I have never once had a problem charging at 16A/220V with the Chargepoint. No reset to 6A or anything like that.
'21 X5 45e
02-02-2021, 10:28 AM | #16 | |
Rep 483
Currently: 2024 iX xDrive50 & 2022 X7 M50i
In the rear view mirror: 94 325is/07 528i/08 X5 3.0/08 328i Conv/11 X5 35i Prem/12 X5 35d/12 335i Conv/15 328d/15 328GT/15 X3 28d #1/15 X3 28d #2/16 X3 35i/16 X5M/16 M4 Conv/17 330e/21 X5 45e - Arctic Grey/21 X5 45e - Alpine White /21 330e Xdrive/I4 e35 |
02-02-2021, 05:59 PM | #17 |
Rep 6,799
The app will indicate the last time that it was updated...that could easily be quite awhile in between them. So, the vehicle itself will always show what it thinks is true, but it does not constantly update that information to the server feeding the app...the app does not directly talk to the vehicle, except through the server.
IOW, it is not uncommon for the app and the vehicle to show different things. |
03-17-2021, 09:30 PM | #18 |
Rep 74
Lots of great info in this thread! I’m starting the process of getting a L2 charger installed in my garage for a 45e delivery date mid April.
Question... if I install a dedicated 220 50amp circuit (yes, overkill but future proofing) and can achieve maximum charging speeds, a FULL charge would take around 5-6 hours? But from what I’ve read, the last 10-20% takes a long time... so how quickly can you get to 80%? That could still be very useful around town, if it was only a couple hours? Would that cause any long term damage to the batteries to only charge to 70-80% on a routine basis? |
03-18-2021, 07:05 AM | #21 |
Rep 74
Wow, 5 hours is pretty fast, all things considered. I guess I was wondering if there are any benefit for charging it while traveling to get some charge. Would an hour charge, break for lunch on a long a trip, have any benefit? If it take longer to charge the last 20%, does it charge the first 20% super fast? Or is it S shaped, where the first 20% is slow and then the bulk of the charging occurs during the middle of the time band? Being the geek that I am, I will probably run some tests, charging the charge at different time intervals to see if I can find a pattern, assuming no one else is this crazy. I’ll be sure to post my results. See attached crude charts showing what I’m taking about. I know it isn’t options A or B, just curious if owners think it is option B or C.
03-18-2021, 07:52 AM | #22 | |
Rep 64
Drives: 2020 BMW Z4 M40i
Charging mine has been linear except once it hits the 100% reading. It can take an addition 20 minutes or so once it hits 100% and you can see the charge power draw drop for those last 20 minutes. Oh, and just FYI, it takes about 19kw to go from 0 to 100% which is about a 2kw or 10% loss assuming the battery is only 17kw as BMW states. |
