08-12-2022, 03:37 PM | #1 |
pullin a boat
37
Rep 479
Stop/Yield sign detection on MY22 G05 with DA PRO?
Hi,
I've successfully coded the additional features for Driver Assistant Pro, such as Traffic Light recognition & the like. aSLA works as well. The only missing thing for me at this point is the Stop Sign detection (and yield) but I can't find any substantial info about it other than a few examples referring to FSC code requirements in KAFAS4 on older models with or without DA+. Has anyone figured out the required codes in VIP, SAS3, MGU and KAFAS4 to get this working? I have a few theories and started tagging a few codes in a notebook to test further, but I feel like I'm missing a few. I don't mind trying some things out as I am fairly well-equipped to do so. I have BimmerUtility as well as a number of other tools if that helps.
2021 X3 M40i, Phytonic/Cognac Past: 2017 330i xDrive Touring M Sport, EBII, Dinan 2014 328d xDrive Touring M Sport, BSM/CR. |
08-14-2022, 04:23 AM | #2 |
Rep 452
Drives: 2017 X5, 2020 X5 & 2021 X5
First of all make sure you have the FSC code for it. I am not sure if Canadian spec models come with it as standard if you do have it, happy days then do the following
Make a copy of your FA and change your country code from Canada to UK ( 812) then using this modified FA generate a new set of NCD files in the Coding Verification menu which is in the Esys section of Bimmer Utility then go to the NCD compare section in BU and do coding comparisons between the newly generated NCD files and your original files (which you should have saved from the car) for the said ECU's and the BDC3 module. I can have a look at my data comparisons and see what I can come up with. UK spec X5's definitely have this feature enabled not 100% sure about German spec models but you could try 801 for Germany instead and eliminate RHD changes that you would get in UK spec models Unfortunately I can't help you anymore as Australian spec models do not have the FSC code
Current: MY 21 X5 3.0d xDrive MSport
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive |
panki_86133.00 |
08-15-2022, 03:27 AM | #3 |
1202
Rep 1,587
You need the KAFAS FSC for GWW (Give Way Warner) as stated. If you have it then you need to code KAFAS (40F8).
Change (edit werte) VFW_COUNTRY_VARIANT_MODE to all FF as below. Copy and paste replacing the existing werte value. FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF Link: https://g05.bimmerpost.com/forums/sh...&postcount=306 I don't own a BMW anymore, and don't code, but thought that might help as a one off. |
Bambazonke213.00 Silver.Solid119.00 |
09-03-2022, 07:39 AM | #4 | |
Rep 255
This is indeed sad news. The G05 platform community is forever thankful for the contribution. |
ifr1201.50 |
12-08-2022, 12:27 PM | #5 | |
Rep 18
I'm assuming the FSC code example you are referring to is https://x3.xbimmers.com/forums/showt...4#post29621814. It would seem that if it works on an older X3 that it could be programmed on a newer model but obviously there are significant code differences. Any luck? And if so what does the functionality do other than recognize stop signs? |
08-27-2023, 07:21 AM | #6 | |
Rep 226
Drives: 2022 BMW X5 M50i
After I activated TLA with your cheat sheet I'm also very curious to activate stop sign recognition in my car . |
10-28-2023, 10:19 AM | #8 | |
Rep 17
So, should 11 or FF work in every country? and what will happen if this be coded without FSC? Error message or somethings? Thank you |
10-29-2023, 11:27 AM | #9 |
Rep 17
10-30-2023, 02:08 AM | #10 |
Rep 16
10-30-2023, 02:15 AM | #11 |
Rep 16
10-30-2023, 09:10 AM | #12 |
Rep 226
11-02-2023, 01:33 AM | #15 |
Rep 16
postbox1918154.50 |
11-03-2023, 01:12 PM | #16 |
Rep 17
All to “FF” or “11” ?
And how about “WWA_country_variant_mode”, should it be “FF” all? Thank you Last edited by SBimmy; 11-03-2023 at 01:17 PM.. |
