01-05-2019, 11:57 AM | #1 |
Rep 17
Air Suspension Question
Hi.
I am about to order a new X5 and was excited about the Air Suspension option for just $1000. My wife is 5’6” and says that the X5 is a bit tall compared to a sedan making it harder to get in. I was hoping that the air suspension would make it perfect hight, but before I go for it, I have the following questions: 1. Is it more trouble than it’s worth? I would like this car to last me 8 years/150,000 miles. What are the chances that the suspension will give me troubles during that time. How costly are those repairs at the dealership (1000, 2000, 3000) 2. How does it work. Do you simply lower it before you get out and it will stay lowered for you to get in (rising automatically when you start driving). 3. How much lower will it be compared to an X5 with a regular suspension I guess the bottom line is. If you were doing a custom build and were on the shorter side, would you get it? Thanks |
01-05-2019, 12:09 PM | #2 |
Rep 978
I have air suspension and like it a lot. The ride is very comfortable but doesn't loose its sporty feel - especially in Sport mode.
I'll take a shot at answering your questions: 1. I don't have any idea. This is my first vehicle with air suspension. F15 (prior generation X5) owners may chime in, as that model allowed for rear air suspension. 2. The air suspension can be lowered and raised manually 1) Via a toggle on the center console 2) Via a button on the trunk lower door (lowers vehicle all the way). 3) By selecting Sport Mode (lowers one level down). The suspension will automatically lower one level down at speeds over 86 mph. You CAN park and lower the suspension down using the console toggle - the X5 will remain lowered until you get back in the vehicle and will automatically raise to match the driving mode (Sport, Eco, Comfort, etc) as you drive. 3. The vehicle can be lowered 40mm or raised 40mm from default height - for a range of 80mm. One important thing the suspension does is self-level. Big passengers in the rear? Heavy cargo in the trunk? Towing a large boat (I do this)? The vehicle will adjust its height accordingly to stay level. Last edited by lumpydog; 01-06-2019 at 08:29 PM.. |
01-05-2019, 07:04 PM | #3 |
Rep 141
I'm not expecting any reliability issues. Coming from 3 different land rovers with air suspension (2012 LR4, 2014 LR 4, 2017 Discovery), I am expecting similar reliability. I did not have a single issue with the feature and seems to work great on the BMW. For 6 years I used it daily from auto access lowering (not really needed on the G05 - seems low enough already) to raising the vehicle driving in town and off road.
The one issue I have with the BMW feature is the air suspension will not stay raised over what seems like 15 or 20 MPH. Land Rovers generally lowered at 31 mph and on the 2017 at a more reasonable 51 mph. If I'm driving over a dirt mountain road (trips to Crested Butte, CO over Kebler Pass comes to mind), I want to be higher up for body protection, greater visibility (seeing and being seen) and in case of pot holes, etc. Hoping BMW changes the speed limitations with a software update, but not expecting it. Also helpful keeping your car cleaner on snowy or slushy roads in town! But your concerns are being on the shorter - I think this car is generally low enough - I still plan on using the lower feature for 83 year old 5'0 mother. Also used the LR feature to lower the tailgate for loading, and while the feature is available on the BMW, I don't see myself using it much - the car really is much lower already. Oh, and the control toggles in the center console do look and feel nice. Also provides the 4 traction control modes - the snow throttle with 20" Nokian H3's has been really wonderful in snow. So one more thing to keep in mind when considering the Air Suspension - Rock, Gravel and Sand I believe are the other offered modes. Going offroad often, the feature is a must for me, but all sorts of benefits, so really enjoy having it. Plus it does seem to ride really smooth. Good luck with your decision! |
tastes jigga315.50 |
01-05-2019, 07:29 PM | #4 | |
Rep 280
01-05-2019, 07:54 PM | #5 |
Rep 141
No problem. I took a few shots when I took delivery last week. Far right switch is for height, left switch is for the various modes.
thekronoschef182.50 ams317715.00 |
01-05-2019, 08:15 PM | #6 | |
Rep 280
01-05-2019, 08:53 PM | #7 | |
Rep 978
The Off Road Package's pre-defined settings (Gravel, Sand, Etc) impact air suspension height. Similar to selecting Sport mode. I only have the Air Suspension. Not Off Road Package |
MatchboxM159.00 |
01-05-2019, 09:44 PM | #8 | ||
Rep 280
jersey john22.00 |
01-05-2019, 09:58 PM | #9 | |
Rep 141
I may be mistaken, but I thought I read somewhere the off road pack would be available with M Sport on later builds. May defeat the purpose a bit - I like the durable trim of the non-M Sport and looks good anyway with Arctic Grey (or at least I'm happy how mine turned out). |
01-06-2019, 09:25 AM | #10 |
Rep 186
01-06-2019, 05:06 PM | #12 | |
Rep 4,246
Other advantages of closed compared to open air supply system: • energy consumption reduced • compressor operating time reduction • higher adjusting speed • weight savings If you're order xLine, 2-axle air (2VR) is $1K. If you're ordering M Sport, you get 2-axle air (2VR) + integral active steering (IAS) for $1300.
01-06-2019, 06:03 PM | #13 |
Rep 186
[QUOTE=If you're ordering M Sport, you get 2-axle air (2VR) + integral active steering (IAS) for $1300.[/QUOTE]
I think the question that has really yet to be vetted is whether or not you’re negatting the sportiness of the M Sport when you add the air suspension and active steering |
01-06-2019, 06:10 PM | #14 | |
Rep 4,246
Just clarifying price and package contents as they didn't specify the model of their design - xLine or M Sport
01-06-2019, 06:59 PM | #15 |
Rep 49
01-06-2019, 07:10 PM | #16 | |
Rep 4,246
https://g05.bimmerpost.com/forums/sh....php?t=1556762
MatchboxM159.00 |
01-06-2019, 07:26 PM | #17 |
Rep 141
Not as good of photos as those above, but here's with Anthracite-Brown Matte Poplar trim with Cognac. Not the vented and expanded leather I wanted, but in stock when I needed a car and VERY pleased with the color combo (Arctic Grey exterior).
01-07-2019, 03:32 AM | #18 |
Rep 157
07-19-2019, 11:47 AM | #20 |
Rep 6
Air suspension
Hello!
Is there any way of getting the air suspension to automatically lower when parked to make it easier to get in and out of the car? |
07-19-2019, 11:54 AM | #21 |
Rep 602
07-19-2019, 02:45 PM | #22 |
Rep 4,246
Unfortunately no, but it would make sense that it should. :
