07-22-2019, 08:15 PM | #45 |
Rep 158
It only works on some roads when functional conditions are met. I imagine they're listed somewhere in the Driver's manual. For instance, the feature works on 80% of a major road near me, but it consistently refuses to work on a particular stretch where multiple lanes merge and the speed limit reduces as you near a traffic signal; it's incredibly intelligent. I'd advise trying it on an interstate with ideal traffic conditions (and you can't have Active Driving Assistant Plus active).
07-22-2019, 09:20 PM | #46 |
1053
Rep 1,951
Can't imagine driving the 401 in such dynamic conditions would warrant driving with cruise control on. The features usefulness is on long road trips where you're on cruise control and you need to overtake slower traffic without cutting off traffic in the left lane. Obviously if there's traffic in the left lane and you need to aggressively overtake the car in front you would bypass this feature and gun it. This feature is supposed to be leisurely.
07-22-2019, 09:24 PM | #47 | |
Rep 2,609
07-23-2019, 12:50 AM | #48 | |
Rep 272
I tried but never got it working. |
07-23-2019, 02:15 AM | #49 | |
Rep 1,236
It is working as it is designed. Last edited by nosnoop; 07-23-2019 at 02:24 AM.. |
07-23-2019, 02:24 AM | #50 | |
Rep 1,236
Have you tried checking the online user manual or the Driver's Guide App in your phone? Those manuals (which uses your VIN) do not display sections not applicable to your car (unlike printed ones). You can check if it contains a section on "Lane Change Assistant". If it doesn't, it is likely not available in your car. |
OzJedi107.00 |
07-23-2019, 06:21 AM | #51 | |
13174
Rep 19,661
Before I got the X5 I thought it would just be a gimmick but it actually a very useful feature as far as making things a little easier. We currently are about 3,300 miles into this trip and I would guess I used it for well over 90% of my lane changes in various traffic conditions. Obviously it is not a necessity, just another of many things in the X5 that makes driving a little easier/more comfortable/less stressful/etc. |
07-23-2019, 08:08 AM | #52 | ||
Rep 2,609
07-23-2019, 09:19 AM | #53 |
13174
Rep 19,661
Having auto lane change turned on or off should have no effect on the performance of ACC or the ability to make manual lane changes. Like you say, to each their own.
07-23-2019, 09:23 AM | #54 | |
Guest
Rep n/a
Drives:
Easy check - CAR Settings-Driver assist-Driving-Steering Assist- if you only have the camera setting listed then its not available. It's disappointing that it not available, as it would work really well on highways with Driver Assist mode engaged, while offering an extra level of safety. |
OzJedi107.00 |
07-23-2019, 09:24 AM | #55 |
Rep 2,609
That is completely incorrect. I obviously meant ACC with lane tracking, not just ACC. If auto lane change is on, signalling activates it and it fights with you. Yes, you can overcome it, but that is nothing resembling smooth driving. With it off, I've described earlier what the system does and it is perfect.
07-23-2019, 09:57 AM | #56 | |
13174
Rep 19,661
07-23-2019, 10:30 AM | #57 | |
Rep 1,236
If you want to signal without auto lane change, just push and release immediately for the 3 flashes (or whatever you set it to). For longer signaling, you can also push past the resistance, auto lane change won't activate in this case, but you have to manually cancel the signaling. Last edited by nosnoop; 07-23-2019 at 10:36 AM.. |
07-23-2019, 08:27 PM | #58 | ||
Rep 2,609
07-25-2019, 02:47 PM | #59 |
Rep 135
It works for me only on highways or wide roads with more then three lanes.
look what I found in owner manual: Functional requirements: ▷ Depending on country specifications: driving on a road without pedestrians or cyclists a with physical barriers to oncoming traffic, such as crash barriers.
BMW X5 2019 - Software version 03/2021.36
Mineral White on Canberra Beige + Walknappa Leather Dashboard |
07-25-2019, 06:39 PM | #60 |
Rep 684
Mine works like a champ where the number of lanes is static, AND there are no merging lanes. Of course the system is looking for adequate distance in the lane you desire to change into. I personally use it very routinely.
2019 G05 X5 40i, Phytonic Blue, Black Extended Merino Leather Interior
07-25-2019, 07:21 PM | #61 | |
Rep 2,609
But after a week of driving with ACC + lane keeping on, and auto-lane change off, I am telling you fellow forumites, that's the way to do it — the system was clearly carefully tuned for that use case. You have to try it to understand, but lane keep —> to lane change —> to lane keep again transition is just seamless in this setup.
07-25-2019, 10:19 PM | #62 | |
Rep 272
Sad, why BMW haven't enabled it but available in GLE. |
08-20-2019, 12:23 AM | #63 | ||
Guest
Rep n/a
Drives:
I've used the system with ALC off for a few months. Using Assisted Driving mode with no ALC is anything but seamless. You indicate, move the steering wheel, then hold and wait in-lane until lane keep/assisted driving mode re-engages. This can take a few seconds and breaks the assisted driving flow. With ALC enabled, again indicate, car moves itself into the lane, carries on driving with Assisted Driving still engaged, no break. Seamless. Is that not your experience? I don't use it in heavy competitive traffic as it takes too long to check it's safe to move, missing lane change opportunities us humans would go for, but in light to moderate traffic it works great. |
08-20-2019, 12:40 AM | #64 | |||
Rep 2,609
I know this is hard to describe in words. I can try for a video, but would have to figure out a camera mount somehow. Update: What you describe I would never call seamless. It occurs to me now that there could be software version differences and/or the behaviour might be affected by other settings such as the sensitivity of the lane departure warning/intervention settings. We might need to document all of that in our respective setups to get to the bottom of this.
08-20-2019, 02:30 AM | #65 | |
149
Rep 320
08-20-2019, 02:38 AM | #66 |
Guest
Rep n/a
Drives:
I emailed bmw UK who said it should have been available on my car.
However, I've coded it myself and I can confirm categorically that BMW have coded it out for the UK market in 2 places - England VO code and 8TR VO Code. Unless a future official code/firmware release changes that configuration, it will never work for us in the UK. It's possible it's in 19-07 but I doubt it. Anyone in the UK have 19-07 and Auto Lane Change? For what it's worth I've been using it for a month and it's a great feature. Last edited by archivedaccount; 08-22-2019 at 02:03 AM.. |
buze132.00 |
