      09-02-2023, 07:02 PM   #1
Dasky_spas
Drives: Bmw
Transmission pan replacement labor cost
Per the title- how much did you all pay to get the pan done? I'm planning to swap in the aluminum oem pan and cut the plastic cover. I already heat wrapped the exhaust pipes that run on both sides of the pan so heat will already be reduced.
sspade2466.00
      09-23-2023, 07:16 PM   #2
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
No no no. Do not use an aluminum aftermarket pan.
Labor rates are local.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      09-23-2023, 09:00 PM   #3
Brandoch
Brandoch's Avatar
462
Drives: 2009 E93 M3 DCT
I guess it depends on what kind of vehicle
      09-24-2023, 09:38 AM   #4
Dasky_spas
Drives: Bmw
8hp76x, same trans in many bmw M cars (75z in m5) so I opted to get the m8 alum oem pan to go on my m850. Same trans, but diff pan options and the upgrade is aluminum with 3" cooling fins; far better than plastic, encased in more plastic.
