09-03-2023, 01:03 PM | #1 |
Rep 1,148
2023 X5 Part Out
Finally getting around to listing the part out from my X5 that I recently traded in. All parts are in good condition, pictures available on request. OEM Black M-Sport Grille (from option 7M9 – High Gloss Shadowline): Asking $175 Touch-Function iDrive Controller w/ Glass option (Part #65829423196): SOLD OEM Wireless Charging Pad w/ NFC (Part #84105A0E550): SOLD Rear Fog Lights (Left and Right) and connectors (New, never installed): Asking $200 Gesture Control Module/Retrofit: Asking $200 Includes the module and necessary wiring to complete the retrofit, coding would be required. See write-up here for an idea of what would be involved. OEM Add-On Towing wiring Kit (New, never installed): SOLD Includes control module (Part # 71606894066), plug/socket, and wiring harness. Also includes the 8-pin connector and wiring bits to install if your car did not come with the 8SL Tow Hitch Prep option. Heated/Cooled Cupholders Retrofit Kit: Asking $375 Includes the center console parts/screws, cupholders, trim, and wiring connectors. Not included but required would be 1 Double flat spring contact for the Fuse Connector and wiring. See write-up here for an idea of what would be involved. OEM Harman/Kardon Speaker set: Asking $400 Includes all speakers, both subwoofers, and the mirror triangles. One foam piece from a mirror triangle is missing, but the foam piece from the HiFi speaker can be re-used. You would also need to remove the foam from the bottoms of the subwoofers and adhere it to the HK subs as they do not come with the foam on the bottom. OEM Bowers & Wilkins Amplifier (Part #65129824561) and wiring connector: Asking $900 Ambient Air Retrofit Parts: Asking $550 Includes Air Freshener, Trim, Ionizer Control Module, Glove Box, Hose, and Air Freshener Bracket, along with 4 Ambient Air cartridges. Not included but required for this retrofit would be the air ducts, ionizer element, and wiring. Note, this retrofit would require removal of the dashboard to complete. Last edited by roxxor; 10-06-2023 at 03:44 PM.. |
09-05-2023, 11:10 AM | #3 |
Rep 1,148
Adding 3 more items I forgot:
OEM Floating Center Caps (Part #36122455268): SOLD TeslaTap 40 - Let's you use Tesla Destination chargers to charge your 45e/50e or any J1772 EV. Asking $70 AeroVironment Dual TurboCord 120/240 charging cable with attachment: Asking $200 Last edited by roxxor; 10-06-2023 at 03:43 PM.. |
09-10-2023, 11:31 PM | #4 |
Rep 2,449
Hi. Interested in a couple of parts. What’s your location?
09-11-2023, 11:32 AM | #6 |
Rep 2,449
Thanks. I noticed the main thing I wanted, which was the towing harness is sold. The other part was the shadow line kidneys. Any idea on shipping to Southern California? 92011.
09-11-2023, 02:29 PM | #7 |
Rep 1,148
10-18-2023, 09:41 AM | #10 |
Wawaweewa
90
Rep 132
Drives: 2020 BMW X5 M50i
can you share more details on the rear foglights? i didn't know you could retrofit therese on the g05
