      05-25-2020, 11:42 AM   #1
qocerhuang
Drives: BMW X5 2019 50i
CarPlay doesn't display apps
It happened to me for couple days now. It is fine for me to call and answer the phone, it also can play the music, but can not open the apps, like the Waze and the google map. Anyone know what is going on with it? Please see the attached pictures, thanks.
      05-25-2020, 12:04 PM   #2
LexxM3
LexxM3's Avatar
1698
Drives: E46M3, G05X5
2019 X5  [0.00]
An iDrive reboot is never a bad idea (press hold volume button for 20-30s until display goes black, then release).
Otherwise, it might be simplest to start over. Disable CarPlay in car, disconnect from phone, clear CarPlay connection on the phone, and start initial CarPlay pairing and connection from scratch. There might be less to do to fix, but you'll waste more time figuring it out rather than starting over. As well, the act of starting over may highlight which (if any) of the many config settings got screwed up for future debugging.
      05-29-2020, 07:16 AM   #3
randybobandy
Rick James
randybobandy's Avatar
305
Drives: 2020 BMW M340i xDrive
Not sure if you got this fixed, but with iOS updates and all sorts of crazy stuff...are the third party apps hidden? I apologize if this seems like I am telling something you already know, but check :
Settings>General>CarPlay...select your vehicle under the "MY CAR" section, then tap Customize. Make sure the apps are not listed under "More Apps".
      05-30-2020, 11:24 AM   #4
Guz
Drives: BMW G05, E60
Same here. It happens to me since software update to 3/2020.40. I lost carplay, spotify, weather widget, even my bmw apps.
Im being loosing something on every updated. 🤬
      05-30-2020, 11:57 AM   #5
X5 45e
1091
Drives: BMW X5 45e
You probably checked this but make sure your phone is connect in CarPlay mode and not in Idrive because that is the default.
Second step would be the good old press the volume button 30 second reset.
And if that doesn't work and you are in CarPlay, switch to Idrive mode and switch back to CarPlay again.
Last would be erase the phone from Idrive completely but I didn't dare to do that because it took me some phone calls to the CD genius before a got connected to the car with my phone. I was afraid to go through the same trouble again. The car was never showing the confirmation code.
I am in Idrive 03/2020 since beginning of March and if I remember I had the same issue but I got I solved by the steps above. Don't remember which. Sorry.
      05-31-2020, 07:07 PM   #6
qocerhuang
Thank you guys, I tried every step still not working.
      05-31-2020, 10:56 PM   #7
Tim2189
Russian in a Bimmer
Tim2189's Avatar
Drives: X5 M50i
Is your phone up to date software wise?
I had issues with appleplay and once I updated it to latest software it was all fixed
2013 X6 - retired
2015 X6 - retired
2015 435GC - retired
2018 X5 40e - retired
2020 X5 M50i - Current
      06-01-2020, 01:16 AM   #8
X5 45e
1091
Drives: BMW X5 45e
Just that and just restarting your phone sometimes also helps. Forgot that one.
      06-01-2020, 02:59 PM   #9
VTENGR
1051
Drives: 2020 X5 M50i
I just had a similar issue. When connected to CarPlay, if I select "CarPlay" to get to my apps, it just shows the CarPlay icon, but never gets to the home screen where all the apps were. I noticed something was up before then because when I would get a call, the caller ID wasn't showing up on my screen. Rebooted iDrive and everything is working fine now.
edit: to reboot iDrive, hold down the volume/on/off knob for 30+ seconds until the system shuts down.
      06-01-2020, 07:13 PM   #10
Guz
I follow your steps and didn't work. After a quick troubleshooting with BMW Genus I end up taking the vehicle back to the dealer for run the software update. Should be able to get it back tomorrow... Let's see what happened...
      08-01-2021, 05:22 PM   #11
Maximus2021
Drives: 2021 BMW X5
2021 X5 No Display
Anyone have nothing on the new X5 display?
