05-30-2020, 10:17 AM | #1 |
Rep 97
New to coding
Hey guys
Im new to coding using bimmercode, and im currently scheduled to service the car on Monday, Do i need to reset everything i coded? Will it cause warranty issues? Will it be visible to the dealer?? Thank you |
06-04-2020, 08:46 AM | #3 |
1053
Rep 1,952
The coding that you do on bimmercode and to some extent Esys is not "coding" in the true sense of the word. Coding implies that you're changing the source code of the software to suit your needs.
What we're actually doing with bimmercode "coding" is unlocking features that are already programmed in the software, but are disabled for one reason or another. For example, "coding" the 5-blink turn signal doesn't require the user to apply special programming structure to the car to add that. It's simply going into the software and changing "disabled" to "enabled". For whatever reason, BMW has it disabled in some markets. With all that being said, I'm sure a savvy service tech will notice the difference. I'm also pretty confident that they won't care - most coding done is superficial and doesn't actually affect the performance of the car. Why would the service tech care if your car is showing the Alpina dash instead of the stock BMW one? With that in mind, you shouldn't see any warranty issues either. That's not to mean that if you go into "expert" mode on Bimmercode (or use Esys) and start haphazardly changing things that you have no idea what you're doing, that could cause the software to act in an unexpected manor, in which case, I don't think BMW will fix it under warranty if they can show you're the one who caused the issue. |
