05-30-2020, 02:06 PM | #1 |
Rep 12
Parking Assistant Plus Issue
Hello;
Despite I have the Parking Assistant Plus 5DN, I can use the car autopark in the parallel direction and not in the perpendicular direction, when I asked my local agent, he said that due to some certification issue the earlier G05 deliveries had this option disabled. Any one knows the affected ECU to code and enable the auto parking in both directions please? And if it can be done using Bimmercode expert mode? |
05-30-2020, 09:24 PM | #2 | |
805
Rep 1,789
05-31-2020, 01:21 PM | #3 |
Rep 12
Thanks for your reply, but I have tried all possible positions and did not work, also the agent has admitted that it is not enabled in the perpendicular direction, the only way is to code it if I can get the right ECU entries.
06-01-2020, 03:47 PM | #4 |
1197
Rep 1,587
If you send me your FA and SVT I can check what is likely to be blocking.
06-02-2020, 02:45 AM | #5 | |
Rep 18
06-02-2020, 02:10 PM | #6 |
Rep 12
I have been at the dealer few days back and now the car is on 20-3 and still not resolved, he claims that this is due to the early car production 2018-11-18 which I don't buy it.
06-02-2020, 06:53 PM | #7 | |
Rep 251
I just saw your above post too. My vehicle is a Oct 2018 build. The software update fixed it. I am presently on 03.2020.xx and it still works. |
06-03-2020, 01:18 AM | #8 | |
1197
Rep 1,587
You have a build version of 1118 which is stored in your FA, and the coding of your car will be based on that and other factors. It's probably an easy coding fix. |
06-03-2020, 05:12 AM | #9 | |
Rep 12
Can you please advice if this can be done via VO or it requires FDL coding and the related entries. Thanks |
06-03-2020, 07:11 AM | #10 | |
1197
Rep 1,587
I could normally figure it out independently, but don't know how a Dubai vehicle is configured - ECE, USA type, language version etc... hence the ask for the FA and SVT |
06-05-2020, 12:13 PM | #11 | |
Rep 12
ifr; thanks a lot for your genuine intentions. |
