12-26-2023, 04:44 PM | #1 |
Member
73
Rep 19
Replacing the gear selector on 2024 x5M60
I'm about to pull the trigger on a new 2024 X5M60, but I can't stand the new gear selector knob that has replaced the standard shifter. I am willing to buy the full shifter assembly (including the dial control, starter button,....) that comes standard on the X5M Competition, but not sure where to find it or if my dealership would do the work to make the replacement.
Has anyone attempted to make this alteration on a 2024 X5 with this new (awful) shifter? |
12-26-2023, 05:41 PM | #3 |
Rep 8,064
Drives: 2024 X5 M60i
I thought I’d miss the shifter when I made the move from a G80 to the X5 M60i. I’ve had it just over a week now and am used to the new shift experience and don’t mind it at all.
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
12-26-2023, 07:34 PM | #4 |
Rep 2,073
Some 3 series owners have swapped the LCI mini shifters to pre-LCI shift knobs, and others have done the opposite swap. Some even found it to be plug and play.
https://g20.bimmerpost.com/forums/sh....php?t=1963153 But installing an M shifter in a non-M has never been doable AFAIK, so you'll need to install a non-M shift knob if you decide to go ahead. |
12-27-2023, 09:47 AM | #6 |
1228
Rep 1,350
I thought I would miss it also but do not in the least and prefer the current config. None of these are actual shifters with mechanical connection to the transmission as they were years ago and have become nothing more than switching gear of various shapes and sizes.
12-27-2023, 09:50 AM | #7 |
Rep 1,364
12-31-2023, 06:50 PM | #9 |
Rep 279
Drives: 2024 BMW X5 G05 LCI
I am in the process of the swap from LCI to Pre-LCI as we speak. Pics of old and new below. Running into a problem disconnecting the wires from the harness of the center console/iDrive system now that I have it disassembled. I cant pull two of them out, and wondering if anyone has run into this problem?
01-02-2024, 01:00 PM | #10 |
Rep 2,858
Would the M drive logic cause an issue, but assume that it’s the same transmission now that both the X5M and M60i share the S68.
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
01-02-2024, 02:54 PM | #11 |
Rep 2,073
01-02-2024, 03:35 PM | #12 |
Rep 2,858
That’s what I thought, as it would have to be coded to work and BMW has transitioned to closed system with iDrive 8.5 with the new head unit. OP could spend an additional $600/month for the X5M comp with the shifter he desires.
aussieintexas222.00 dwwStL163.00 |
01-06-2024, 06:27 PM | #13 |
Rep 279
richwonders1 Finally got around to installing it!
And the X does light up! |
11
matowi293.50 Ibiza3614.00 bluegill16.50 mushy_musashi133.00 KB7120.00 mobilejo1116.00 richwonders173.00 Major-Zebra58.00 doctorwizz28.50 1230vani660.00 jayfeinst49.50 |
01-06-2024, 09:08 PM | #14 |
Rep 7
01-07-2024, 05:23 PM | #17 |
Rep 279
No prob. I’ll try to do my best in laying out the details and provide pics and links.
I’ll post asap! |
01-07-2024, 05:32 PM | #18 |
Rep 4,374
Very interesting, I actually like the LCI center console/short shifter better. I find my pre LCI glass shifter in the way and full of finger prints. That said, I would actually like to see the little tiny LCI shifter made out of clear faceted plastic/glass with some sort of light in it as I do like mine at night when it lights up.
01-07-2024, 05:43 PM | #19 | |
1228
Rep 1,350
TN2SC2020153.50 |
01-07-2024, 07:39 PM | #20 |
Rep 3,940
01-09-2024, 07:48 AM | #21 | |
1228
Rep 1,350
Have Ferrari, Porsche, Lamborghini, eliminated these pacifiers to "save money" also? |
Cityman188.50 |
01-09-2024, 08:48 AM | #22 | |
Rep 4,374
JoeAyalaM157.50 |
