TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > window rattle... fixed?!?!?!
      05-09-2011, 03:32 AM   #23
bogi
Drives: bmw 320D E90
oopss
the silicone spray works for only 2 days, after that the squeaks/creaks started again. Probably need to change to gummi pfledge after this. Turns out, in the manual it does say do not use silicone spray...
      05-17-2011, 03:04 PM   #24
kevina2
kevina2's Avatar
Drives: 2007 BMW 335i E93
Gummi Pfledge
The two bottles I ordered just showed up. $8.79 CDN each. I'll try them out but I'm not to sure that I will know for sure until next fall/winter. I'll let you know.
Kev
      05-26-2011, 06:41 AM   #25
bogi
not 100%
I bought 'rubbercare', a BMW part sold by BMW dealer and the bottle doesn't look like the Gummi Pfledge in the picture above. It did improve the problem up to I'd say 80-90% to date . However, there is still some rattling sound inside the door trim... probably a bolt loose, not a rubber ageing problem?
      06-03-2011, 01:03 PM   #26
bogi
recurring
It seems, the problem was solved temporarily by the rubber care spray. After 10 days the problem recurs.
      06-21-2011, 09:40 AM   #27
cholowiski
Drives: 2006 325i
Did the gummi pflege work? Did it last very long?
      06-23-2011, 05:40 AM   #28
bogi
rain helps
u know what, now that it rains very often, the squeaks/rattles form the window/door is greatly diminished! It's almost gone I'd say! We should lubricate the outer side of the rubber strips then! All the rain does is wet the outer part of the rubber seals but we tend to normally lubricate the inner side of the seals. learning from this rain experience, maybe we should try lubricate the inner and outer side of the seals as well?
      06-23-2011, 09:27 PM   #29
Tzu
29
Drives: 335i
Yes you need to rehydrate the rubber. What happens to dry condoms?
      12-08-2011, 08:19 PM   #30
Ryebread
Diesel Fitter
Ryebread's Avatar
Drives: 335d m-sport LMB
I have just started to hear a P side door WINDOW rattle.
2011 e90
I didn't see any other threads on window rattles, so I'll check this out, thx.
      08-31-2012, 09:55 PM   #31
hadoob024
hadoob024's Avatar
Drives: 2009 E90 M3
2009 BMW E90 M3  [0.00]
I think I'm experiencing something similar, but not sure. Is the issue here an actual rattling sound or is it more of a rubbing/creaking sound? Seems like anytime I go over a bump I hear this weird sound (like rubber rubbing on rubber). I have tints on the car, and the sound almost does sound like rubber rubbing on rubber or plastic or something. And I have noticed that its more noticeable in the backseat. Its driving me crazy though. Can anyone confirm the actual sound being made? Thanks!
      08-31-2012, 11:14 PM   #32
munna
129
Drives: 2018 X3
I had the door rattle (on both doors). The dealer replaced the seals and even the door latches (inside the door) but it did not fix the problem. I wrapped black electrical tape around the door latch hook on the body. The sound completely went away after that.
      08-31-2012, 11:43 PM   #33
hadoob024
hadoob024's Avatar
Drives: 2009 E90 M3
Hmmmmm... That sounds more like a rattling issue and not this rubbing/creaking issue that I'm hearing. Glad that fixed your problem though.
      09-02-2012, 03:03 PM   #34
Ryebread
Diesel Fitter
Ryebread's Avatar
Yes!!!!!!! It's amazing.
      11-23-2012, 04:48 PM   #35
starbai
PPRSWCE
starbai's Avatar
Guyana
654
Drives: 18 Tanzanite Blue F80 ZCP
Just ordered... Gummi Pfledge from Amazon.com... will report back on whether or not it fixed my window rattle....
      04-29-2013, 02:06 AM   #36
JET335
JET335's Avatar
Drives: E90 LCI 335i
The interior of my doors squeeked when the car shifted, so i asked the BMW tech when i had a visit. They use and recommend Static Guard (http://www.amazon.com/Static-Guard-C.../dp/B0013IRBG4). Ive been using it whenever I hear a creak and it works great. Just spray it on the rubber sill of the outer edge inside the door.
<div align=center>
E90・LCI・335i・LUX H8 V3・VORTEX LEMANS・BMS DCI
      12-06-2013, 08:41 PM   #37
jyd78
Drives: E92
did it work? please let me know, this rattle on my car is driving me NUTS
      12-07-2013, 08:22 PM   #38
Ryebread
Diesel Fitter
Ryebread's Avatar
How many times do u need to say it? This stuff is the biznass.
Buy it.
It's a miracle worker.
      12-08-2013, 02:50 PM   #39
FCobra94
Guest
n/a
Drives:
Thanks for bumping this...I have a similar issue. Gummi should be here in a few days so I hope it does the trick.
      12-10-2013, 01:44 PM   #40
starbai
PPRSWCE
starbai's Avatar
Guyana
654
not entirely... it was a bit better but not fixed.
      12-13-2013, 06:20 AM   #41
mlifxs
Diamond Geezer
mlifxs's Avatar
212
Drives: Jet Black 2007 328i Saloon
another suggestion is white lithium grease (tube) . wipe excess or it leaves white-ish film, but works well and most auto parts stores have it
      03-02-2014, 12:43 PM   #42
Casca
Drives: E90 6MT
I had a little bit of creaking from the rear doors and read about gummi pledge so gave it a try. Creaking went away. I was impressed, so used it on all the rubber seals. Everything was good.
4 or 6 months later, major creaking (winter). I put more gummi pledge on, no improvement. It got warmer, but still a lot of creaking. MUCH worse than before I used gummi pledge. Tried even more gummi pledge, still a crap ton of creaking noise. Read more about it and how BMW stopped using it and recommends not to use it.
So I got a rag, soaked it in soapy water and wiped down all the rubber seals to get gummi pledge off. Zero creaking noise after that. I just it did it today, so who knows how long that will last.
With gummi pledge, I was just adding it on. I didn't go through cleaning the seals first or anything. I think the build up of anything on the seals probably just makes things worse. Probably best to throughly scrub/wipe the seals with mild soapy water (I used palmolive) and then apply the gummi pledge or maybe no gummi pledge at all.
Edit: lasted 1 day before creaking returned full force. Ordered Zymol Seal. http://www.amazon.com/gp/aw/d/B003AN...3869396&sr=8-1
      07-14-2015, 04:05 PM   #43
Mroy
Mroy
United Kingdom
Drives: BMW 3 Series Saloon
Hello all
I have an 8 year old E90 with 92K miles on the clock. Meticulously serviced by the previous 2 owners. Unfortunately however I hear rattling noises particularly when the car has been sitting in the sun for a while (the noise magically disappears when it rains!).
Following reading this post, I used Gummi Pflege several times to clean the seals. The rattle persists though and I think it is the windows (the noise also disappears if I wind them down half way). Does anybody have any suggestion on how to resolve this without spending too much?
Thanks
      07-14-2015, 07:56 PM   #44
mlifxs
Diamond Geezer
mlifxs's Avatar
212
Originally Posted by Mroy View Post
Hello all
Thanks
I found this thread to be helpful as well:
http://www.e90post.com/forums/showthread.php?t=231670
In my case, my car has shadowline trim, as described in the thread. The solution shown has helped reduce my door rattles, though the application needs to be repeated about once a month.
Another thing I think helps (maybe) is: if you apply Gummi Pfledge or other compounds to your seals, leave your doors open for a couple hours after application to let the seals expand a bit. Worth a try at least.
