03-02-2021, 09:32 AM | #309 | |
12971
Rep 18,716
Because on where it is positioned, even without Neoprene, it will be tough to adjust. I normally take them apart again to adjust it. The time it takes between adjusting it while in the car and out the car, is about the same. Out the car will be less muscle work. Based on my testing, best setup is 0mm gap on the front and 10mm thread gap on the rear adjuster.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
03-02-2021, 06:25 PM | #310 |
Rep 6
Im not sure if anyone with no, but I was thinking of putting the bump stops from F90 M5 on when doing install of springs. Ive heard these are shorter in design to the F95 X5M. Also does anyone know if there would be a compatibility issue?
03-02-2021, 09:03 PM | #311 |
Rep 254
r33_RGSport12971.00 |
03-03-2021, 05:20 AM | #312 |
Rep 192
***UPDATE***
My car which had the sway bar link Knock noise has now been rectified by the dealer and fix notice has been issued by BMW. |
r33_RGSport12971.00 ed41367.50 |
03-03-2021, 05:33 AM | #313 |
Rep 290
03-03-2021, 08:07 AM | #314 | |
12971
Rep 18,716
It seems like either there is a defect on the sway bar link or the lower arm. Where it creates some tolerance and even with recommended torque, it still have some play under load.
ed41367.50 |
03-03-2021, 11:49 AM | #315 |
3102
Rep 1,823
Great news! Could you please share the BMW work order ?
ed41367.50 r33_RGSport12971.00 |
03-03-2021, 11:57 AM | #316 |
Rep 732
Second that - please
Thank you in advance
'23 F93 M8 GC ZCP - HRE S101SC - Full Akrapovic - '15 Audi R8 4.2 S-Tronic (Past) YouTube '21 F96 X6M ZCP Akrapovic/MSS/BC Forged, 18 G30 M550i, '18 G01 X3 M40i, '15 F10 M5 ZCP HRE S101 #1 & #2/Akrapovic, 13 W204 C63 AMG - ADV1 5.01SL's |
03-03-2021, 12:52 PM | #317 |
12971
Rep 18,716
QF8 shared the information with me.
But, since it is not in BMW bulletin yet, it is not 100% official. Pretty much there is a gap between the lower arm and sway bar link itself. Based on QF8 car, it is 1mm gap. So, his local dealer installed a 1mm washer to fill in the gap. I believe this gap can be closed by tightening the bolt as I mentioned before.
03-03-2021, 05:54 PM | #318 |
514
Rep 1,437
I know this is mainly an MSS thread, but curious as to any feedback on the H&R setup.
2022 Individual M5 Comp
Venetian Violet 2021 X6M Comp 2024 i4 M50 on order IG @purpleM5Comp_NY |
03-03-2021, 08:06 PM | #319 | ||
12971
Rep 18,716
I have 1 set in stock and a few more on its way. Maybe you can get it and give a review.
03-03-2021, 08:53 PM | #320 | |
Rep 8,815
03-03-2021, 09:25 PM | #321 | ||
12971
Rep 18,716
03-06-2021, 12:09 AM | #322 |
Rep 95
Finally got around to lowering mine
Shout out to Ben @RG Sport for the MSS Springs Also Shout out to ACHTUNING for doing the install For anyone on the fence about this. DO IT !!!!! It looks so much better and like others have commented the drive is a bit more softer, i have no issues with it. Actually truck is my wifes and she would prefer it a little less bumpy I did the full drop on the front and kept it 10mm above max drop in rear. Now one of these days i will get around to installing my racechip. |
03-06-2021, 07:34 AM | #323 | |
12971
Rep 18,716
It looks perfect.
ed41367.50 |
03-06-2021, 06:48 PM | #324 | |
Rep 732
I'm hoping wifey asks for spacers next
03-06-2021, 07:26 PM | #325 | ||
12971
Rep 18,716
ed41367.50 |
03-06-2021, 08:27 PM | #326 |
Rep 8,815
MSS finally installed. Had the shop tighten the sway bar endlink plus the neoprene fix for the rear. Happy to report zero noises so far. I used Ben's recommendation max drop up front and 10mm gap in the rear which to me looks perfect without the rear looking droopy.
Thanks Ben@RGSport! (Winter Wheels are Vossen Anthracite HF-5 in 21/22 combo. New Summer setup going on soon)
03-06-2021, 09:10 PM | #327 | |
Rep 732
The 10mm drop in the rear means there's a 10mm (1cm) gap in the rear? I like your setup & plan to copy yours - thank you in advance!
03-06-2021, 09:14 PM | #328 | |
12971
Rep 18,716
03-06-2021, 10:10 PM | #329 | |
Rep 8,815
It’s the setup Ben recommends and the 10mm is the gap on the MSS rear adjuster before it’s at max drop. Last edited by Alan l.; 03-06-2021 at 10:50 PM.. |
03-06-2021, 11:06 PM | #330 | |
Rep 732
Thank you very much!
