04-04-2021, 12:04 PM | #1 |
147
Rep 313
Stripped Lug Bolt
I'm wondering if anybody would be able to help me identify the part number for this lug bolt for the X5. I did a number on the bolt and hole changing out my winter tires and I can't seem to find the exact replacement online.
Also, if anybody knows the thread pattern because a friend of mine is going to help retap the hub.
2023 BMW X7 LCI M60 (On Order) 2020 BMW X7 xdrive40i M Sport Phytonic Blue 2019 BMW X5 xdrive40i Mineral White |
04-04-2021, 12:14 PM | #2 | |
Rep 4,246
M14 x 1.25 https://www.getbmwparts.com/oem-part...ck-36136795153
04-04-2021, 02:28 PM | #3 | |
Rep 2,609
Can we conclusively determine if that part number is in fact a two piece? Regardless, two piece and one piece lug bolts should not be mixed on the same wheel and probably should not be mixed on the same car.
adamjs83147.00 |
04-04-2021, 02:34 PM | #4 |
Rep 8,700
Drives: eVeRyOnE mAD!
I believe default thread length is 27mm?
phillydilles74.00 |
04-04-2021, 03:16 PM | #6 | ||
147
Rep 313
04-04-2021, 03:41 PM | #7 | |||
Rep 2,609
But first things to figure out is a) if that part number is one or two piece, and b) if not two piece, what the two piece part number is so that you can just buy one. For the record, I am not a fan of the two piece design and if you search carefully, you'll find a fair number of people (including myself) where the sleeve/washer got embedded in the rim. My tech lead agrees and my dealer replaced all my two piece bolts by the "old fashioned" one piece on my request (so, by the way, I still have 20 stock two piece bolts sitting around doing nothing). I have never found a good reason for the change to two piece design except that it theoretically doesn't scratch the inside of the rim lug hole since the bolt rotates in the sleeve rather than the hole; but that "benefit" is overwhelmed by the proven possibility of the sleeve embedding itself in the hole. Here are a couple of example issue threads: https://x3.xbimmers.com/forums/showthread.php?t=1711680, https://x3.xbimmers.com/forums/showthread.php?t=1739276 I am also wondering how you managed to strip yours like that? Whatever the root cause of that was, hopefully you've rectified it before putting the car back on the road.
04-23-2021, 05:47 AM | #8 | ||||
147
Rep 313
I have no idea, brute force and frustration with an overly powerful impact wrench? Lesson learned as I ended up having the entire hub replaced at a local service station. They ordered that part number for the lug bolts and it was in fact the two piece.
LexxM31698.50 |
04-23-2021, 08:46 AM | #9 | |
Rep 1,449
Glad you were able to get in fixed and taken care of. Switch to hand tools and avoid the impact wrench. I learned in my early car days when I didn't change the wheels myself what damage an impact wrench can do watching fools at NTW (now NTB) doing tire changes.
No. Try not. Do. Or do not. There is no try.
-Yoda |
04-23-2021, 10:27 AM | #10 |
Rep 264
I have no idea, brute force and frustration with an overly powerful impact wrench? Lesson learned as I ended up having the entire hub replaced at a local service station. They ordered that part number for the lug bolts and it was in fact the two piece.[/QUOTE] I ordered bolt hangers to help mount wheels to avoid the stripping of bolts. Hopefully this will help me prevent the stripped bolts
2019 M5 Competition
2021 X6 xDrive40i M Sport 2018 Toyota RAV4 AWD 2008 Corolla S Souped Up - The Black Widow |
04-26-2021, 07:57 PM | #11 |
Rep 6,805
While an impact wrench is fine for removing bolts, I always use a manual wrench and torque wrench to install them...it's too easy to mess things up when installing the bolts with an impact wrench. I don't really trust the torque limiting sockets...they may work just fine, but I think some of that is the pressure used, and skill level...a torque wrench is easier to use IMHO.
05-04-2021, 05:45 AM | #12 |
Rep 589
What comes from BMW originally is two piece design? Why I was under the impression mine was a single piece?
05-04-2021, 06:20 AM | #13 | |
Rep 2,609
05-04-2021, 06:25 AM | #14 |
Rep 589
I will check mine.... what's the point of these overly complicated design for a simple mechanical bot? Just make it solid piece and give the owners peace of mind.....
05-04-2021, 06:36 AM | #15 | |
Rep 2,609
05-04-2021, 07:43 AM | #16 |
Rep 709
Hey,
from a technical point of view is the spherical collar, which is now mandatory for most manufacturers, a torque relief for the rim. While the wheel stud rotates, the ball collar stops and presses on the rim without any frictional forces. Without a spherical collar, the high torque would cause the wheel studs to rotate / grind into the material of the rim. |
05-04-2021, 08:13 AM | #17 | |
Rep 2,609
Also, how does this concept work for hub studs rather than our bolts? Are lug nuts now to also to be double piece?
05-04-2021, 01:46 PM | #18 |
Rep 6,805
Probably since the invention of nuts and bolts, having a washer under the nut is standard practice. Sometimes, they also call for one underneath the head as well, but normally, when a nut is involved, you hold the head stationary, and turn the nut. In the case of the wheels, you are turning the head, so you will be damaging the finish on the wheel as you tighten it up unless there's something to prevent that.
05-04-2021, 04:12 PM | #19 | |
Rep 2,609
05-04-2021, 05:30 PM | #20 |
Rep 589
I took the picture today. The OEM part is a 2 piece design, but I don't see any movable washer you all mentioning. Am I missing something here? Is the grey cone shape part the washer? In my mind, washer is a flat piece (flat washer, lock washer)
ladra17.50 |
05-04-2021, 06:25 PM | #21 |
Rep 2,609
The silver-coloured part is the "washer". Twist it, it will freely spin but is restricted from moving up and down the bolt. For some reason I always want to call it a "sleeve", but others call it a "collar" which is probably the most correct name out of those 3.
