07-23-2022, 07:46 AM | #1 |
Rep 169
Detail Supplies Organizer Needed
I need a good idea for holding my car detailing products that is portable from garage to driveway for washing and detailing my X5. Is there a great organizer that will fit the bill? I hope to place exterior and interior products in the organizer.
07-23-2022, 12:04 PM | #2 | |
Rep 3,041
Drives: 2022 BMW X5
check out Amazon, there are plenty of options there, just look at ratings and read reviews.
07-25-2022, 11:01 AM | #3 | |
42
Rep 38
i put the below deionizer on the cart for my rinse water that i put a quick disconnect on the hose outside. https://www.rvupgradestore.com/On-Th...tg2-ddi-bf.htm then put the CR spotless deionizer on the water feed to my pressure washer setup. https://www.detailedimage.com/CRSpot...00-Gallons-S2/ Wall mount pressure washer with auto on and off with pull of trigger. https://www.pressurewashersdirect.co...er/p99067.html |
07-25-2022, 02:58 PM | #4 |
Rep 508
Drives: 2022 X5 xdrive40i msport
Really not sure what you're asking to be honest. You want a cart to roll around the vehicle when working on it or a shelf to keep things close and organized ?
I will show you what I did if it helps. I also have a DI water system from Adams Polishes inline with my AR Clean 630TTS pressure washer. the cart I got from Adams Polishes as well. Last edited by 1Mors; 07-25-2022 at 03:08 PM.. |
