11-14-2019, 08:32 AM | #529 | ||
2020 Mineral White 30d MSport
523
Rep 2,146
Drives: 2020 Mineral White 30d MSport
In my case my dealer knows about it, maybe I'm not concerned because I'm a friend starting from the owner to the guy that washes the cars after service, they also knew about my CarPlay interface i had on my former F15 In countries so small like mine things are done different and probably more personal, that's an advantage
11-14-2019, 06:01 PM | #531 |
Rep 802
Sorry .. where do I go for expert mode? I can't seem to be able to find it?
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
11-14-2019, 06:13 PM | #532 |
Rep 802
I only seem to be able to go into expert mode in the "Roof Function Center" (FZD_35) module. None of the other ones have "Expert Mode" as an option?
11-14-2019, 07:21 PM | #533 | |
91
Rep 306
11-14-2019, 07:23 PM | #534 | ||
Rep 802
11-14-2019, 07:25 PM | #535 |
Rep 5,447
Are you IOS or Android and what version do you have?
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
11-14-2019, 07:33 PM | #536 | |||
91
Rep 306
11-14-2019, 08:34 PM | #537 | |
Rep 802
11-14-2019, 08:41 PM | #538 | ||
Rep 252
Yes at this stage. If you do not want to beta test, ver 3.4 should be publicly released, one would assume, in the next few days to weeks, depending on feedback and fixes identified by the beta testers. |
11-14-2019, 09:27 PM | #539 | |||
Rep 802
11-14-2019, 11:10 PM | #540 |
Rep 430
11-15-2019, 08:53 AM | #541 |
91
Rep 306
07/2019.70 not all green. Those pictures was in demo mode
11-16-2019, 10:50 AM | #542 |
Rep 421
My X5 having been updated yesterday, I attempted to re-code ASS. When starting Bimmercode it indicates "Updated coding data available", advising update is necessary to connect to the vehicle.
Selecting 'update now', briefly displays 'Updating now', then 'Coding data update failed - an error occurred while updating the coding data'. Any suggestions as to what to try next? I'm running Android 8.0.0 on a Galaxy S7. This is only the second time I've run Bimmercode on this device, the first time being a few months when it worked flawlessly. |
11-16-2019, 01:00 PM | #543 | |
Rep 421
To update coding data, the Bimmercode app itself needed to first be updated. That had occurred to me, but selecting Bimmercode within my phone's app manager didn't show an 'update' option. Loooking at this again, I selected 'App details in store' and did I find an app update option there. Updated the app and now Bimmercode was able to successfully update the coding data. |
LexxM31698.50 |
11-18-2019, 06:07 AM | #544 |
Owner
132
Rep 566
Drives: G05 30d M-Sport
Just decided to bite the bullet and buy an OBDLInk MX+, and bimmercode. However it doesn't seem to be working with Android. The app 'fails to connect' -- seems the connection is dropping all the time.
I managed to update the firmware using their own app, but it does the same with their's as well. Moving the phone closer doesn't help at all, I'm like 30cm from the adapter and that doesn't help. BummerCode!
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
11-18-2019, 03:05 PM | #545 | |
Rep 810
1. Make sure in the Bimmer App on your phone, under settings - the "OBD LX/MX/MX+" adapter is selected. 2. Ensure your phone is on "Airplane Mode" prior to trying to connect, but remember to re-enable Bluetooth. 3. As Bluetooth is re-enabled, go into your car settings and ensure your phone is "Disconnected" from the Car. I am sure you have your phone paired with your car via BT, so this needs to be disconnected - else the phone's Bluetooth cant pickup the OBDLink dongle. 4. Make sure the car is in Diagnostic mode - press the Start/Stop button 3 x times in quick succession and wait around 5 seconds - you will hear a gentle ring alarm and then "vehicle in diagnostic mode" come up in the Instrument cluster. After the above, it should connect It can be somewhat "unreliable" in connecting, sometimes I have try a few times - so be patient, but once connected its as solid a rock, I've never had it dropout or fail while reading the ECUs or coding. Last edited by James_G0540i; 11-18-2019 at 03:10 PM.. |
11-19-2019, 12:16 AM | #546 | |
Rep 199
If yours doesn't work, it may help to try the tricks. You might also want to try other simpler apps (such as OBDLink's own) to figure out which component is making trouble (phone, BT, MX+, app). Last edited by perikifi; 11-19-2019 at 01:24 AM.. Reason: Added OBDLink app |
buze132.00 |
11-19-2019, 05:48 AM | #547 | ||||
Rep 810
I never said you need to unpair your phone, just disconnect it from the Car via iDrive. The last time I checked, you can only connect to one Bluetooth device at a time from your phone, so if your phone is connected to the car, how will it Connect to the MX×? |
11-19-2019, 07:34 AM | #548 |
Owner
132
Rep 566
Well I managed to get it working, using a combination of what was suggested...
+ Airplane mode + Disable the Bluetooth of the car + Enable Bluetooth on phone That works. I tried again without airplane mode, and it worked too, so I suspect it's the phone<->car chatting that confuses the BT stack... Anyway I managed to code assisted drive view in 'expert mode' -- but nothing else is really available in my Android version... I'd like the lane-change-assist at least -- would the 'beta' allow me to code that? I used the github XML page as a reference, there's quite a lot of stuff in there, but none can be accessed via the app...
11-19-2019, 08:17 AM | #549 | |
Rep 2,609
Nonetheless, your advice matches the stated requirements from Bimmercode developer and modern smartphones (and BMWs) are also full bugs and corner cases, so it is best to follow the instructions precisely.
11-19-2019, 09:04 AM | #550 |
523
Rep 2,146
New update on beta test flight
