11-20-2018, 04:11 PM | #1 |
Rep 238
Cigarette lighter plug issue
Anyone try to plug something into it, like a radar detector? I tried both the front receptacle and the one under the climate controls in the rear and both wont hold any adapter deep enough for the pin to reach the base. If I press is down it works, the second I let go it gets pushed out a few mm and looses contact. The one in the trunk works no problem.
12-23-2018, 05:51 PM | #4 |
Rep 205
Same. Multiple El cheapo USB chargers fail to get power from the outlets. Is it really a depth issue? Or some proprietary design that prevents "standard" devices from working?
12-23-2018, 06:00 PM | #5 | |
Rep 631
12-23-2018, 06:24 PM | #6 | |
17
Rep 40
12-23-2018, 06:41 PM | #7 |
Rep 1,448
I have a BMW charger that should work in all the plugs, but in terms of RDs the front plugs with my Uniden R3, but not my V1 (now hardwired) or Escort 360.
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
12-23-2018, 07:00 PM | #9 |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
There are two sizes. Size A and Size B. The US has a standard, Europe doesn't. The two sizes are very close to each other, so much so that there isn't any obvious difference between the two, but resulting in sloppy fit or a very tight fit. I don't remember which is which, as it's been many years since I tried using one. BMW's (and a couple other European manufacturers) have always been just a little difficult to make their plugs fit right. I always hardwire my radar detectors into my cars.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
12-23-2018, 07:25 PM | #11 |
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
I know that the BMW adapter fits just fine, not sure about others.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
12-23-2018, 07:29 PM | #13 | |
Rep 978
Yes Jay - the BMW one works great. Middle one too. Right one - can't get it in enough to make contact - at all. That's the first socket that charger hasn't worked in and it's traveled with me for years. Weird. |
******2084.50 |
12-23-2018, 07:31 PM | #14 | ||
Rep 205
12-24-2018, 06:55 AM | #16 |
Rep 105
I have the wireless charging tray but as a backup, when my wife is with me, I ordered a USB-C cable to use with her Samsung. I figured it was power supply for behind the front 2 seats so perhaps it will provide power in the center console as well. The cigarette lighter one I have seems to work but it is not secure enough to maintain the contacts. In my previous BMW the cigarette lighter cable would light up when working in the X5 nothing.
12-24-2018, 07:45 AM | #18 |
Rep 1,448
I have an older version of this device that I need to locate.
12-24-2018, 10:28 AM | #19 | |
Rep 1,448
When I saw that USB-C cables came with my iPad Pro3, I was frustrated about another new set of cables (esp after having to buy new cables in Macau after leaving a set in a Taipei airport lounge). Now, I at least get multiple uses of all these new cables I had to purchase.
12-25-2018, 07:52 PM | #21 |
Rep 238
What's the worst thing that can happen other than fuse blowing if I put a little piece of aluminum foil in there? This way the tip of the plug stays in contact with the base of the lighter socket? I just don't have the time to go in for appointment to have this looked at right now. Just can't live with my max 360.
12-25-2018, 08:29 PM | #22 |
Rep 978
