12-17-2018, 09:04 PM | #1 |
Rep 668
Noise from rear when going over bumps at slow speed
When I am driving <20 mph and going over bumps, I am hearing a "clack" or knocking sound coming from the rear. I've checked everything on the interior to make sure everything is secure, but I can't seem to find anything. Anyone else hearing this? I wonder if it's coming from the suspension.
12-17-2018, 09:37 PM | #2 |
Rep 6,121
Could it be a loose spare tire?
12-17-2018, 09:37 PM | #3 |
Rep 17
Same issue with knocking/popping noise coming from the right/passenger rear side when going over a bump, especially a sharp bump.
Built in Oct 2018. It's getting quite annoying. Have a service appointment this coming Thursday. I'm 75% certain the popping noise is generated by the rear seat / airbag next to the door. The seat and airbag seem very loose and make popping sound when bumping on them. Definitely defective fittings or a design flaw. $70K vehicle should not produce abnormal noise like this. Minus the noise, loving this X5 G05. |
12-17-2018, 09:43 PM | #4 | |
Rep 668
I don't have a spare, so can rule that out.
12-18-2018, 10:39 PM | #5 |
Rep 293
I have owned 4 BMWs and every single one of them has had some sort of creak, buzz, rattle, etc. Picking up my X5 on Friday and I’m terrified it’s going to have the same issue as the others.
12-19-2018, 10:36 AM | #7 |
Rep 6,121
My X3 does sometimes too, it has to be something that's shared between all of these models.
12-19-2018, 11:21 AM | #8 |
Rep 790
Our X5 is solid as a rock. I’m very sensitive to creaks, rattles, etc...and there are zero. Quite happy with that! Our 2016 528i that we turned in to get the X5 had 43k miles on it and also had zero creaks or rattles.
- Scott
Current Cars: 2019 X5 xDrive40i M-Sport, 2018 Camaro ZL1 Past BMWs: '16 528i, '00 M-Coupe, '14 X1 sDrive28i, '00 740iL, '02 325i, '99 M-Coupe, '00 323Ci, '79 323i, '83 320i |
12-19-2018, 01:09 PM | #9 |
Rep 28
I actually have my car in service today to address this issue exactly. I hear a "clunk" sound when backing out of a driveway or even sometimes when taking a RH turn from a stop sign. It is very consistent. I have a feeling that I am going to get the old, "Customer complaint cannot be replicated, no problem found"
Wild Blue3683.50 |
12-19-2018, 02:11 PM | #10 | |
Rep 668
12-19-2018, 02:26 PM | #11 | |
Rep 684
No idea if this helps at all, but I thought I'd put it out there just in case...
2019 G05 X5 40i, Phytonic Blue, Black Extended Merino Leather Interior
X5_CC288.50 |
12-19-2018, 11:32 PM | #12 |
Rep 75
I had the same issue on my E70 and after so many trips to the dealership with no luck to find the root cause, I found it myself, it was the latch where the back seat locks to secure it. On either side, in my case it was the right side, I just used the black electric tape on the metal piece, and the friction was reduced to zero, no more cluck noise. It used to drive me crazy, I know the feeling!
12-20-2018, 05:49 AM | #13 | |
Rep 978
X5_CC288.50 |
12-20-2018, 09:42 AM | #14 | |
Rep 668
Here are some pictures. I just wrapped the front and back sides of the little bracket with electrical tape. |
Xeno315.00 |
12-20-2018, 09:47 AM | #15 | ||
Rep 75
01-02-2019, 11:00 AM | #19 |
Rep 1,133
This stuff works awesome on all kinds of squeaks and rattles. Always keep a roll on hand.
J.V. Converting FELT-06/BLK0755 JVCC FELT-06 Polyester Felt Tape: 3/4" x 15 ft, black https://www.amazon.com/dp/B01455QMX4..._B3olCbBTKKYVF
It's good to be bad
01-06-2019, 08:38 PM | #20 |
Rep 17
The X5 was in service last week for noise. I drove around with a BMW Tech..."unable to replicate popping / knocking noises". It was pouring rain 45 degrees (extreme cold for central Florida). The last few days were in the high 70's...the freaking knocking noises are back. Temperature induces?
I will try the electrical tape method--Thank You for the photos. But I was hearing the knocking sounds even with the back seats down. Not sure if my problem is seat latch related. I've applied rubber weather strips to all the cheap plastic in the cargo area under the carpet. Seems like the BMW engineers spent all their time making front cabin all nice and quiet; however, they just said, "fuck it" we'll just use cheap noisy Chinese plastic molding for the under the cargo area liner. The plastic pieces make so much knocking/popping sounds when I press or push one again the other. This is where I applied lots of rubber weather strips. They work quite well as sound abatement. Having done all that, I'm still hearing an occasional pop, but it's not as loud. I'd say it's 75% improvement. Now I'm experiencing a new annoying noise--the moon roof liner rattles like rattle snake when it is opened all the way. It's quiet when closed (fully extended) all the way. Rattles when going over bumpy surfaces. I just hit 1200 miles today. No other issues. |
01-07-2019, 01:00 PM | #21 | |
Self-Deprecating Narcissist
7266
Rep 6,561
