02-02-2019, 08:46 PM | #1 |
Rep 6,121
'Replace battery'
My car is throwing this code despite the battery being fine. It must've been low from delivery and after getting wrapping it likely drained sitting for a week. I can't clear the code with my OBDII scanner and my dealer is closed until Monday any ideas?
02-02-2019, 08:48 PM | #2 |
817
Rep 1,785
I'd put it on a battery tender for 24 hours. The code might clear once the battery is fully charged. good luck.
COL(Ret), US Army Hagerstown MD 2019 X5 40i MSport Alpine White/Coffee (my 13th BMW) 2015 Mercedes SL400; 2009 Lexus RX350 |
02-02-2019, 08:50 PM | #4 |
Rep 6,121
I drove 300 miles home and still have the code so it's probably fully charged
02-02-2019, 08:50 PM | #5 |
Rep 6,121
Yes everything runs fine no issues whatsoever. the code is just annoying because I can't see my odometer
02-02-2019, 08:51 PM | #7 |
817
Rep 1,785
Well, I guess a trip to the dealer is next. Sorry, I hope your dealer is closer than mine.
02-02-2019, 08:52 PM | #8 |
Rep 6,121
don't get people started, you know how crazy they get
10 miles away, all highway no traffic usually I just don't want to go there lol
02-02-2019, 08:55 PM | #10 |
Rep 240
Exactly same on mine. Went by dealer and am getting new battery next week.
02-02-2019, 08:55 PM | #11 |
Rep 6,121
It's more of the car also dings at me because it's a car alert random too
02-02-2019, 08:56 PM | #12 | ||
Rep 6,121
02-02-2019, 09:01 PM | #13 |
Rep 240
02-02-2019, 09:17 PM | #15 | |||
Rep 6,121
Maybe mine will be cool like that or just clear the code if the battery is fine. What's strange is I can clear the code when the car is in diagnostic mode but it immediately throws the same code once I start the engine. This tells me there's likely a problem or it's just German
02-03-2019, 06:25 AM | #16 | |||
Rep 190
02-03-2019, 07:23 AM | #17 |
817
Rep 1,785
Does the X5 have 2 batteries?
02-03-2019, 07:34 AM | #18 |
Rep 978
G05 uses two batteries.... One in the trunk and one in the engine compartment. Depending on your features, the engine compartment Aux battery is either AGM or Lithium.
From the training manual: • AGM starter battery in the luggage compartment with 90 Ah or 105 Ah • Auxiliary AGM battery in the engine compartment with 60 Ah OR • Lithium ion auxiliary battery in the engine compartment with 10 Ah An auxiliary battery in the engine compartment is used to provide assistance for the vehicle electrical system. On vehicles with electric active roll stabilization, the two anti-roll bar actuators are also supplied with power by a 60 Ah AGM battery. In vehicles without active roll stabilization; a 10 Ah lithium ion battery is installed parallel to the AGM battery in the luggage compartment. If you ever need to jump start yourself or someone else... or want to use a battery tender... there is a red cap covered post for positive and and good ground point will work for the negative point - the owners manual identifies a good grounding point. . Last edited by lumpydog; 02-03-2019 at 07:45 AM.. |
AndroidRobot4326.00 X51990.00 |
02-03-2019, 08:40 AM | #19 | |
Rep 6,121
02-03-2019, 08:46 AM | #20 |
146
Rep 342
See this thread: https://g05.bimmerpost.com/forums/sh....php?t=1573753
The same thing have happened to me and the OP of that thread. AndroidRobot, did the guys who did your ppf,/ceramic/tint leave the key inside the car or never turn the car completely off? Even if you push the start/stop button the car's electronics will still stay on unless you lock the car and walk away. If you have the doors open for hours per day, a few days in a row, the battery will die. There's a function to "turn off vehicle" if you push up on the iDrive knob, scroll all the way to the right, you'll see an option to turn everything off. I had the same red "Replace Battery" warning that wouldn't go away. When I took it in, my SA said it wouldn't hold a charge. He also said they can see literally every instance you turn the car on, how long it stayed on, and whether the ignition was on or not. For example, if you go to your car, get in, sit down and customize your widgets for 4 minutes then leave without ever starting the engine, it will get logged. They see all this the moment they hook the car up to their computer, so, you can't really lie to them. My SA also said batteries are not covered under warranty cuz they're normal wear and tear items, but he replaced mine anyway cuz the car was only a week old. BMW batteries are not cheap and you'd have to get them "programmed" to your vehicle. It's a good idea for people who have their G05's worked on to let their installers know how to turn off all the car's electronics, since there's so much of it, so that the car's battery won't get completely drained. |
02-03-2019, 08:50 AM | #21 | |
Rep 6,121
02-03-2019, 08:54 AM | #22 | ||
146
Rep 342
