06-11-2019, 11:43 PM | #1 |
Rep 13
"Assisted Driving Plus" vs "Assisted Driving Mode"
I recently purchased a 2019 BMW X5 XDrive40i. It has the Driving Assistance Professional Package, which according to the description includes Active Driving Assistant Pro.
It works well and I like it. But there is one thing that I can't figure out. I looked in the X5 G05 Owner's Manual and there is no mention of 'Driving Assistance Professional Package' or 'Active Driving Assistant Pro'. I push the button on the steering wheel that is a picture of a car with a steering wheel below it. That switches on the assisted driving. The owner's manual describes two available modes (selectable by pressing the MODE button on the steering wheel): -Cruise control with distance control (icon of car by speedometer) -Cruise control with distance control and steering and lane control assistant (icon of a car over a steering wheel with lane markers on each side) When I select the mode "Cruise control with distance control and steering and lane control assistant", I'm able to have the car 'self drive', as it keeps the lane and maintains the distance between my car and the car in front. However I must continue to hold the steering wheel. If I let go of the steering wheel, within a minute or so I'm directed by the car to put my hands back on the steering wheel with a yellow warning of hands moving to the steering wheel. If I continue to ignore the warning, the hands become red, the hazard lights come one, and the lane keeping and self driving disable. However, I noticed that sometimes I have a third option appear, called "Assisted Driving Plus". I have no idea why that option appears sometimes, and sometimes does not. When it does appear, I can select it with the mode button. After that I can drive for long periods of time without having to touch the steering wheel. I drove for more than 15 minutes on the freeway without ever having to touch the steering wheel. However eventually the "Assisted Driving Plus" went away, was replaced with "Assisted Driving Mode", and again I was forced to put my hands on the steering wheel. I can find no documentation on "Assisted Driving Plus". Does anyone know anything about it? Why can I only select it occasionally? Why isn't it in the Owner's Manual? See attached .jpg images of the "Assisted Driving Plus" and the "Assisted Driving Mode" icons on the dashboard. Thanks in advance. |
06-11-2019, 11:53 PM | #2 | |
456bhp for breakfast
425
Rep 913
Read up on these sections in the manual. It's very cool! |
natahoa252.00 |
06-12-2019, 12:30 AM | #4 |
Rep 272
Is Assisted Driving Plus available in all countries?
I have never seen that option pop even though I am sure I met the functional requirements as per the screen shot few times. |
06-12-2019, 12:41 AM | #5 |
13247
Rep 19,752
This post has some pics I took when the conditions were correct, they show the message that comes up as well as the option in the menu bar. Just hit Mode and you are then in hands free.
https://g05.bimmerpost.com/forums/sh...0&postcount=18 |
06-12-2019, 01:19 AM | #6 |
210
Rep 323
Drives: BMW X5 G05 30d/BMW M5 F90 Comp
Nope. In Australia we can't use it due to regulations. I am sure BMW will software activate it once the law catches up with modern times. We have the hardware.
OzJedi107.00 |
06-12-2019, 01:47 AM | #7 |
Rep 1,236
They previously used "Traffic Jam Assist" to describe this function and I think it a much more easily understood term.
Now they use "Assisted Driving Plus" and who would have guessed what "Plus" means without reading the manual? |
06-12-2019, 05:50 AM | #9 |
Rep 602
I have the Driving Assistance Professional Package but I can only keep my hands off the wheel for maybe seven seconds or so. I thought this was extended to something longer like the OP suggested where they have a whole minute before having to grab the wheel. I’m in the US so maybe that has something to do with it?
06-12-2019, 08:20 AM | #10 | |
425
Rep 913
06-12-2019, 08:27 AM | #11 |
Rep 602
06-12-2019, 08:36 AM | #12 |
13247
Rep 19,752
What you're describing is in the normal range. Some have reported longer intervals at slower speeds or less traveled roads but I have not experienced that.
06-12-2019, 08:45 AM | #13 | |
425
Rep 913
06-19-2019, 09:04 AM | #14 |
Rep 105
I have not seen Driving Assistant Plus show up as an option yet I have the package on my car. Potentially a real stupid question but there are many times I believe I have met all the Functional Requirements but still no option. The one possibility is Lane Departure is "unchecked" on my car since I did not like the jerking of the steering wheel but do I have to have it checked to comply with "The steering and lane control assistant is active."?
06-19-2019, 09:13 AM | #15 | |
13247
Rep 19,752
Mine always comes on when I'm in a traffic jam on an Interstate although of course I wish I wasn't in that situation. Next time you are on an Interstate (it could work on other divided highways) and you hit a traffic jam. After a stop, hit resume (unless you had the cruise stop for you) and as you are increasing speed it should pop up the option as long as lane markings are clear. |
06-19-2019, 09:17 AM | #16 | |
Rep 105
06-19-2019, 10:11 AM | #17 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
Garage List 1998 Jeep Cherokee ... [0.00]
2011 Toyota Highlander [0.00] 1998 Plymouth voyager [0.00] 2019 X5 40i [0.00] |
The owners manual is kinda wonky. You would think certain settings are grouped together, but not always. I can’t recall my exact issue, but a setting I was looking for turned out to be in the iDrive menu.
It’s not very intuitive, and the search function also isn’t great. It is like getting a new computer or phone - just have to figure it out as you go along. |
06-23-2019, 01:08 PM | #18 |
Rep 105
Still trying to get Assisted Driving Plus to appear but no luck yet. I double checked my sticker and I have it noting Traffic Jam Assist. I must not be doing something right? Or it's not seeing road markings as clearly as it needs to? I will keep checking and hopefully it will appear at some point.
06-23-2019, 01:15 PM | #19 | |
13247
Rep 19,752
06-24-2019, 05:46 AM | #20 |
Rep 105
I confident I have it since it was requested on the build sheet. I pulled the Monroney sticker and it states:
Drivers Assistance Pro Pkg Extended Traffic Jam Assistant Active Driving Assistant Pro It's just odd while at times I feel it should have come up but has not. Maybe the lines on the road are not correct. I also have "unchecked" lane change assistant which was trying to keep me centered in the lane and the wheel pull was a little alarming. But I don't think I need that checked? If all else fails I will try the dealer but that can be hit or miss since some of my options I had to show the kid how to use, like pairing my phone to unlock the car and use as a "key". |
06-24-2019, 02:47 PM | #21 | |
Rep 684
2019 G05 X5 40i, Phytonic Blue, Black Extended Merino Leather Interior
06-25-2019, 05:52 PM | #22 |
Rep 105
Finally! It worked today on my way home from work. Most likely my issue before was either not enough traffic to warrant it or it was activating on its own when I was on Assisted Driving. The lights on the steering wheel turned green and it was off and running like a champ.
