Extended BMW 335d PIDs for Torque
10-15-2015, 07:56 AM | #45 |
798
Rep 1,633
I want to let everyone know that the H20/Meth Target PID is not a conservative number. It is based on relatively dry air and having margin on AFR.
The intent was to 1) help folks size their systems correctly. That's why it is not conservative. It is easier to tweak down with the controller, than jump up with a nozzle. And 2) to facilitate an understanding of H20/Meth injection. |
10-15-2015, 10:33 AM | #47 |
798
Rep 1,633
10-15-2015, 10:48 AM | #48 |
798
Rep 1,633
Based on feedback, I've returned exhaust pressure to its previous form to match up with Testo output. DPF and Turbo Drive Pressure also follow suit. It is a very small adjustment, for the "tuning scientists". See attachment.
10-15-2015, 10:48 AM | #49 |
Rep 5,623
I cant view EGT parameters in torque but can with BMWhat. Will using your pids let me view these additional parameters? Also, is there a danger it might brick my ecu as my car is a UK one?
10-15-2015, 10:57 AM | #50 |
798
Rep 1,633
10-19-2015, 12:10 AM | #51 | |
Rep 697
The file from this post did not show any PIDs for me. However, the file in your very first post works. Not sure if it's the file or my app. |
10-19-2015, 09:27 AM | #52 |
144
Rep 316
Ah, well that's just too damn simple. Never messed with torque before so I'm still learning the basics LOL. I've been spoiled data logging on vw/audi stuff with VCDS (similar to bav-tech).
10-19-2015, 11:16 AM | #53 |
798
Rep 1,633
I hate to say it but the VW guys are just plain ahead of us. I am most jealous of the pressure sensing glow plugs - could really dial in water/meth will that. Wish someone would try to modify one of our glow plugs.
10-19-2015, 12:20 PM | #54 |
427
Rep 1,040
Where did we leave off with this? Let's find the closest candidate in length and make it happen....
10-19-2015, 01:26 PM | #55 | |
798
Rep 1,633
Adapt a VW PSG to the 335d. There are 5 variants, none of which will fit without some sort of adapter/modification. Second option is to fit a pressure sensor to one of our plugs. Optrand makes a small affordable sensor that could be inserted into the body of a glow plug. I don't know the details of how either would be done, as I am in no position to make it happen. Then there is instrumentation, which is pretty straight forward. Simple voltage signal, but need a very fast data logger. A PC oscilloscope would probably be most useful from a tuning perspective. I can take care of that part of the project. We can start a new thread if others are interested in this. So far,I think it is just you and me. |
10-27-2015, 11:33 AM | #56 |
798
Rep 1,633
Using the DPF differential Pressure PID for alphabet soupers
For those of you who have deleted the DPF and have no use for the differential presure sensor - think again:
Connect it to the "dirty" and "clean" side of the air filter and you have an electronic Filter Minder Connect it to the "dirty" side of the air filter and atmosphere and measure the "ram air" effect with speed. In the future, I maybe creating a pressure differential MAF PID, for those of you who are getting a clipped signal from the stock MAF due to increased boost and intake modifications. Not sure what the working pressure limit is. It may be able to measure pressure drop across an intercooler, or other fun things. Any other creative ideas? |
10-27-2015, 05:16 PM | #57 |
Rep 2,410
You can also use that sensor to measure how clogged your SCR is :-)
http://www.e90post.com/forums/showpo...7&postcount=60
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
11-01-2015, 07:01 PM | #58 | |
Rep 2,410
http://www.e90post.com/forums/showpo...4&postcount=55
11-04-2015, 03:28 PM | #59 |
Rep 5,623
Used the pids today in post #36, but only 3 of them were green. My car is a euro 03/2008 335d. I got drive pressure as one of the 3 greens but it stayed zero. The one i really wanted was the boost pressure, but for some reason it didnt pick it up on my car
I might try some of the other files. |
11-04-2015, 10:00 PM | #60 | |
798
Rep 1,633
Here are the IDs and descriptions available for your ECU: ID Description 0x0001 Anzahl bestätigter DTCs und MIL Status 0x0004 berechneter Lastwert 0x0005 Kühlmitteltemperatur (Sensorwert vor der Korrektur) 0x000B Ladedruck (Sensorwert vor der Korrektur) 0x000C Motordrehzahl - Rohwert vor der Korrektur für OBD Tester 0x000D Fahrzeuggeschwindigkeit 0x000F Ansauglufttemperatur 0x0010 Luftmasse von HFM 0x0011 Ausgangstastverhältnis - Drosselklappe (vor der Korrektur) 0x001C OBD Zulassung des Fahrzeugs 0x001D Location of oxygen sensors 0x001F Betriebsdauer seit letztem Motorstart 0x0021 gefahrene Wegstrecke im Zustand MIL ON 0x0023 Raildruck (linearisiert) 0x0024 Lambdasensor Signal - Equivalence Ratio Bank 1 - Sensor 1 0 0x010E Lambdasensor Signal - Oxygen Sensor Voltage Bank 1 - Sensor 1 0x002C Ausgangstastverhältnis - Abgasrückführregelventil 0x002D Abgasrückführregler - Regelabweichung 0x0030 Anzahl der Warm-ups seit Löschen der DTCs 0x0031 gefahrene Strecke seit letztem Löschen der Fehlercodes 0x0033 Umgebungsdruck (Sensorwert vor der Korrektur) 0x003C Catalyst Temperature Bank 1, Sensor 1 0x003E Catalyst Temperature Bank 1, Sensor 2 0x0041 monitor status since last engine shut off 0x0042 Batteriespannung (Sensorwert vor der Korrektur) 0x0045 Tastverhältnis - Drosselklappe 0x0046 Umgebungstemperatur 0x0049 Pedalwertgeber - ungefiltertes Signal 0x004A Pedalwertgeber - Rohspannung von Sensor 2 0x004C Solltastverhältnis - Drosselklappe You may modify the custom PID for Boost by changing the ID. Find "170" in the Boost PID and change it to "10B". "1" designates the OBD Mode and "0B" is the ID, as in the list above. |
Persian Whisperjet166.50 |
11-05-2015, 01:57 AM | #61 |
Rep 5,623
Thanks DWR i will give that a go tonight
Is that the full list of available IDs for my ECU? Is there an ID available on my ECU to monitor EGTs and oil temp? |
11-05-2015, 08:59 AM | #63 | |
COAL FED
74
Rep 300
It would be interesting to see if we can adapt a sensor that will allow the plug to remain functional.
11-06-2015, 04:14 AM | #64 | |
Rep 5,623
Do you think it may be my MAP sensor? |
11-06-2015, 08:09 AM | #65 | |
798
Rep 1,633
11-09-2015, 10:59 PM | #66 |
Rep 572
Hi Guys!
I hope you can help me. I am using BAFX adapter and Torque Pro app on my BMW X5 35d (2011). I purchase this combo primarily to have access to transmission temp. Other owner of 50i reported that he can access the temp. There are two "Methods" available in the app for the trans temp, but both are not working for me... The app states "no data". Please could you help to get the information on the transmission temp? Thanks! |
