Diesel Fuel Additives?
03-22-2017, 11:46 PM | #67 | |
Rep 1,157
03-23-2017, 10:55 AM | #68 | |
Rep 153
I currently run kleen in my D now. dont really notice a difference, hoping it would clear up my slightly rougher idle (assuming it is due to CBU). |
03-24-2017, 07:26 AM | #69 | |
Rep 104
I run Precision turbo's HPL 5-30 diesel oil. It's $16 a quart, but I get it for a drastically reduced cost. One of my friends I studied engineering with works at Precision turbo and their shop is 10 minutes from my house. I'll be working on getting oil analysis done and forum discounts once I gauge more interest. I'll have a thread up relatively soon about it. |
04-07-2017, 05:09 PM | #70 | |
217
Rep 1,909
Archoil Turbo Maxx bla bla
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
04-09-2017, 12:01 AM | #72 |
217
Rep 1,909
what difference did you feel ?
04-09-2017, 11:13 AM | #73 |
389
Rep 1,623
That video is interesting and not sure how that test relates to use in an internal combustion engine.
I have two personal experiences with Archoil completely fixing a problem that otherwise would have required replacement parts. First, I had a 2005 Excursion with the 6.0 PSD. I had replaced countless injectors and always had an issue with stiction and experienced difficult cold starts. I tried rev-x, hot shot secrets and countless other fuel and oil additives with no change in the vehicles behavior. I constantly replaced injectors and it'd be OK for a few thousand miles but eventually, the systems always came back. I was at my wits end. I heard about archoil and ordered some. Within the first 45 minutes, the archoil completley cured my PSD of stiction and I never again had a cold start issue, even in sub zero temps in the VT mountains. I put another 70-80k miles on the engine before I sold it. In that time, I never had another stiction or cold start issue. Second, I picked up a 1995 E34 525i for a turbo project. The M50 engine handles boost exceedingly well. I intended on keeping the engine stock and simply replacing the head bolts with ARP studs one at a time in order to keep the OEM head gasket intact for the build. I was going to use E85, which would benefit from the stock compression ratio. I picked the car up and drove it home, someone had stolen the cat so it was loud. Once I got the car quited down, i realized it had significant lifter noise. I was pretty bummed as I wasn't really motivated to replace the lifters... As a last ditch effort, I threw in some archoil. Within minutes the lifter noise was completely gone. To this day, the lifter noise is still gone. I have been running archoil in everything... differentials, transfer-case, quads, tractor, diesel and gasoline engines etc. All of my friends now run it in their cars/ trucks too, all with similar results. I do not doubt the test in the video, just don't know how it translates to effectiveness in an internal combustion engine or differential. An item of note, Archoil is a friction modifier but it also contains detergents that help with lubricating and cleaning tight tolerance areas like injectors and lifters. I have and will continue to use it. Last edited by 335dsleeper; 04-11-2017 at 01:25 AM.. |
04-23-2017, 04:16 PM | #74 |
Rep 38
I add 1/4 oz/gal of Optilube every time I buy fuel. At 98000 miles I have never had to replace a injector or glow plug. Are the two related? Who knows? PL says no way but circumstantial evidence says yes. My original intent was to increase the lubricity which Optilube does. If other benefits occur its a bonus.
2009 335d
2016 VW GSW SE tsi 2008 VW rabbit (daughters car) 2004 Nissan Titan (big brakes, air springs) 1972 240Z (set up for road racing, autox) |
04-24-2017, 02:35 PM | #75 | |
Rep 1,157
04-24-2017, 05:54 PM | #76 |
Rep 38
It stands to reason that cleaner and more complete combustion would be beneficial to glow plug life but since I have not researched the topic its just an assumption.
2009 335d
04-27-2017, 05:32 PM | #77 |
Rep 722
i highly doubt this.
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
08-29-2017, 02:16 PM | #78 |
Rep 601
Although it's not a BMW and may depend on the year of your car .... I was told by a Ford diesel mechanic to use 2-cycle oil every fill up for my Ford F-350 7.3l (I do it every other). Using 2-cycle oil has been written about on diesel truck forums ever since the US switched to low-sulfur highway diesel. I've been running 2-cycle as an additive for about 6 years / 50k miles (haven't been driving it much the past couple of years)
It's said to keep your injectors from burning up. As today's diesel is considered a "dry" diesel compared the a "wet" diesel of yesteryear. I doesn't take much ... I use at least 16 fl oz for a 24 gal fill up (30gal tank). The correct ratio is said to be 1oz of 2-cycle per gal of diesel. Lots of people state with the addition of the 2-cycle oil they have seen 1-2 mpg gain. Personally I haven't paid much attention to mpg ... it's a big truck it's gonna get crap mpg. However I do notice it runs quieter. Outside of the 2-Cycle about once a couple month or so I'll add Diesel Kleen instead to clean the injectors a bit. Last edited by N52UNED; 08-29-2017 at 02:52 PM.. |
kydiesel35166.00 |
09-06-2017, 11:29 AM | #79 |
Rep 153
useless update: but I am running LM Ceratec in my car for the past 4-5k miles and I dont really notice a difference, i have a couple of track days with it too, so nothing catastrophic happened. i saved a lil bit of my old oil (no additives) and will save a lil bit of this when i change it at approx 7k. I intend on sending it out to blackstone and see if there is any differences in the levels of metals present to see if the additive actually did reduce wear.
update with some data soon to come. |
Built4Sin57.00 |
09-29-2017, 08:32 PM | #80 |
Rep 258
BG 244. Half a quart in a full tank of gas every 10K miles or so. Just used it recently for the first time and immediately felt the engine running smoother. MPG increase was slight but absolutely a smoother/quieter running engine. Not sold at your local auto parts store but is avail on Amazon - https://www.amazon.com/BG244-Diesel-...dp/B00K0WR7VI/
11-17-2017, 02:16 AM | #81 |
Rep 123
I am having great success with HotShotsSecret additives. I ran their Extreme Diesel in 1 tank and my sticky injector issue is GONE!!!!!! Love it....I am running the Everyday Diesel Treatment now and like it so much better than LubriMoly or Diesel Kleen....This last tank I went 464 miles and I don’t have a lite foot...
03-11-2018, 09:07 PM | #82 |
Sleepy
75
Rep 367
Just saw a new product at walmart its duralube def cleaner fuel additive and fuel system treatment. Anyone use this yet?
Its got some chemicals in it i have never heard of before. Ill try it and see since i still have my def. |
03-17-2018, 08:46 AM | #84 |
2131
Rep 3,361
You run gas in your d? Just kidding. I have had great luck with hot shots diesel extreme, buttery quiet injectors now. Nice to see another local d. I work in Orange cty, NY
03-29-2018, 02:21 PM | #85 | |
Tim
54
Rep 206
03-30-2018, 08:16 AM | #86 |
Rep 1,157
03-30-2018, 08:35 AM | #87 | |
Rep 866
Now at total 650,000 miles on my diesels.... If I did have sticky injectors, I would use an additive which is basically their original purpose. |
03-30-2018, 10:34 AM | #88 | |
Rep 1,157
From what I have seen, everyone running the Hot Shot's Secret Diesel Extreme(Here's some info: https://www.hotshotsecret.com/diesel-extreme/) and/or EDT(More info: https://www.hotshotsecret.com/edt-ev...sel-treatment/) see a 2-3mpg increase(I have tested this myself, and can confirm), less smoke on deleted cars(I have tested this myself, and can confirm), more power from the butt dyno(I have tested this myself, and can confirm), and quieter injectors(I have tested this myself, and can confirm). On top of that it has been known to clear injector codes on more than one occasion. You can say just fuel is good, and sure it's "good enough", but until you try an additive, don't knock it. Or are you scared you'll be satisfied |
